Question about Zenith B19A02D 19" TV
Prima TV Model Q2016 comes on when plugged in.
I have a Prima TV model Q2016. As soon as it's plugged in, the horizontal circuit fires up, but the set has no video or sound. The TV can't be turned off using the power button. If I press menu I get no response. If I press either TV/Video, or any of the channel up/dn or Vol. up/dn buttons the set will turn off, and cannot be turned back on. If I unplug, and plug the set back in, it's the same thing all over again. Could it be the EEPROM, Micro IC, or both?? I've checked the power circuits. Voltages all seem to be present..
Thanks.
Steve.
The prima tV that co on as soon it is pluged in 90% of the time the Micro IC causes that proplem you need to replase the micro
Posted on Jul 12, 2012
3 Suggested Answers
  • 13 Answers
SOURCE: AV input selection without a remote
Depending on the model of the tv, you could scroll ch dn past ch 2 and you should cycle through your inputs. if that doesn't work try holding down the two vol buttons on the tv. that could access the menu for the tv
Posted on Jan 24, 2009
brownline45
  • 310 Answers
SOURCE: prima model number cv1311 will not power up
good day. there are some parts to be tested. just resolder all pins of jungle ic. make sure that the board has no loose connection, try to check them all. then try to on your tv.
Posted on Jun 21, 2010
My tv/ dvd player has appeared with a green line down the screen
There are two problems occurs on your TV, one is the line down the screen because of faulty horizontal deflection or faulty horizontal yoke winding. 2nd is...color of the screen are not balanced, check the RGB transistors in CRT board circuit.
Aug 05, 2014 | Prima Televison & Video
Where is Earphone area on Prima model cv2011 tv/dvd set
I'm sorry to say but this model of TV doesn't not have any headphone jacks.
May 02, 2008 | Prima CV2011 TV
Our 2 year old Prima TV quit working. The power comes on, then as soon as picture tries to come on, the TV goes off. Called a repair man and is one of the parts for power, but Prima has gone out of...
gerneric should be able to be used as i had to work on a customers old prima and used some generic parts. ill try and find the link for you for the parts
May 14, 2011 | Prima CV2011 TV
Prima model number cv1311 will not power up
Jun 21, 2010 | Prima CV1311 TV
My prima tv suddenly says
You took the TV out of the mode for either satellite or cable and it need to be reset . check the user manual for the setting.
You didn't give model number for the unit/ I may be able to get you the instruction for you to reprogram the tv.
Apr 23, 2010 | Prima C2012 TV
Prima lcd tv, model number LC27R25 wont turn on
Most likely there is a problem in the power supply. Sets these days are so full of safety circuits that most any problem will cause one to not come on. Hard to say. Thanks
Oct 21, 2009 | Televison & Video
Sony Wega FD Triniton KD27FS170 Does not Start-
The most common fault with this model is the flyback transformer assembly is defective. Along with this, the horizontal output transistor may have also failed. In some cases this failure occurs because there is a drive problem coming from the horizontal scan driver circuit that is ahead of the horizontal output circuits. There may also be some support components that triggered the fault in the first place and would also be required to be replaced. When there is this type of failure, it is possible that the power supply may also need some service.
On more rare occasions, there may be a simple failure from the main power supply buss, or a failure in some other circuit that is putting the power supply in to protect mode.
An experienced TV tech who knows your model of Sony set can troubleshoot it and determine the exact failures. He can then give you an estimate.
This model of CRT set was considered to be an excellent TV set. Unfortunately when the full digital service is established as the standard, and the analog service is discontinued, you will require a digital to analog conversion box for this set to work with TV stations. Some cable TV and satellite TV companies will be supplying the analog signal in their standard package.
Jerry G.
Oct 10, 2009 | Sony Televison & Video
Bottom of screen flickers, and eventually the screen 'freezes'
they have problem lines in tv screen harizontall lines how i can fixed in HDTV prima 29inch.2008 model .give me ANSWER .
Jan 17, 2009 | Prima CV2011 TV
Philips/magnavox 20 in tv
check the horizontal output transistor or the vertical IC,maybe one of them is defected .
Oct 30, 2008 | Philips Magnavox 27MS343S 27" TV
I have a HT3061P Prima TV. The screen is gray color with horizontal lines,the audo is very good.
check the RGB supply it is 180volts or the capacitor value 10/250volts (4.7/250v, 2.2/250v)
Oct 16, 2008 | Prima CV2011 TV
Zenith B19A02D 19" TV Logo
205 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
