Question about GE 46GW947 46" Rear Projection Television
No sound on about half of the channels
Our problem is that there is no sound on about half of the channels and it shows the message on channel 8 that this is not the regular audio and to remove the sap we have checked out the manual as far as all the trouble shooting fo the audio, nothing works.
  • dave tefft Mar 16, 2007
    thank you your response,
    i have already gone through all of that and still nothing,
    what is strange, its only about half of the channels that dont have any sound,
    if there is any suggestions, please help
    thank you
    President:
  • 1,284 Answers
Press the menu button on the remote then select #1 AUDIO once in that screen select #3 AUDIO PROCESSOR thats where you will have the selection of MONO, STEREO or SAP.
Posted on Mar 16, 2007
  • Don
    Don Mar 17, 2007
    Is the TV connected to a cable box or sat. rcvr? If so then maybe thier settings are incorrect. If connected to a cable box, then temporarily bypass it and connect cable directly to the TV. Now try the channels that had no audio and see if it works. If it does then the cable box is the issue.
Logik recorder - error message - cannot schedule recording, there is already a timer at the same time on this channel. turned the box off at the wall & retuned. Any suggestions? Thank you. x
check programmed recordings you will have a clash possibly in time and date on another channel. If the dvd records two channels at once normally check if it has two channels already set up at the same time to record i the scheduled recordings.
you may have two different channel positions that are the same tv station and have set up two different channels to record the same show. and then you may be trying to record another different channel at the same time. check and delete extra channel schedule.
Another way to have this is as an example say programmed record at channel nine f0r show 1 at 7:30 to 8.35 day xyz and then you set up show 2 to record at channel nine say from 8:30 to 9.35.day xyz this will use two time frames during the overlap from 8:30 to 8:35 on day xyz and if you decide to record a third show you can't between the overlap time frame
Jun 25, 2016 | Televison & Video
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
Pt-50lc14 no sound on ch8, has sound on all others
The channel memorised on channel 8 is set to another AUDIO frequency or audio mode. You need to check the setting of the channel 7 to confirm and reset using the manual tuning to reset the audio mode.Since you have not mentioned the place of residence, say for instance PAL system has different audio modes.
Nov 29, 2011 | Panasonic Televison & Video
My son bought this TV and had it hooked up to a cable connection with an HDMI cable and it worked fine. He gave the TV to me and I hooked it up to a basic cable connection with no cable box. It does not...
If your TV has an On-screen Menu you should be able to access your Tuner controls. Run your auto channel scan and you should pick up your "regular channels". You may be able to de-select the odd channels and show only the ones you want to use.
Oct 03, 2011 | Westinghouse LTV32W6HD 32 in. LCD...
I have a cambridge audio Azure 540R. WAs all working fine. A red box with SW under the L speaker channel has appeared. No sound from the L speaker, Although the test sound through the L channel is ok. The...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/s/Cambridge-Audio-540R-Receivers-review-manual/id/2536dj197/t/1-2/
"SW" stands for SubWoofer.
Page 8...
Shows the currently active channels depending on decoding mode and source material. Icons lit indicate active channels in the source material. Icons with a box around them indicate actual channels being output separately.
Search for the word "balance". Page 8 again (circled 8)...
Lights when the Front Left and Right speaker outputs have been set to different levels in the OSD, i.e. a balance adjustment has been made.
You can look at the relative levels of all channels as described on Page 14.
Mar 22, 2011 | Cambridge Audio Azur 540R Receiver
I connected my HDMI cable to my television and have comcast for my provider. I get the HD Channels beautifully but when I go to a regular non HD channel, I get no sound at all, only the picture. How am...
You will need to used a red and white cable that will connect to the (audio out) on the comcast box and then to your (in audio) on your tv.
Thanks
wbigtodd
Jan 22, 2011 | Insignia Televison & Video
Son puissance max
800 watts per channel @ 4 ohm
400 watts per channel @ 8 ohm
400 watts per channel RMS @ 4 ohm
200 watts per channel RMS @ 8 ohm
Dec 13, 2010 | Gem Sound GemSound PA-2505 Car Audio...
What is the very best way to wire 3 sets of speaks and 2 subs through a 4 ch. amp and a 2 Ch. amp.?Thank you, Paul
Ummmm Im gonna give this a try-If it were me i would run the 4 channel ground pounder on the doors and rear panels -the front 2 channels run the component set exclusively at 2 ohms per channell and run the 8 inch 3 ways in parallel with the rear deck speakers for a combined load of 2 ohms per channel on the rear channells-naturally the 8 inchers and the 6.5's are going to be able to handle a little bit more bottom end than the component set so you can feed a little more midbass to those rear channels- I dont know the resistance of the coils on your subs or the model of the MA amp you are using but if you can throw 600 or 700 on your subs that should be sweet enough- hope its not a waste of your time or maybe you already tried it set up that way-good luck though
May 27, 2009 | Alphasonik (PMA640A) Car Audio Amplifier
Amp Power light will not go on. Protection light is lit- Thump sound in speakers
It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
Amplifier in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Oct 31, 2008 | Visonik Dual Bass Box with Amplifier Car...
GE 46GW947 46" Rear Projection Television Logo
65 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
