Question about Proscan PS52650 52" Rear Projection Television
Powering off and on
I have a PROSCAN Model PS52650, Chassis PTK188AB, Service NO P552690LX1. We had the transformer burn up and had it replaced. $161.00 Now the TV is cutting off and on all the time. The transformer used was not an original but aftermarket. It stays on for 6 mins before it starts up. Sometimes it goes another 30 before shutting off. I have the back off and a fan blowing on it and it doesn't help. Everyone says it will cost at least $400 to fix it and we should just throw it away and get a new one. Problem being I can't get a 48 in TV for $400 or $500. Any suggestions on what I can do(not a repairman). I am a Certified Microsoft Technician for computers so I know a little about electronics but not TVS
  • 38 Answers
Reheat the board.....this could happen that the tv board will get heat after a few minutes then the loosen suspected part will totaly open.
Posted on Mar 17, 2007
  • Rele Isales
    Rele Isales Oct 04, 2008
    theres could be a leaky capacitor on your power supply section. i suspected the secondary section.
    good luck!
We have lost the power cord to plug into our Proscan TV model: PS52652 chassis: PTK169PDBS. where can we find a cord to purchase?
Check with techs that repair these sets or any tech. If they cant find the right power cord they can allways take the power cord from another name brand set and wire it in.
Aug 05, 2010 | Proscan PS52650 52" Rear Projection...
My tv. proscan mod. ps50700 won`t turn on
The PS50700 uses the 195 series chassis. The most common cause of the set not starting up is a shorted flyback (high voltage) transformer. Sometimes a shorted flyback will also cause the horizontal output transistor to short too. These parts need to be tested and/or replaced by a tech familiar with the RCA 195 chassis.
Aug 17, 2007 | Proscan PS65000 65" Rear Projection...
Proscan big screen no power will not start up
If you hear it trying to start up (usualy you'll hear a slight hiss about 3times) than the problem is likely the High Voltage block - a very common fault with these sets- The block costs between $40-$100 and because Highvoltage is present should be replaced by an experienced technician. If you decide to do yourself let me know.
Sep 26, 2009 | Proscan PS52650 52" Rear Projection...
No power.its plugged into the outlet and it works. red power buttom not on tv
HELLO. it sounds like it could be a couple of things why your set will not come on. 1. you could have a blown fuse.on the chassis. 2. you could have a bad power supplly transformer. 3. you could have a bad horizontal output transistor and a bad fly back transformer. it could be one of them or both of them as well as a blown fuse. because the fuse is blown from the horizontal output transistor burning out or the fly back transformer burning up. check and see if you have a burnt fuse, the size iof the fuse will be 5 amp to 6.3 amp fuse on the chassis right inside where the 110 ac cord comes in and hooks to the chassis. the fuse should be right there, look for it. hope this helps you"GOOD LUCK"
Aug 09, 2008 | Televison & Video
Proscan 52"
unfortunatly I dont have a link for your model, however I will continue to search for one, and will send a response if I can locate one
Jun 19, 2008 | Televison & Video
Service manual for Proscan PS52690
I believe your model is a PTK188 can you look for the chassis number off the tag on the back, and I may be able to help you locate a manual, but the older RCA / Proscan / GE need the chassis number
Jun 14, 2008 | Televison & Video
I need a part # for a flyback transformer for an rca proscan model # ps61700
Your model has the CTC195 chassis which has flyback number 239111 you can get a replacement at the following link for 13.99. hope this helps here is the link.
http://www.electronix.com/catalog/product_info.php/products_id/13075
Feb 10, 2008 | Televison & Video
No power
Probable IHVT aka flyback xformer.Also,check Horiz output
transistor.Please provide service number (three characters longer
than model number) & chassis # then I can give you part numbers.T.
Oct 12, 2007 | Proscan PS50700 50" Rear Projection...
Proscan 50" rear projection TV model S50-700
the life expectancy of a tv is 6yrs depends on how you take care of your tv.it can go for a long time.
Apr 18, 2007 | Proscan PS50700 50" Rear Projection...
Turns on and off !
If you have no electronic experience and do not know how to troubleshoot electronics, then yes pleaqse call in a pro to assist you with this repair.. It hard to tell whats wrong with a set that is in a dead condition. It could run you anywhere from 50 bucks all the way up to 1200 depending on if a main board has to be replaced. Good Luck
Jul 28, 2006 | Proscan PS52650 52" Rear Projection...
Televison & Video Logo
122 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
