Bosch HBL 755 Stainless Steel Electric Double Oven Logo
Posted on Dec 14, 2008
Bosch HBN43N551B electric built in oven. How do I remove the oven from the wall to replace the lamp?
1 Related Answer
Anonymous
  • 235 Answers
  • Posted on Feb 11, 2011
SOURCE: We own a Bosch (Built-in) oven HBN4305.0B and the
With the power turned off it is usually a case of, in most ovens, just removing the element by unscrewing two screws. Unclip the wiring and make a note of what wires go where. Find a new one and install in reverse procedure.
1helpful
I need to replace the bulb housing in a Bosch double oven. Do I need to remove the unit from it's built in unit to gain access?
Question edited for clarity and correct spelling of maker 'bosh' to 'Bosch' and correctly capitalised.
Question moved to a better category.
Yes always.
This is a 4 part video. See if you can find the rest of it.
2answers
Bosch single wall ovens where is the thermal fuse located
Hi!
The location of the thermal fuse in a Bosch single wall oven may vary depending on the model, but it is typically located on the back of the oven.
To locate the thermal fuse, follow these steps:
  1. Turn off power to the oven: Before attempting any repairs, turn off the power to the oven by unplugging it or turning off the circuit breaker that supplies power to the oven.
  2. Remove the back panel: Locate the screws or bolts that hold the back panel of the oven in place and remove them using a screwdriver or socket wrench. Carefully remove the back panel to access the components inside the oven.
  3. Locate the thermal fuse: Look for a small, rectangular device with two wires attached to it. This is the thermal fuse. It may be located near the top or bottom of the back of the oven, depending on the model.
  4. Check the thermal fuse for continuity: Use a multimeter to check the continuity of the thermal fuse. Set the multimeter to the ohms setting and touch the probes to the two terminals of the thermal fuse. If the multimeter shows no continuity, the thermal fuse has blown and needs to be replaced.
  5. Replace the thermal fuse: If the thermal fuse has blown, replace it with a new one of the same rating. Install the new fuse in the same location as the old one and reattach the back panel of the oven.
  6. Test the oven: After replacing the thermal fuse and reassembling the oven, turn on power to the oven and test it to ensure that it is working properly.
If you are not comfortable working with electrical components or if you are unable to locate the thermal fuse in your Bosch single wall oven, it's recommended to seek the assistance of a qualified technician.
Kind regards
Mar 12, 2023 • Bosch Ovens
Control panel is hot
Best dissertation writing services helps the students to complete their dissertation in professional way. It makes them get high grades in their dissertation presentation.
http://essaywriting-servicereviews.com/Forum-Dissertation-Writing-Services-Reviews-UK
Having problems removing Bosch built in double oven.
Usually the screws keeping the wall oven in its space are through the sides of the oven. With doors open look on both sides for screws that go into the cabinets
Feb 02, 2015 • Bosch Ovens
How do I clean the floor of my Bosch oven when Mr Muscle cleaner doesnt work?
I find oven pride the best one on the market, there is a box set which has a big bag to put shelves etc in to deep clean the parts etc, then the rest of the cleaner is for the internal areas of the oven...
I hope this helps, I have used a steam cleaner for really stubborn stains as well...
Bosch wall oven turns on when mcrowave is on
Contact Bosch website and ask customer services if they have had this problem before. It may be subject to recall if there is a fault. Also have a word with the installer. If there is any leakage of radiation it MUST be stopped.
MY 24 INCH BUILT IN SINGLE WALL OVEN DIGITAL TIMER
turn power off at main box the back on retry st set clock . if it won;t set / replace it . it has gone bad .mm
After doing a self clean, the panel now flashes locked
thermal protector has caused lockout. happens w/ self clean a lot. it's a small thermostat device most likely on the rear of the oven. oven need to be pulled from wall to check/replace. you may have to open door w/a coat hanger if it's locked to get the door open to allow access to screws to allow removal of oven from wall if it's a built in. unplug it before doing anything. fuse is under back cover size of a bottle cap, 2 wires, should be "closed" normally. replace or spray w/freon to "reset" it.
1helpful
Wall oven will not light
Remove the flame spreader panel to access the ignitor.
Place a clamp on amp meter on the ignitor wire and turn the oven on.
If you read less than 2.9 amps, replace the ignitor.
If you read 2.9 to 3.2 amps replace the gas safety valve.
Top Bosch Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
