Question about Whirlpool Washing Machines
The washing machine is working but it does not allow the water into the drum when you set it on a number. It is one of the american style washing machines. The machine serial no is CP1201250 and the model is 3RLSQ800JQ2 Thank you Claire c.dodman@virgin.net
    President:
  • 373 Answers
It is a problem with the water inlet valve.Check it for blockage.for more information related to any other problem related to this, check out this link
http://www.acmehowto.com/howto/appliance/washer/diagwasher.php
hope this information is helpful.Pay back with comment.will look forward to answer your future posts.
Posted on Dec 14, 2008
I have a 6.5L LG turbo drum washing machine. The cold water is coming out of the tap but dripping slowly through he machine? What do you suggest to do? The call out fee is $100 and $20 per 10mis ...
The water solenoid valve may have gone bad and is allowing water to enter. Turn off the cold water shut off valve at the wall to immediately stop any water from flowing. What is your machines model number?
Jan 15, 2015 | LG Washing Machines
On the cleaning cycle of my washing machine, the hot water does not en the drum. It is almost as if a valve does not open to allow the water in.
sounds like a hot valve fault. call a local repair person, have your make and model number ready when you call.
Dec 02, 2014 | Washing Machines
Kenmore water keep running will not wash
On many washing machines, there is a water level setting switch. This allow you to adjust the level in the machine to converse water. This switch works on air pressure. There is a small hose inside the outer drum at the bottom of the washer. It is connected to the pressure switch (level setting switch). As the washer fills, the weight of the water compresses the air in the hose until the pressure switch activates. There are two possible failure scenarios; they are both fairly easy to repair. First, the hose could be blocked at the drum entry point by lint or debris. This is a somewhat common occurrence. To check this, unplug the washer. Remove the rear cover from the control panel to access the rear of the switches. Find the rubber hose attached to the level switch and remove it. Blow through the hose to clear it. Reattach the hose and retest the machine. If that doesn't work, you may need to replace the water level switch, It is easily remove and replaced once you have accessed the rear of the unit. You can calls Sears service with the model and serial number of the machine and get replacement parts sent directly to your home.
Jan 01, 2012 | Kenmore Washing Machines
The washer fills slowly with water when not in use. It drains without any problem when drain/spin cycle is used.
Most likely the water inlet valves on your washing machine have failed. You may have noticed larger amounts of water in the clothes drum when the washing machine hasn't been used for a few days, this is because the valves may still be open allowing water to drip into the clothes drum.
Here is a link to the part that you need to buy: http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Washer-water-inlet-valve--universal-item-number-AP3098982.aspx.
And a link to a video showing you how to replace the part: http://www.ultimatehandyman.org/video/appliance_repair/water-inlet-valve.php
Hope this helps!
Feb 28, 2011 | Whirlpool GHW9400 Duet Washer
Black type residue being left on clothes
This is a common problem on washing machines, if you predominantly do cold washes.
Over a period of time, a washing machine will accumulate a buildup of Soap Scum (excess soap & softener residue) which can stick to the inside of the drum.
This black coloured soap scum occasionally breaks away from the drum, and attaches to the clothing fabric during the wash cycle.
You can rectify this, by doing the following:
Firstly, purchase a packet of CITRIC ACID from your local grocery store (usually found in the baking isle).
Do the following procedure before going to bed:
1) Do a HOT WASH without clothes (Hi water level, with HOT water) - allow machine to fill with hot water, then add the CITRIC ACID to the water. Allow the machine to complete a FULL wash cycle (i.e. allow machine to agitate for 30 mins or so, then drain).
2) Fill the machine again with the HOT water / CITRIC ACID solution, but this time allow it to sit in the bowl overnight (no cycle).
3) Next morning, set machine to spin & drain (i.e. to empty the solution)
4) Set machine to fill with FRESH HOT WATER ONLY (no citric acid), then set machine to spin & drain. This will flush all remaining residue left in the bowl.
Note: Soap scum residue is caused by using excess detergent/fabric softener. Hot Water flushing should be done every 6 months.
Contrary to what the detergent manufacturers state, you should follow Samsung's instructions by using HALF the recommended detergent.
Samsung machines prefer LOW SUDS, and you may find by reducing the amount of detergent used, you may even eliminate the buildup of soap scum.
"If this has helped resolve your issue, please rate this solution"
Oct 31, 2009 | Samsung SW62ASP Top Load Washer
I have a Samsung SW62ASP top load washing machine. I keep getting chunks of black flaky stuff turning up through my wash. I always empty the in bowl filter, is there another filter?
Aug 05, 2009 | Samsung SW62ASP Top Load Washer
Washing machine not heating water
yes it will work but unless you have hot water going into the machine there will never be hot water there but you can just use it with cold water will not hurt anything just no hot water
Mar 09, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
WMA54 Hotpoint Aquarius drum does not turn during wash or spin
If the machine pumps water inside but does not start :
Start checking the lid switch, if this is stuck the machine wont start.
If the drum does not move at all, the motor, the motor control unit, the motor coupler, the control board may be faulty.
For more details , see: It doesn't spin
See also a general diagram here: redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Jan 06, 2009 | Hotpoint WMA30 Front Load Washer
Indesit we 16 will only turn anticlockwise!
00023398.gif small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
transparent1.gif Find a part for your Washing Machine godark_3.gif How Washing Machines work godark_3.gif What is wrong with your Washing Machine? godark_3.gif Email the RepairGuru for help with your specific problem godark_3.gif Maintenance tips for your Washing Machine godark_3.gif Answers to common questions about Washing Machines (FAQ) godark_3.gif Locate your Washing Machine model number godark_3.gif Accessories for Washing Machines godark_3.gif Appliance Recall Information godark_3.gif RepairClinic.com is the web's best resource to buy parts for your Washing Machine and get free Washing Machine repair advice for all major brands of Washing Machines including Admiral, Amana, Asko, Bosch, Crosley, Electrolux, Estate, Frigidaire, GE, Gibson, Hotpoint, JC Penney, Jenn Air, Kelvinator, Kenmore, Kitchen Aid, Magic Chef, Maytag, Modern Maid, Norge, RCA, Roper, Sanyo, Speed Queen, Tappan, Westinghouse, Whirlpool, White-Westinghouse, and more.
Jun 29, 2008 | GE WSM2700D Top Load Stacked Washer /...
Washing Machines Logo
23 people viewed this question
Dan Webster
Dan Webster
Sal De
