Question about Air Tools & Compressors
Nail gun will not shoot
My paslode framing nailer will not work on my compressor at home i have 120psi on it. pull the trigger and air blows out of the trigger. took the nailer to work same psi nailer works fine whats going on everthing else works on my compressor?please help thanks scott
  • Winterlude Dec 15, 2008
    this has nothing to do with the compressor. I have the exact same problem with my new dewalt frame nailer. After working for an hour with it it wouldnt fire, but air would rush out the trigger when I would try to fire. I took it back to the shop and they said Dewalt uses a grease that's too thick and tends to cause the nozzle to jam. He took it and fixed it, said he changed the grease for oil. Worked great, after using it for an hour again, the same thing is happening. I'm going back tomorrow.
    Point of interest. Both times I worked outside with it with below freezing temps. Both times I used it for over an hour outside. Both times it only stopped working the next time I went to use it the next day, after sitting inside.
  • timmer59 Mar 11, 2009
    My porter cable nailer will not shoot nails. The pin strikes the board and leaves an indentation but no nail.
    President:
  • 1,388 Answers
Not all 120psi air supplies are the same. Here are some differences. The pressure regulator has a great deal of effect on the performance of the air tool. Regulators are sold by the volume of air (cfm)that they can handle. The more cfm the larger the pipe fittings on the regulator. A 1/4 fitting regulator will restrict the air somewhat compared to a 3/8. Another difference is weather moisture is present in the air. Moisture will temporarily help seal the orings, however too much water in gun will cut the orings. The air hose and fittings will also stifle performance. Long small diameter hose will lower pressure at the gun. This can be measured by installing a guage on a T fitting on the end of the hose and watch the pressure as you fire the gun. Larger fittings and hose ID will improve performance. Finally, your nail gun should work on both compressors. To make your nailgun work at home, (assuming that there are no air leaks) lube the headvalve parts with silicone grease. (sold at lowes in plumbing dept) For best performance, replace the orings in the head valve, examine the plastic parts where the orings contact and look for wear and tiny scratches (use magnify lense). Replace these worn parts along with orings. Replace the head gasket and make sure that the body and the head-cap are not warped. Place sheet of fine sandpaper on flat surface, with cylinder removed rub the body of the gun on paper a few times to check for warp. Do same with cap. Parts are available at www.toolpartsdirect.com. Enjoy
Posted on Dec 14, 2008
I think that there is water in your compressor from condensation, it's getting the inside of your gun wet and it's freezing up. Just a guess.
Posted on Apr 18, 2009
I have a Hitachi NR83A3 framing nail gun. It won't drive nails flush. Adjusting the depth screw from one extreme to the other doesn't appear to help or change the driven nail depth. Any ideas?
Easy to check. Remove nails from gun and connect to air supply. Using hard rubber pad or soft wood depress and hold trigger and push nailer safety against pad and hold there. The gun will fire but the driver will stay down until you pull back on the gun and relieve pressure on the safety foot. With driver down examine the tip of the driver. It should look square and should extend about 1/4 inch or more past the nose. If tip is broken replace driver. If lots of air is leaking past the nose during test, also replace the lower bumper. Good luck
Dec 23, 2014 | Hitachi Air Tools & Compressors
Paslode framing nailer: compressor powered, hisses but will not shoot nails, appears to be in the sliding mechanizism that touches the wood first before it will shoot, help
I've used paslode for years and whenever there was a "hiss" of air and no fire- it was o-rings- When were the o-rings changed last? And how do you know they are in 'good shape'? You can't tell by just looking at them. If that isn't the problem then I can't help. Just as an aside- do you oil the gun (down the air intake nipple) every time you use it? Lack of oil will wear out o-rings fast. Sorry if this isn't overly helpfull but most gun problems are o-ring or seal related unless you've worn out or damaged a mechanical part.
Feb 10, 2013 | Air Tools & Compressors
Plaslode im250 second fix nail gun fires intermittently. Gas is loading fine and trigger working only fires about one in every ten pulls of trigger
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Dec 31, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Porter Cable FR350 Round Head Framing Nailer not firing
check and make sure your compressor is at the right psi. 120psi. is there any nails stuck in it. there may also be a problem with the seals.
Mar 08, 2010 | Garden
Paslode nail guns won't shoot
piston is probably jammed
This happens sometimes try holding it up against a board with the trigger depressed and then inset the battery.
The goal is to try to force the firing sequence to get the piston back to the right position with corded units this is simply done by attaching the air hose with the trigger pulled this causes air to rush into the gun chamber pushing the piston back and firing a nail out.
The cause of this is a misfire or jammed nail that stopped the piston in the wrong location so air will not build in the chamber correctly.
Hope that helps
Feb 18, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
Paslode framing nailer works for about 10 nails and then stops, air comes out from around trigger but it does not fire
buy a rebuild kit and use it; and in the future oil your gun ( if it's not oiless) and DRAIN YOUR COMPRESSOR DAILY to avoid this problem
Nov 13, 2009 | Tools & Hardware - Others
Paslode air framer not sinking some nails
Your air pressure is dropping everytime you fire. It sound like your compressor is not cutting back in untill it to low. Not giving your tool enough continuess pressure. Your compressor cut in pressure should be around 90-100psi no less. and your max. pressure no more then 120psi. (Make sure your regulator is set at 110psi)
good luck...!
Aug 11, 2009 | RTO Paslode #650027 2500CT Placement Nail
Paslode nail gun not firing
Yes you need to oil driver blade piston.
You need to check for spark. With no nail or gas in it. Take of main cylinder(4bolts on top, 2 bolts on nose. And then put in battery. And then push upper switch(behind roller at top) and the fan will come on. And then pull the trigger. You should have spark.
Thanks,
Jeff
May 16, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Air Tools & Compressors Logo
986 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
