Question about M-Audio Mobile USB MIDI Controller
Need more detailed instructions to assign buttons and basically to know the function of each button and how to apply them
  • Bob Morris
    Bob Morris May 11, 2010
    What is the make and model? Binary Bob
    President:
  • 8,637 Answers
It will tell you which button. Normal 0 If you are then go to Control Panel.
1. Click on PRINTERS.
2. When the Printer Properties come up, CLICK on KEY SETTINGS.
3. Then set up the keys by selecting the key to be setup.
Hope this helps. Bud
Posted on Jan 17, 2009
Tip
Connect PS3 to the Internet
Wired Connectivity:
The network configuration and connection depends on the connection method and equipment you have.
Important: A router would be required if you want your PS3 and the computer to be connected to the internet at the same time.
The following are mandatory. You need:
  • An Internet connection
  • A cable modem
  • Ethernet cable. (Available with the PS3)
When you have a wired connection to the Internet, it is not necessary to adjust any of the default settings. (It is done automatically). If you aren't able to connect with the default settings, follow the instructions to adjust the settings.
  1. Select "Network Settings" under "Settings" in the home menu, press the x_button.jpg button.
  2. Select "Internet Connection Settings", press the x_button.jpg button.
  3. You will be popped with a message stating the Internet connection will be terminated, select Yes, press the x_button.jpg button.
  4. Select "Wired Connection", press the x_button.jpg button.
  5. Select Easy or Custom and adjust the settings.
    • If you select Easy, then the basic settings are automatically set.
    • If you select Custom, then you need to enter the settings. Refer the settings supplied by your Internet service provider.
Back to top
Wireless Connectivity:
  • A cable modem and a router
  • Access point (Not necessary if using a wireless router with built-in wireless functionality)
  • Settings information for the access point (SSID, WEP key, WPA key)
When you try to connect wirelessly to the Internet, First adjust the network settings. These settings may change depending on the type of access point and the network environment you are in.
The following instructions apply most of the network configurations.
  4. Select "Wireless", press the x_button.jpg button.
  5. Select "Scan", press the x_button.jpg button.
    The system will search for access points within range and display them as a list.
  6. Select the access point that you want to use, press the x_button.jpg button. (An SSID is a code or a name that is assigned to the access point. If you have no clue which SSID to use or if the SSID is not displayed, contact the person who set up or maintains the access point.)
  7. Confirm the SSID for the access point, press the right button.
  8. Select the security settings as necessary, press the right button.
  9. Enter the encryption key, press the right button. (The encryption key field will display an asterisk (*) for each character you enter. If you do not know the key, contact the person who set up or maintains the access point).
  10. Select Easy or Custom and adjust the settings.
on Feb 20, 2010 | Video Game Consoles & Games
How do i assign functions to the profit mouse?
Click Start, and then click Control Panel.
Note If you use Microsoft Windows XP, click Start, and then click Control Panel.
Double-click Mouse.
Click the Buttons tab.
Under Button Assignment, click the box for a button to which you want to assign a function, and then click the function that you want to assign to that button.
Repeat this step for each button to which you want to assign a function.
Click Apply, and then click OK.
Close Control Panel.
Jun 10, 2014 | Kensington PROFIT WIRELESS MID-SIZE MOUSE
Unable to record or playback on new DP 02
It sounds like either the inputs are not assigned or the tracks are not armed for recording (or both).
Here is a quick explanation of the procedure involved in recording with the DP-02 that I posted for another person who was asking for some basic instruction on how to record. You might be missing a step somewhere along the line as for instance you will still see the meters move even if you don't have the inputs assigned or don't have any tracks armed, but the DP-02 won't record anything until you do both.
To record you need to first assign your input to a track, then arm the track for recording, and then press play + record at the same time.
1. So you would patch your mixer output, mic or instrument into an input on your DP01 (say input A). You can run some audio to set the level with the input level knob (located next to input A on the front panel).
2. Then to assign that input to a track simply press and hold the 'input A' button and then press the 'rec' button of the track you with to record on. The 'rec' button will flash rapidly to indicate that the input is assigned to the track.
(To assign the input to a different track you have to clear the input assignment from the first track and assign the input to a new track. To clear an assignment press the input assign key, A in this case, and the track it's assigned to will flash its 'rec' button. Hold down the input assign key and then press the flashing 'rec' button. The button will stop flashing and the input can then be assigned to another track by following step 2 again).
3. Next, to arm the track for recording simply press the 'rec' button for that track. The 'rec' button with flash slowly.
4. To begin recording press play + record together in the transport section and the 'rec' light for the armed track will stop flashing and light steadily. Press 'stop' to end recording.
This should get you started. The operation of the DP02 is actually pretty intuitive once you've gone through it a couple of times (which is one of the real strengths of the unit). You'll be multitracking like an expert in no time.
Hope this helped.
Cheers,
bd.
Nov 25, 2008 | Tascam 2488 Portastudio Multitrack...
Gulbeyaz_hellokitty@hotmail.com
This is directly from Logitech:http://logitech-en-emea.custhelp.com/
"Logitech MouseWare Software:
1. Right click on the Logitech white mouse icon in the System Tray and select "Mouse Properties".
2. Click on the "Buttons" tab and your pointing device should be shown. If you have more that one mouse connected, select the mouse you wish to program by clicking on the "Devices" tab, and select the mouse you wish to program from the drop down menu, then go back to the "Buttons" tab.
3. Scroll down the list of buttons and select the button you wish to program, and click on the function to highlight it.
4. Now click on the "Modify" button. A "Modify Button Function" box will appear with a drop down menu. Select the button assignment you wish to use and click the "OK" button. Now click the "Apply" button to save your changes.
Using the "Keystroke" button assignment.
If the button assignment or keyboard command you want is not listed under the button assignments, you may want to use the "Keystroke" button assignment. Using the MouseWare steps above select Keystroke under Step 3. The "Keystroke Assignment" box appears. Click your mouse cursor into the box that states "Unassigned". Now press the key or combination of keys you wish to use and click the "OK" button. The function should now be displayed in the current list of button assignments. Click the "Apply" button then the "OK" button."
Hopefully this will help. Please let me know if it doesn't.
Nov 25, 2008 | Logitech Cordless Click! Mouse
Trying to bind my MX400 Mouse's forward and backward buttons inside of games. I've been using the Setpoint tool, tried binding them to keys on the keyboard with no success.
Try setting the buttons to "generic" in SetPoint and then assign fuctions via the game options.
From Logitech Knowledge Base:
The information in this article applies to the following products:
All Logitech Mice
Logitech SetPoint
Cause:
Most games that support a mouse will give you options to program or assign specific functions to various buttons on the mouse. These games normally look for generic mouse buttons when attempting to bind the mouse buttons to a game function. If the button is set to another function in SetPoint (such as Universal Scroll, Back, Forward, etc), the game may not see the mouse button as available to bind. This mainly affects buttons 3, 4, and 5.
Solution:
To resolve this issue, set the button you wish to program to a generic value in SetPoint. The following values should be used if you are having problems binding buttons in games.
Mouse Button 3 (The Middle Button/Scroll Wheel):
In SetPoint, assign this button as Middle Button or Generic Button.
Note for MX Revolution users: You must disable Logitech Smart Shift Technology or the Middle Button option will not be available in SetPoint.
Mouse Buttons 4 and 5 (Normally the thumb buttons):
In SetPoint, assign the thumb button(s) as Generic Button. Note that these buttons will still work in most browsers for forward and back. It is not necessary to assign these buttons to Forward and Back in SetPoint for this functionality.
May 15, 2008 | Computers & Internet
Compaq keyboard
You probably need to load the Compaq utility that assigns and activates the keys. Go to http://h18000.www1.hp.com/cpq_support.html
enter the model number of your compaq computer, and search the available downloads for the utility.
Nov 27, 2007 | Compaq Presario 5000 PC Desktop
Copy function
well you gotta provide the details in scanners configuration where you want the scanner to copy your Documents to .i.e. whether you want it to scan and store it as a image or open it with some Application or you want it to print just assign any one task with proper configuration it will definately work.
Thanks
Nov 17, 2007 | Canon CanoScan LiDE 30 Flatbed Scanner
Changing Sensitivity
1. Open the SetPointTM software and assign a keystroke to the button you want to use. For further details about this procedure, launch the Help Center within SetPoint and view the mouse topic To change the task assigned to a button. 2. Click the Windows® Start button, locate the function or application you want to launch and right-click it to display a menu. (If the function or application you want to launch is not available from the Windows Start menu, use Windows Explorer to locate it and then right-click it.) 3. Select Properties. 4. In the Shortcut tab, enter a Shortcut key that is the same as the keystroke you chose at step 1. 5. Click OK.
Oct 06, 2005 | Logitech MX1000 Laser Cordless...
“Custom Button”
The custom button can be used to assign specific camera functions set by the user. This function allows the user to quickly select assigned camera functions by pressing the custom button and selecting settings using the control dial.
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
M-Audio Mobile USB MIDI Controller Logo
114 people viewed this question
Top M-Audio Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
John Bolton
Jim Goldsmith
Jim Goldsmith
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
