Question about CTX Panoview 630 Monitor
Have a broken power supply but can't order a new one. can someone tell me te voltage on wich pins?
    Problem Solver:
  • 14 Answers
Panoview 630 Power Connector pinouts:
It has been many years since the question was posted but who knows, maybe this will help someone. Looking at the end of the connector clockwise from 1-oclock position:
1pm:NC
3pm:+12
5pm: no pin
7pm:+5V
9pm:+5V
11pm:GND
shield is GND
+5V@3A
+12V@1.5A
(you can modify an Apple ADB cable to work)
Posted on Jun 04, 2015
3 Suggested Answers
SOURCE: Looking for AC power Adopter for CTX LCD monitor
Check it on Radio Shack maybe they got something
Posted on Jun 03, 2009
  • 32 Answers
SOURCE: ctx monitor
try lowering the screen resolution
Posted on Oct 20, 2009
Behringer mx8000
is your supply gone ? difficult. check inside, you can see what leads feed what regulators, I hope. However, hard to build a supply with all them voltages... get a new one, I suggest. Luck...
Mar 26, 2014 | Audio Players & Recorders
I bought a x2gen mg5r4 monitor at the goodwill I've got a power adapter that supplies the proper voltage & amperage to the monitor. It powers up just fine, but when plugged into the computer it (the
If the monitor indicates "No Sync" Make sure your video cable is a high density DB15 end. If it is only 9 pins, you have a DB9 cable or connection. Also make sure the video you have it attached to is enabled and is also a high density DB15. (it will have 3 rows off pins. The DB9 will have 2 rows)
If those are okay it may be broken wire in the cable or on the monitor's DB15 connector/connection.
Dec 18, 2011 | Computers & Internet
How to fix No Display on LCD Display Panel at all?
Good day, For you lcd issue you may try doing these steps:
1. Check if the the power cable of properly plugged in.
2. Check the cable connecting your monitor to the tower or CPU
3. If there's no power at all you can try to change the power cord and also the monitor to cpu cable.
4. You can also plug it on another outlet to make sure that its not your power outlet that's causing this problem
If everything above doesnt work for you, you might consider having it check by a technician or just purchase a new one. Hope this information help you a bit. Have a great day.
May 24, 2011 | CTX Panoview 510 (White) 15.1 in. Flat...
My monitor is unresponsive. Does not power on anymore. Does anyone have any troubleshooting ideas?
If your monitor uses a power supply (the brick that plugs into the wall, and then a smaller cord plugs into the monitor), then it's more likely the power supply that's gone out than the monitor itself.
Find someone with a multimeter to check the output voltage on the power supply. There will be a label on the power supply that says what the DC voltage (VDC) is supposed to be. If the meter shows no voltage when the power supply is plugged into the wall, then you just need a new power supply.
Do not try using another power supply as a substitute unless it is a specific match to your monitor. They vary widely by output voltage, etc. and using the wrong one could fry your monitor.
Hope that's helpful.
Jan 14, 2011 | Dell E207WFP LCD Monitor
I am replacing a motherboard with a G31-M7 TE and find that my existing power supply has a 20 pin plug consistant with the old motherboard but the new one has a 24 pin socket. Why is this and do I need to...
New motherboards have a 24-pin power connector. Here is a diagram of both plugs:
You can see that the two are almost identical. The extra 4 pins on the 24-pin connector provide extra connection points for a few voltages. Newer boards and processors need more current, and the extra pins were added to prevent overloading.
Adapter cables are available to go from your 20-pin power supply plug to the 24-pin motherboard connector. Here's one from TigerDirect, and other vendors have them as well. If you're not making other changes than replacing the motherboard, you shouldn't need more than this adapter.
If you are upgrading your processor along with the motherboard, you should probably replace the power supply too. Older power supplies are often in the 300-watt range, and this is too low for reliable operation with new processors, motherboards and video cards. A new 500 or 600-watt supply is not expensive, and would give you the 24-pin power connection the motherboard needs.
Hope this has helped. Thanks for using Fixya!
Nov 20, 2010 | Biostar G31-M7 TE Motherboard
Where Can I Buy the Power Adapter ?
follow this link-
http://catalog.ebay.com/Optoma-PanoView-PV755A-White-15-inch-LCD-Monitor-/52116071?_tab=2
hope it helps-
Aug 14, 2009 | Optoma PanoView PV755A 15" Flat Panel LCD...
Dell 1800FP, no signal found (analog). Green LED on, get message
check if your signal cable is properly connected to your system unit and make sure that non of the pins of your signal cable is broken.if any of the pins are broken,try and change the whole signal cable and re-connect it again
after following the above instruction,reboot your computer
thank you for contacting as with your problems,you are always welcomed
Jan 26, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Power connection pinout
Here is a pin connection specification for the ac power supply (dual voltage adaptor)
>socket/plug for a Compaq TFT450 LCD Monitor that she
>supplied (edited for further clarity).
>The pins of the male connector (a PS2 mouse type connector) should be connected like this:
> 1 2
> 3 I 4
> 5 ^ 6
> GND GND
> 5V I 12V
> 5V ^ 12V
>For clarification - the male will be the end of your cable, and not the socket on the monitor.
>The I is the central polarising bar of the connector, and the ^ is the notch.
Jun 16, 2008 | Compaq TFT450 14" LCD Monitor
Replacement External Power Supply
So the old power supply doesn't have the output voltage, current and polarity noted on the label? What a ripoff! *grin* Did you look on the case near where it plugs into the monitor? Sometimes that will tell you the voltasge and polarity. Poliarity? Get that one wrong and the monitor could be cooked instantly! But it's usually positive. I found a completed eBay listing that had this info: "the power supply which the seller used to power up this Planar Flat Panel is inventoried as follows: ViewSonic 12V Power Adaptor Model # SYS1126-5012" I looked that one up, and it's listed as 12V at 4.17A. PC Hub has them for $28.62: http://www.pchub.com/uph/laptop/345-19804-2285/AC_Power_Adapter_5V-12V_Others_SYS1126-5012.html Good luck!
Jan 06, 2007 | Planar PL2010M 20" Flat Panel LCD Monitor
CTX Panoview 630 Monitor Logo
224 people viewed this question
Top CTX Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Steve Allison
Steve Allison
Are you a CTX Computer and Internet Expert? Answer questions, earn points and help others
