Question about Whirlpool Duet GHW9150P Front Load Washer
Problem with whirlpool duet
I have a front load whirlpool duet washer and the tub has water in it and the door clicks close then it makes a humming noise turns one time it blinks f21 after a while
    President:
  • Whirlpool Master
  • 2,651 Answers
You can access the drain pump assy by removing the 3 screws across the bottom of front panel, after that youll see the drain pump directly in front of you, youll need to unscrew t he filter cap form the "button trap"assmebly, this is what catches all the junk left in pockets, or the baby socks, so they dont make itr into the puppmp itself. be warned there will be water wanting to come out after unscrewing the cap. ALOT depending on amount of water in machine!!!!!!
Posted on Dec 15, 2008
Duet front load washer control locked
Door will not open with water in the tub, unplug unit remove lower machine cover. You will now have access to the drain pump clean out, rotate cap and remove any items.
Oct 23, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Due to power outage can't get door open on Whirlpool Duet front loader washer. With wet towels inside, need to manually open door to get them out. Is there an easy solution?
On that type of washer the door lock is wired in series with the water level switch and if water remains in tub the door lock will not power up and unlock..what you can try is (if havent already done so) is select the drain/spin only cycle and when the water has drained the door should unlock
Aug 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool duet front load washer fills randomly with water when not in use and the door is open. Usually it only fills up to the door opening but this morning it was over flowing. ??????
check and make sure you do not have a siphoning problem. make sure the drain isn't backing up in the machine. This could also be a problem with the water inlet valve. Its possible that its not closing all the way when the machine is off. If its dirty water entering washer then the problem is siphoning from the drain. If its clean watet the valve is bad.
Feb 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What would cause the washer not to start the cycle after the door is closed or not spin the water out of the tub?
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
Courtesy jsrock516
Mar 26, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
The wash cycle clicks on and a small amount of water enters the drum, as normal, but then there is just a humming noise and the drum does not move. When I put it on the rinse and spin cycle (there is...
I removed the bottom panel under the door and drained the the tub. There is a white filter housing that unscrews, but you need to have towels handy to catch the water that comes out. The machine appeared to work after that but it would'nt drain and it turns out that the humming noise was coming from the drain pump connected to the filter. I ordered a new drain pump assembly, which should be easy to replace since it is located at the front of the washing machine.
Jan 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Our whirlpool duet sport front load washer is fairly new (2008) now it has started dripping water during the cycle under the front of the machine. any suggestions would be helpfull.thank you
check tub boot for any tears in lip that seals to door zippers etc. can tear this.also sometimes water can leak from pump cleanout.you would need to remove bottom panel to check this
Jan 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Duet Whirlpool Front Load washer on the spin cycle it make a clanking sound and is now dripping waster from the bottom of machine.
your pump is going bad.the water is leaking from pump or rubber door boot that connects to tub and wher door shuts,check for tear in boot.
Mar 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front load washer, Clicking noise during spin cycle
i would open the door nad with your hand (glove on if preferred), feel around the intereior of drom for prhaps a nails, or hair clip that has gotten caught in one of the many holes in tub
Dec 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
110 people viewed this question
Dan Webster
Dan Webster
Sal De
