Question about Sony Xplod XM-1652Z Car Audio Amplifier
My protection light comes on when i turn up my bass controller an cuts off the sound to the subs how do i stop this so i can turn my subs up
Check ur ground wire and also ur remote wire.
Posted on Dec 16, 2008
My infinity reference 7540a amp cuts in and out with heavy bass when the ''loud'' feature is on. I redid my ground, remote wire, shortened my power cable, and double checked all speaker connections. I dont...
sounds like ur gains are set to high and is going into protect mode
also what ive seen happen before is the speakers (if mounted in metal shelf or door and arnt bolted down correctly can flex under bass notes and flex the speaker that much the termanls short onto the metal and amp hits protect mode
(rare but worth a look if you think u have elimanted most other things Had a dude come to me when i was working in sydney with this problem )
also could be things like clipping protection , overheat protection ,amp drawing to much current from the alternator
do your lights dim when you hit the bass notes ?
get back to me and im sure we could solve this problem
Jan 22, 2010 | Infinity Reference 7541a Car Audio...
My red protection light comes on and the amp stops if i turn up the volume on the head unit more than just a little. the settings on the amp are not more than half way up. all other lights are working....
sounds like you need a farat cap, your drawing more power than your cars gerating system and put out....does your stereo dim when the bass hits?
Oct 20, 2009 | Sony Car Audio & Video
Speakers cut off when bass goes up
probably the amp going to safe or protect mode judging by the fact that you have 3 subs wired to it i would say it is not 1 ohm stable try disconnecting 1 sub and see if it still happens this will be running a 2 ohm load rather than 1 if it stops happening then you need to figure out a better wiring configuration that will work with your amp.
Jul 03, 2009 | Kicker ZX400.1 Car Audio Amplifier
Sub keeps loosin bass
Its probably not your subwoofer- its likely that your amp is showing its age after 2 years of bumping -But it could be that you have partially roasted the coil on the sub which is tripping your amp into protect mode-thus shutting down throw a different sub in there for a week and listen to it and if it stops acting up then its probably the sub if it still shuts down then it may be time for a new amp
May 29, 2009 | Fusion FEW12PK Car Subwoofer
Jbl sub power dumb blonde needs help!
sound like something shorted out or is shorting it out sounds like its in protect mode.-z
Feb 20, 2009 | JBL BassPro Car Subwoofer
Protect light flashing on and off, sub cuts in and out
there is a wire crossed somewhere in the system or the sub is damaged how old is the amp
Dec 01, 2008 | PPI DCX-600.4 Car Audio Amplifier
Phntom bass sounds
uhhh....try you change your wire setup
Sep 17, 2008 | Infinity BASSLINK Car Subwoofer
Protection light
You cannot parallel two subs AND run them on the Bridge. You must have at LEAST a 4 ohm load on the bridge, and 2 4 ohm subs in parallel equals TWO OHMS. BAD!!! Move each sub to it's own channel or your amp will soon fry.
Sep 10, 2007 | Sony XM-2002GTR Car Audio Amplifier
Protect light
Set your Filter Switch to LPF.  Turn the Bass Gain/ level all the way down temporarily. Set your Crossover to below 100HZ.  Then Turn on the system with a Bass test sound.  Turn up your bass Gain/level until you get distortion.  Then turn it back till you just get the distortion out. Then do not warn everyone that you will De-nad them if they touch your settings.
Oct 23, 2006 | Jensen JXP680 Car Audio Amplifier
Sony Xplod XM-1652Z Car Audio Amplifier Logo
111 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
