Question about Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x
I don't know what oil type to use for a Tecumseh 8.0 hp engine
I recently bought a Troy-bilt snow thrower model 42010 and I want to change the oil since it has not been used for several years. I do not have the engine manual and don't know the required engine oil type. Also, is the gas that has been sitting in the gas tank still ok or do I need to drain it and if so how do I do that?
Thanks, John
  • Anonymous Jan 09, 2009
    I'm trying to help my neighbor change the oil on his Ariens 520 snow blower with a Tecumseh Snow King engine. He can't find his manual, so I need to know what type of oil to use, and where the drain plug is located.
  • 163 Answers
5W-30
Posted on Dec 16, 2008
Need to find correct spark plug for Troy-Bilt #42027 Snow Thrower.
Several engines were available, you need to look for the number on your current plug - easiest method.
otherwise, you will need to give the motor manufacturer and nameplate info (Tecumseh SnowKing 8HP?)
Nov 16, 2014 | Garden
Troy bilt repair manual
Check with the engine manufacturer if you have trouble with Troy built.
Aug 03, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Augur wont turn on troy bilt model 2410 snowblower,stall s out when i engage the augur
ICE OR HARD PACKED SNOW IN BLOWER HOUSING
warm up or pour hot water down chute to thaw out
Feb 13, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
How do I replace the primer on a troybilt storm 5024 snow thrower?
Heres a link to a video showing replacement of the most common primer bulbs on tecumseh small engines, keep in mind that there are a few different size of primer bulbs that look almost the same, so you would have to go by your engine model and go from there.
Feb 14, 2011 | Troy Bilt 5.5hp Self Propelled Mower
I want to change the oil on my Yard Machines snow thrower with a 10hp Tecumseh engine and can't find the engine manual. What kind and how much oil should I use? Thanks - Zelmo
Zelmo use 10w30 weight oil and just put in enough to reach the full mark. In an air cooled engine I highly recommend you use Full Synthetic oil. It performs much better than conventional oil in an air cooled engine. Change the oil once a year.
Dec 31, 2009 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Simplicity Sno Away Snow Thrower Briggs 6hp engine No Spark
Check engine oil.
Remove wire from low oil sensor and the start.
Replace low oil sensor.
Hope this tip help solve your problem.
r/David
Dec 28, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Oil blows out of tube
You either have a head gasket going bad or your piston rings are shot which causes air to go down into the crankcase building up pressure which exits through the breather tube.
Jan 31, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x Logo
2,835 people viewed this question
Top Tecumseh Tools & Hardware - Others Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ArcFlash
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
Are you a Tecumseh Tool and Hardware - Other Expert? Answer questions, earn points and help others
