Question about Xerox Phaser 8500/DN Printer
Updating Xerox 8500N to 8500DN to get duplex printing
Hi !
Apparently on my Xerox 8500N, if I change the little configuration card for the one that came with a 8500DN, my printer will have duplex printing. Do I need to change/install anything else like the NVRAM chip as someone told me. I already increase memory from 128 to 512MB.
Thanks to give me the more information/instruction to help me get the duplex printing on my Xerox 8500N
Jan
  • jandube Jan 10, 2009
    I installed a 8500DN configuration card and redo the printer installation process with the Xerox CD and everything remains as before ie no automatic duplex printing. Still offering me the manual double side printing option and on my configuration page, it said Duplex Unit Not Installed ! How can I install the duplex unit ?
    Problem Solver:
  • 16 Answers
Finaly you found the card.if not msg me
Posted on Aug 06, 2009
  • 23 Answers
That is all you have to do is get a new configuation card and that will do it
Posted on Dec 23, 2008
I had a problem my color laserjet printer 8500dn that is asking to clean density sensor I don't no how to do it please help
Hi Elias, The link below is a user manual for a color laser jet 8500, 8500n, 8500dn, I had a look and the answer to your question (Clean density sensor) is on page 155 (To clean the density sensor
1 Open the upper right door.
2 Use the brush located next to the sensor to remove all toner particles from the sensor)..... This WILL Help...CHEERS..
http://h20566.www2.hp.com/hpsc/doc/public/display?docId=emr_na-c00656644
Mar 30, 2016 | Office Equipment & Supplies
Error code 02,011.61
The configuration card is for the wrong product.
1. Turn off the printer
2. Verify that the Configuration card is the correct type for the printer
(located at the rear of the printer.)
3. Insert or replace the card
4. Turn on the printer.
5. If the problem persists, replace the main electronics module.
May 28, 2010 | Xerox Phaser 8500N Printer
We have a Xerox Phaser 8500N printer. The yellow is printing out a dingy gold. I hav checked the yellow print blocks and there is plenty.
What it essentially boils down to is that you're not printing enough color. The blocks are melted into a holding bin and will discolor over time. To correct this, you will need to purge the color that is "stale". Go to this link http://www.solid-inks.co.uk/technical_support-phaser_850_860_8200.html?category_id=1 and download the pdf for your color (I would recommend downloading all four to keep on hand). You'll want to open the PDF and print 10 to 20 copies until the bad ink is replaced with fresh ink. You'll notice the color change as the ink is purged.
Jan 05, 2010 | Xerox Phaser 8500N Printer
How to set up printer to print double sided. Printer Xerox Phaser 8400
First look at your printer identification.
You can see it in either the display or on the startup or configuration pages.
It must have a "D" in the name for you to be able to do automatic duplexing. i.e. 8400DN or 8400DX . Then you can scroll to printer setup
and select defaults, and then turn on the duplex, or double sided printing.
If yours does not have a "D" i.e. 8400, 8400N then you would need a new sim card to enable the duplex option.
Oct 22, 2009 | Xerox Phaser 8400 Laser Printer
We have a phaser 8500dn error code 07,010,43:5027, please help
Hi
Your print head is not moving properly.
If the printer is not level, then ink seeps down the print head and get into the print head mechanism.
Check and clean this out.
May 07, 2009 | Xerox Phaser 8500DN Printer
Xerox 8500n with error 13323.47:23971
13,323 is a Printhead Reservoir Temperature Faults . One of 3 things. In order of likeliness.
1. Print head has failed
2. Cable to the back of the print head is loose.
3. Electronics module has failed..
What that code means is that once the ink melts and flowes into the print head, the print head is not maintaining the proper temperature.
Nov 13, 2008 | Xerox Phaser 8400 Laser Printer
Printer staus unavailable at this time
A couple things I would check that can cause this, all related to PC to Printer communication.
  1. Cable problem: Printing locally with a non-bidirectional printer cable from LPT1.
  2. Configuration Issue: Printing via IP and having designated in the device setup more trays then actually exist. For example, checking that you have a feeder when you have only the default tray.
  3. Resource Conflict: Printing via IP when another device is using the same IP.
  4. User Error: Having multiple copies of the same printer. i.e. 8500DN, and 8500DN(1) setting one up but having the other set as default.
Jul 24, 2008 | Xerox Phaser 8500/DN Printer
My 8500N prints reams of code instead of the jpg sent to print
First off and I am sure you have tried this, but power of then power up your printer. Just to allow it to reload the software internally.
The other thing is to change drivers. That is what is generating the code.
You can go to Xerox.com there is a varity of drivers to try. Sometimes a PS and PCL driver will intrepert differently and print code like that.
Not sure preview is where the problem is. But I am assuming it prints fine in other applications.
There is also a firmware update on the xerox.com site, you can upload the newest printer software there. Or at least start out with a clean version on your printers operating software.
I strongly suspect a driver change will help.
Mar 01, 2008 | Xerox Phaser 8500N Printer
Fiery x12
Have you gone into the driver properties and checked if the setting in the drive is defaulted to duplex?
Jan 17, 2008 | Xerox DocuColor 12 Printer
Phaser 8500N color problem
There is a process called TEKCOLOR correction.
It is on the xerox.com site.
Search for phaser 8500 under the support, in support in the search area enter.
Solutions for Colors are Off or Wrong
This will take you through the process in the correct steps to resolve your issue
Nov 07, 2007 | Xerox Phaser 8500N Printer
Xerox Phaser  8500/DN Printer Logo
853 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
iteminconline
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
