Question about Whirlpool Cabrio HE 4.5 cu. ft. Washer
I have a whirlpool ultra capacity dryer and a code keeps flashing when i;m drying it says AF
    President:
  • 373 Answers
The AF indicates an insufficient air flow.You need to check the lint screen after every load, AND you need to perform routine cleaning of the dryer venting (inside the dryer, as well as the vent line from the dryer to where it exits the house) about every three months. If left in this condition, the dryer heating circuitry will eventually failed and/or you could cause a fire hazard. An easy way to check to see if you have a clog somewhere is to remove the dryer vent hose from the back of the dryer. Run the dryer to see if you have air flow coming from the back of the unit. The air should be about 140 degrees F and forceful. Check to see if the error comes back. If everything runs fine, then you know the problem exists in the vent line between the dryer and where it exits the house. If you still have problems, you will need to unplug the dryer, remove the back panel and inspect the interior for clogs. At least you have a dryer that warns you when the air flow become restricted or blocked. Most dryers will continue to run until they overheat or fail. I hope this information is helpful. Post back with your comments and let me know.
Posted on Dec 14, 2008
MY WHIRLPOOL CABRIO DRYER IS BLOWING HOT AIR BUT CLOTHES ARNET DRYING. CLEANES THE VENTS FROM THE OUTSIDE AND THE AF SENSING CODE KEEPS FLASHINGS WHAT DO I DO? PLUS IM GOING CRAZY I HAVE FIVE KIDS......
This is an air flow issue. Take the hose off the back of the dryer and run it and see if the error goes away. If it does not, something is plugging the inside of the dryer airflow.
Aug 08, 2013 | Dryers
Dryer takes forever to dry even after i cleaned the vents out
don't forget the exhaust tube coming from the back of the dryer and leaving the building. those can get pretty restricted with lint. Another place to look is inside the cabinet for lint. Getting these cleaned regularly can prevent a fire.
Nov 20, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dryer not drying-the sceen has af flashing please help..whirlpool cabrio
An "AF" code means there is a low airflow condition and the clothes may not dry properly. To remedy this, check to make sure the lint screen is cleaned off and that there is no blockage in either the vent duct that runs from the dryer to the wall or the vent hood on the exterior of the house.
Thanks for using FixYa.
Sep 17, 2011 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
On the screen of my dryer where it tells me how long I have till the cloths are dry keeps flashing AF and it takes me all day to dry one load of cloths.
The AF stands for Low airflow condition. We had it too. Check the lint trap first as it is the easiest. Then check the dryer hose ductwork make sure its not crushed or blocked. You may need to clean the line from the outside too.
Dec 30, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
My Whirlpool Cabrio dryer takes forever to dry anything (3 hours for just a couple shirts!). There is a code AF flashing on the display window, but i have checked all the airflow issue places and nothing...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 31, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
I have a whirlpool cabrio dryer and it is showing AF on the display and it isn't drying. what could be the problem?
AF Error Code for the Whirlpool Cabrio Dryer is a Air Flow problem. Check your dryer vent and the outside exhast vent.
Jan 13, 2010 | Dryers
AF flashing on our Whirpool Cabrio Dryer.
Hi Terry,
AF flashes if a restricted airflow condition exists. Check to make sure the lint screen is clean, the door seal is in place and the vent is not
obstructed.
I suspect it's the vent connecting the dryer to the wall or the vent pipe in the wall to the outside. Without moving your dryer, look behind it to see if the flex duct is crushed or pinched. If it is, it's pinching off your air flow, too. Pull the dryer out straighten or replace the hose (you can get vent hose at Home Depot, Lowes or Ace Hardware) then slide the dryer back being careful to keep it about 8" from the wall (8" is the recommended distance from the back of the dryer to the wall, btw).
If the flex vent is NOT pinched off, then you should call a chimney sweep to come out and clean the vent pipe that's in the wall.
*Note---> If you want to test this diagnosis to verify it, just disconnect the flex hose from the wall and run a load of clothes. The error code should not reappear.
SG
Mar 27, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool cabrio dryer
af on your cabrio dryer means clean your air filter
Dec 14, 2008 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
Whirlpool Cabrio HE 4.5 cu. ft. Washer Logo
146 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
