Question about Intertherm P3RA-048K Air Conditioner
THE BLOWER ONMY PELLET SOTVE WILL NOT COME ON..ANY IDEAS? IT STARTS AND HEATS UP WELL BUT THEN THE BLOWER NEVER COMES ON..
  • Ken Bledsoe May 11, 2010
    Do you have a volt ohm meter?
    Problem Solver:
  • 14 Answers
Check the control wires going to the fan motor. probably a limit, wire off . you need an ohmmeter. to check with the power off when the hearer has reached a good warm temp
Posted on Jan 10, 2009
I have an Englander 25-EP pellet stove. The 6 am 125 volt fuse on the control board keeps blowing as soon as the exhaust blower comes on.
Try a 10 amp fuse, or a straight wire. The straight wire will cause a wisp of smoke that will reveal the problem.
Dec 17, 2017 | Cars & Trucks
Pellet stove smokes after blower stops
This should not be happening, have somebody check the draft for you, smoke should be drawn out chimney, unless draft is no good.
press the helpful button
Feb 11, 2016 | Pool & Spa
Hammering sound ptac
heat pump? possible causes: low freon. clogged / dirty coils. blower motor running?
Jan 20, 2014 | Heating & Cooling
I have a Quadra fire 1200 pellet stove insert. The convection blower does not stay on continuously. 2 min on 2 min off
It may be working properly. If it seems that it's a little cool in the room and the blower is cycling like you say then the stove may be getting chilled. If this is the case then the low-temp switch is cutting the blower off.
If the room is quite hot there may be a problem with the blower. Check to see if it has a bunch of dust in it making it run hot and tripping the internal thermostat.
Please respond with the 'comment' button, down below the ads. I'm considering a pellet stove and I'd like to hear anything you have to say about yours.
lp
Jan 11, 2011 | Napoleon Auburn Pellet Stove Heater
When furnce starts blower comes on exchaust then burnner light as it warms the main blower should come on but does not burnner shut down after high limits need to no why main blower fails on start up motor...
check the afc automatic fan control when heater heats up fan cuts in ,or cuts out if fan dose not start , check to see if back of afc is clean on dust or fluff in it
Aug 16, 2010 | Heating & Cooling
My Aveo starts up normally and slowly heats up to normal operating temp. But the cooling fan never turns on and eventually the temp guage climbs from the halfway mark to the top mark. I checked the fuses...
Most systems work this way: temp sensor on engine sends a signal to the computer which in turn sends signal to blower relay that then sends signal to the fan.
Any problem along the way, and the fan won't come on.
May 14, 2010 | Cars & Trucks
Weatherking furnace is starting and stopping
This just sounds like a couple of problems. First, your blower is designed to only turn on once the heat exchanger heats up, so the flame will be on for a minute or two before the blower starts. it sounds like your blower is cooling down the heat exchanger too fast and causing it to shut off so it can warm up again...check blower speed for heat, it should be the lowest speed (black wire). Blue=medium speed, red= high speed. second problem could be your flame sensor rod is calcified, you just need to locate this and clean it off with some fine sand paper.it is located in the flames near the burners. Also change your filters, for proper air flow through your heat exchanger.
Oct 28, 2009 | Heating & Cooling
Pellet stove
PRESS H THEN TROUBLE THEN START THEN HIGH 6 THEN LOW 1
THEN PRESS BLOWER & HIGH FOR 3 BEEPS
Sep 30, 2007 | Stoves Broan 40000 Series Hood - 36" Hood...
Intertherm P3RA-048K Air Conditioner Logo
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
