Question about Hampton Bay 24002 Ceiling Fan
Ceiling fan and lights did not work
Not the electric braker
    Problem Solver:
  • 9 Answers
Loose wire at the ceiling connection.Turn power off and pull a little at the colored wires.Light kit not plugged in,bad socket or pull chain.Burnt bulb.
Posted on Jan 02, 2009
I want to replace a ceiling light fixture with a ceiling fan/light combo. the existing fixture is about 32 inches from a wall. what size fan can I put there?
I have replaced a couple ceiling light fixtures with ceiling fan/light combos in bedrooms where the light was basically in the center of the room. This was fairly straight forward and for me required replacing the electrical box that the light fixture was using with a heavier duty fan mounting box which you should make sure you use (that way the fan/light combo won't fall on your head later on -- literally). As far as the size of fan you can put there depends on whether the fan mounting electrical box can be mounted in the "exact" position of your original ceiling light fixture. I say this because the new box MUST be anchored to the ceiling joist structure in some way as a ceiling fan (usually) weighs more than a light fixture and tends to vibrate lending to more stress on the electrical box it's mounted to. Have someone who is an electrician or at the very least has a clear understanding of the importance of proper electrical work do the work or at least clearly explain what you need in your specific situation.
It is generally accepted that you should have at least 18" of space between a wall and the tip of your fan blade. In order to do this with the 32" figure you gave, ideally you should have a (32" - 18") x 2 = 28" fan. A fan in the 28" to 30" range is probably about as big as you should go in this area. You could technically place a 60" fan in that location and leave only about 2" of space between the fan blade and the wall, but that's asking for trouble and should NOT be done in my opinion. The smaller the fan, the less air you will be able to move, therefore you need to balance size, air flow requirements, and the restrictions of your particular location with what you can put there.
Do a quick internet search on "what size ceiling fan do I need" for more information on this topic.
May 26, 2014 | Computers & Internet
Installed a Casa Vieja Habitat Ceiling Fan today, the light works but the ceiling fan does not. Please help solve this problem! Thanks!
Check main line electrical wiring connection where it is connected and the switch electrical connection of the ceiling fun.
May 29, 2011 | Casa Vieja Habitat 44" Brushed Nickel...
Hunter fan model 25706 both the lights & fan have stopped working
mcdevito75 here, VeryGood question, very good, here we go, ------ First a re-set for the motor, I really don"t know but if there is it"s on the motor itself, you"d have to un-screw the cover just at the ceiling and let this cover slide down the chain Attached from the ceiling to the fan itself. and check the motor itself for a reset swtch, usually a red bitton. Now!! true, if the fan motor is bad it could affect the lights, here"s how, the wall switch supplies electricity to the fan motor and the pull chain on the motor turns the fan on, from the motor itself to the fan lights another wire also from the fan motor goes to the fan lights, SO!! if the fan motor is no good it won"t allow electricity to go on to the fan lights. Maybe you Fan motor is just stuck, specially if you haven"t used it in a whlie, with the wall swiotch on and fan speed on low try to gently move the fan blades them selves. If not you may have to repalace the fan.
Jul 18, 2010 | Hunter Ceiling Fan Light Switch Control
Turned on light switch and there was a click from the unit and neither the light nor fan work now
Either there is a bad connection in the fan/light or the circuit braker tripped...there is no fuses or circuit breakers in the unit...
Pull the fan apart and check for power there and if there is non then check the circuit breaker..
heatman101
May 21, 2010 | Broan-NuTone (8663RP) Ceiling Fan
I am having a problem adding a hunter 28550 light to my existing hunter ceiling fan. The fan works fine but I can not get the light to work.
It's possible whoever installed the fan originally, did not connect the black/white striped wire to the electric box. Drop the ceiling canopy and let me know what you find.
Mar 31, 2010 | Hunter Ceiling Fan Control Switch
Hunter ceiling fan type 3 not responding to remote
Sounds like the black wire from the fan is not properly connect(lose)
Here is an example wiring diagram
Mar 15, 2009 | Hunter Low Profile III 20807 Ceiling Fan
Electrical box not working
unfortunately it sounds like the main electic wire is shorted out. Not the one to your fan, but the one that provides the power supply FOR the fan. The only way i know to fix this is to get an electrician. I am certain the wire needs replacing.
Nov 29, 2008 | Hunter 52" Ceiling Fan With Light And...
Hampton bay model 55295 fan works, light doesn't
Did someone give you advice on this? My fan is doing the same thing. Fan works fine, but the light does not. Looks like the electricity is not making it down to the ballast - trying to figure out how I can repair it.
May 27, 2008 | Hampton Bay (261025) Dual Mount Ceiling...
Hampton Bay ceiling fan
You have a dangerous electrical situation call an electritian to test the wiring.
Oct 20, 2006 | Hampton Bay 04379 Madison Avenue Ceiling...
Hampton Bay 24002 Ceiling Fan Logo
104 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
