Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Craftsman snow blade install instructions
I am trying to put on a snow blade on a 6 year old craftsman 42 inch deck. the blade is craftsman, just dont no how to hook it all up
can you send me instructions or a link?
thanks
Paul
  • 49 Answers
Go to sears.com and click on the PartsDirect link at the top. Enter the model number of the blade and you will see a parts diagram of blade. Hope this helps.
Posted on Feb 06, 2009
Got a craftsman mower 42 inch deck changed spindles and blades and deck still shakes belt may not be tightening up
did you put the blades on right ??? they have a star pattern and it needs to be lined up correctly... if that's ok does the belt have a bad spot in it or is the engagement mechanism operating correctly ???
Oct 20, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I need to installhow to install a new deflector on Craftsman mower model 917273130?
Very simple. The 6 inch or so pin that holds it on is retained by a clip on one end. To remove clip use a pair of pliers. If you work steadily and carefully you will be able to reuse this clip. After removing clip, pull the pin out. Old deflector and spring be removed now. To get the spring right you have to try it in position before installing it. Just remember that the spring is holding the deflector down so when you are done installing, when you pick up on the deflector there is pressure holding it down. Don't put the pin clip on until you verify the spring force is correct because getting that spring clip off is the Hardesty pay off the job.
Oct 11, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a 26 hp gt 5000 craftsman tractor modle 917-276081 what snow blades will fit
42 go to sears they have them also try ebay u may find 1 there i needed 1 for my sears ltx1000 went to ebay a bought a new 1 on auction for $175
Mar 05, 2013 | Craftsman 20 Hp 42" Deck Lawn Tractor
I put my snow blade on successfully, but the tractor does not start now! What to do?
Did it start before you installed snow blade? Did you remove mower deck? If you removed mower deck you probably had to unplug blade safety switch. This is a plug in deal, look underneath and see if it is hanging, there is probably a place on the snow attachment to plug into,or you can jump around it by plugging a wire into each hole. (please note I am assuming it ran good before you installed the snow attachment).Hope this helps.
Dec 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have 11 years old Murray (42 inch deck). After deck adjustment still leaves uncut portion of the grass between blades. Should I exchange the blades (I have not done it for many years, but I sharpened...
On a two blade deck, such as yours, there is generally an overlap between the cutting coverage of the blades so that you do not leave a mohawk. This does not work well on turns however, and the sharper the turn, the more grass is left. Overcoming that issue brings you up to a 3 blade deck. If your mower is leaving a strip of uncut grass while cutting in a straight line, somehow you are running blades for a smaller deck, thus there is no overlap. The mandrels are offset, one slightly in front of the other so that the blades do not hit each other. I would measure under the deck and see how long a blade could be and still fit within the deck and not strike the other blade, then ask a parts store to sell you something longer than what you have now.
Oct 20, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
My riding lawnmower blades will not disengage or engage Now my lawn mower will not start
just replaced some pulleys on my craftsman 42 inch cut and now the blades are ingages all the time, but it will start
Jul 17, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Got a 42" snow blade and no paperwork with it.
Ok that snow blade attachment was Made for Sears/Craftsman by AGRI- FAB. Go to thier website. Email them that you bought model number xxxxxxx and there were no instructions in the box. They will either tell you how to down load the instructions or send them too you. I have had the best luck with AGRI-FAB they like happy customers.
Oct 18, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
42 inch craftsman. Replaced bades and now have a row of uncut grass in the center of cut.
OOPS! I hate to tell you but you most likely put new blades on that were too short. Check your manual and get the proper length blades. If you still have the old ones, check them against the new ones and you will see that they are shorter resulting in the uncut grass in the center.
Jun 23, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
1,361 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
