Question about NexxTech Portable Hi-Speed USB 2.0 Kit Hard Drive
Nexxtech case doesn't open?
Having trouble opening nexxtech (nx2 case
2 Suggested Answers
Sheikhtijani
  • 1284 Answers
SOURCE: Not a problem, but question?? A Nexxtech NX2 was
Nexxtech NX2 is an external USB 2.0 hard drive which has a fast transfer speed. It posses no threat to you or your computer and all your privacy/passwords are safe.
Posted on Jan 14, 2010
Lost the CD for NexxTech External Hard Drive Enclosure
Try the following
Is your external HD (Seagate + Enclosure) being seen by your computers USB system ? When you connect it, is there any action at the bottom right of your screen ? Any messages saying 'New hardware found' ?
If you get this, or even if you don't, try My Computer > right click > management. Click on Disk Management in the new window that opens. The window will change or a new one will open (I can't remember). You might see, in addition to your internal (system) HD, an your floppy, an you CD/DVD, another disk which is marked a unallocated or uninitialized. Right click on that [Do not select you system disk or any disk which may contain data by mistake] ; a menu should come down which may have the choice 'New Partition' which brings up a windows Wizard, Go through that, selecting the defaults if uncertain, ending with clicking on finish. Your disk should now begin formatting - it may take some time depending on how big your disk is. Do not select your system disk by accident. When this is finished your disk will show up in Windows File Explorer. This is the outline for Windows XP, but I think other versions od Windows offer a similar facility.
If this fails, try a different jumper select on your (Seagate) disk; I do not know what the correct jumper setting is.
22.April.2014
Mar 10, 2014 | Computers & Internet
My Nikon Capture NX2 has stopped working, tried to open it last night and Windows said it has stopping working and will close the program, nothing new to computer just stopped working. I have...
Does your PC recognise the fact that you've connected your camera?
Try uninstalling Capture NX2 and then reinstalling, if you still have the Installation CDs.
Jan 12, 2018 | Nikon Capture NX 2 Full Version for PC,...
Jan 14, 2010 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Nikon Capture NX will not open black and white jpegs
Nikon Capture when initially installed you have to tell it what types of files to open.... IT has 3 tick boxes for NEF (Nikon Raw Files), TIFF, & JPEg, you actually have to tell it which types you want NX to open. The easiest way to fix the problem maybe to reinstall the program and reset the file association as you install it. Hope this may  help.
Jul 26, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Usb 2.0
If you connect a device like this that is running in USB 2.0 to a computer or device that only supportrs USB 1.0 the speeds there will be just the USB 1.0 , because it will depend to the USB port that its connected to.. that's why its advisable that if you have a device that runs in USB 2.0 better connect it to a device also that supports 2.0 so you can get the 2.0 speed..
Hope that helps.......
Sep 06, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Red Light/Blue Light I/O Error
My nx2 is working again after having the "red light/blue light/I/O Error" problem. I just:
1. turned off my computer
2.unplugged the HD,
3. took out the HD from the enclosure and plugged it back into the enclosure,
4.started up my computer without the HD being plugged in
5. after my computer had been on for a minute, I plugged the HD in and my computer recognized it and had the proper mixture of red and blue light coming from the HD, indicating it's working properly.
Aug 26, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Nexxtech headset
I am not interested in a  "plan"  I just wanted to know how to open the casing of the mic switch on a  "Nexxtech" headset.  I found out how  and I now have it fixed.
I did not expect to have to wait a day for an answere.
Thank you
Ebern70
Feb 27, 2008 | Radio Communications
NexxTech DP3222 DVD Player
Open tray, press on the remote, stop-2-3-7-9, press arrow down until 0 and press ok.
Make shure you put TV TYPE --> ntsc in the general setting
I tried this (on a multisystem set that can be "made to think" that it's a PAL or NTSC set as the case may be) and it worked. The Nexxtech DP3222 and the Entiveo DP3220 are basically the same unit except that (a) the hack for the Nexxtech doesn't require resetting every time you turn the unit on and off, unlike the Entiveo (this is really annoying) and (b) you can set the Nexxtech to multisystem, NTSC, or PAL standards, whereas the Entiveo is NTSC-only, but (c) the fast-forward on the Nexxtech is somewhat less intuitive than on the Entiveo (involves holding a button down). All in all, I prefer the Nexxtech, if only because it is more easily hackable. And I would have sworn that the Nexxtech had a blue screen saver on it before I started hacking it, because now it has a really gross-looking black-and-white screen saver. But I don't care about screen savers as long as the unit does what I want it to do.
Jan 28, 2008 | NexxTech DP3222 DVD Player
Music format
It's .wav format. However if you burn your MP3s as an audio disc (not an MP3 disc) with a program like Nero or Roxio Easy DVD Suite, then it will automatically convert them to .wav and burn them to CD and it will work with your CD player straight off.
Sep 07, 2007 | Audio Players & Recorders
NexxTech Portable Hi-Speed USB 2.0 Kit Hard Drive Logo
146 people viewed this question
Top NexxTech Computers & Internet Experts
Alun Cox
Joe Goldman
Joe Goldman
Prashant M
Prashant M
Are you a NexxTech Computer and Internet Expert? Answer questions, earn points and help others
