Question about Reiker Room Conditioner Ceiling Fan with Heater RRC12001
Reiker room conditioner
Our heater quit working on our reiker ceiling fan room conditioner
  • Anonymous Jan 25, 2009
    Same Problem Here
Reiker Corporation distribution fan motor is the largest and best available in the ceiling fan industry and carries a lifetime warranty.
Posted on Jan 17, 2009
2 Suggested Answers
SOURCE: reiker room conditioner
called reiker, and they sent me a new thermostat for the fan. installed it and problem solved
Posted on Feb 02, 2009
Ceiling fan blades
Call the manufacture of the fan.
Aug 18, 2014 | Reiker Room Conditioner Ceiling Fan -...
Heating element for reiker room conditioner chalet ancient bronze model
I would look for a bad thermostat on or near the heating element. If your not sure with electrical work, it might be best to replace the whole thing. Most cieling fans cost less to replace than repair.
Dec 13, 2013 | Reiker Room Conditioner Chalet Ancient...
Reiker ceiling fan - does not turn on - theres is power to unit - maybe remmote is bad? how do i change code
Before trying to change the code, have you tried changing the batteries? Both in the hand held remote and the one in fan housing? If so, and that didn't help, make sure the batteries are turned in the right direction and fitting tightly.
Will the fan operate without using the remote control?
Feb 19, 2011 | Reiker Room Conditioner Heater
The room conditioner is noisier now than when I got it. When I looked at it, it seems that it might need cleaning. How do I do that?
I would start out by wiping down them damp sponging the fan blades top and bottom. If you have a air copressor and don't mind a mess you can use low pressure air to blow thru all the cooling ports on the motor.This is the way I clean ours but it doesn't make my wife very happy. You can also shut off power and disassemble to the point you are comfortable with then brush and vacumn.
I have found that the ones that I have taken completely down,while it does make them easier to clean they have all had sealed bearing motors so not able to lube.Hope this helps you. Thanks.
Feb 04, 2011 | Reiker Room Conditioner Ceiling Fan with...
Light flashes, clicking noise, fan does not turn
it sounds like the motor has a weak start winding or if the unit has a start capasitor it is bad
Feb 05, 2010 | Reiker Room Conditioner Ceiling Fan with...
Jan 27, 2009 | Reiker Room Conditioner Ceiling Fan with...
Reiker ''room conditioner'' heater stopped working
i have of course the same problem......5 times now in 3 years.
i have discovered that for some reason if i disconnect the fan and put it back up it works again for another 8 months or so.
Nov 16, 2008 | Reiker Room Conditioner Ceiling Fan with...
Fan and light no longer turn on
possibly the thermal overload sensor failed internally? as indicated in the instructions there is a overload sensor and thay will typically fail in others appliances.
Oct 30, 2008 | Reiker RRC120004 Brushed Steel Ceiling Fan
Reiker Room Conditioner Ceiling Fan with Heater RRC12001 Logo
406 people viewed this question
Top Reiker Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Reiker Heating and Cooling Expert? Answer questions, earn points and help others
