Question about HP PSC 1210 All-In-One InkJet Printer
I just installed my 1210 all in one HP printer, its used and i havent used it in a while, it had an error message by the ink cartridge light so i had to put in new ink cartridges now it will do anything else. it wont print. when i try to print something, it just sits there
  • 112 Answers
HI,
DEAR TRY COPY A PRINT i mean print out not from your system jast put a paper in to your secner and copy it if the printer do it.then reinstall your software
if not then you have to repair it from your nearest printer repair shop.
Posted on Dec 14, 2008
The black printer cartridge leaked a fair amount of ink in to the printer. I am getting all lights flashing and the printer won't even turn off when I hit the power button. I did some cleaning and it...
Sorry to hear that.. here are some instructions that should help you out:
Instructions
things you'll need: Microfiber cloth
1. Ink Cartridge Errors
2. Turn the printer on and open the ink cartridge cover. Wait for the cartridge carriage to stop completely before reaching into the printer.
3. Press on the top of each print cartridge, then pull the cartridges free from the carriage. Make sure you are only using HP cartridges labeled as "HP 60" or "HP 60XL."
4. Reinstall the ink cartridges and close the cover. If the ink cartridge error message displays again, remove the ink cartridges as before.
5. Clean the copper metal contacts on the cartridges using a dry microfiber cloth. If you still see the error message after you reinstall the ink cartridges, replace hem with new cartridges.
Print using the device's ink backup mode if you do not have a replacement for one of the cartridges. Remove the cartridge you cannot replace and close the cover and continue printing. The printer will automatically use the backup mode until you install a new cartridge.
Mar 21, 2011 | HP DeskJet F4280 All In One Printer InkJet
Ink system failure....error code 0xc19a0013....what is this error code and how do i clear it....
What is HP Printer Error 0xc19a0013 & How to Solve the Error ? 0xc19a0013 ink system failure error shows in the control panel of printer.
Reason of occurring this error message is listed below:
  • HP printer setup may not be installed properly.
  • Printer cartridges low message.
  • Printer cartridge is damage or not inserted properly.
How to Solve "0xc19a0013" Error Code for HP Printer
  • Change low or empty cartridges: in case ink alert message is display before this message. Changing the cartridges may solve the issue.
  • Make sure the printer cartridge is installed or inserted correctly
  • Remove the printer cartridge and reinstall that.
  • Use HP Printer Automatic Cleaning Utility to Printheads:In case the error message is occurring ,use automatic cleaning utility of printer for printhead cleanup
  • Update the Printer Drivers :It may happens due to outdated printer drivers. We recommend you this to update your HP printer drivers on regular bases for smooth and flawless printing
In case your HP printer still display the error message best option is to dial HP Printer technical support Phone number-1-800-436-0509 (US), +44-800-078-6054 (UK), +61-1800-769-903 (AUS)
1 800 436 0509 HP Printer Technical Support Phone Number
Jan 04, 2011 | HP Officejet 6500 Wireless All-in-One...
I have a hp psc 1200 . i have not insert the printer cartridge. will the scanner work ?
Inkjet Printer will not operate with out the ink cartridges inserted. The Error message on display will not allow the printer to work.
Regards
Riztech
Jun 16, 2010 | HP PSC 1210 All-In-One InkJet Printer
My printer doesnt print anymore error msg and will not turn off. Ive installed new print cartridges and no luck keep getting the error msg and wont print at all. I have a psc 1210 all in one
What is the error message?
Also, please consider the following:
Are you using a factory new ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 16, 2009 | HP PSC 1210 All-In-One InkJet Printer
Printer ink cartridge not recognized by printer hp psc 1210
some time hp printer does not reconize refill cartridge or cartridge is damage when refilled so change cartridge
Feb 20, 2009 | HP PSC 1210 All-In-One InkJet Printer
Hp 1210 all in one printer - error message
Two problems;
1 - This unit cannot be set back to factory settings as it does not have the keypad to enable this functionality.
2.
Most of the time when the error pops up it is due to problems with either the printer reading the cartridge is in from the contacts or the cartridge contacts are damaged.
I should also point out that refilled and remanufactured cartridges are the number one reason for the error but assuming that you are using hp cartridges fresh out of the pack take a look at this link and follow the steps. I would type them out but it even has pictures for easy reference!!
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00042818&cc=us&lc=en&dlc=en&product=79499&dlc=en&lang=en
If you are not using hp cartridges then replace with genuine cartridges and it will most likely resolve the issue - the printer is able to tell the difference between a new and refilled/remanufactured and often times will reject the cartridge because of this.
Jul 01, 2008 | HP PSC 1210 All-In-One InkJet Printer
Cradle jam after inserting ink cartridge, wont align
May-15-2008
in a HP-PSC-1210, replaced empty HP56 black-inkjet cartridge.
Afterward, printer gave error message AND unable to "dismount" the cartridge.
Finally discovered that an HP57 color-inkjet cartridge had accidentally been mounted/installed. A handyman relative was able to dismount the (wrong) cartridge.
Cradle did not actually jam, though printer would not print.
Apr 21, 2008 | HP Office Equipment & Supplies
Pen failure message from utility
HP tech support suggests cleaning the ink cartridge contacts and the contacts inside the printer for the cartridges. If this does not clear the problem, try replacing both cartridges (color and b/w) with new ones.
Jul 25, 2007 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 1210 All-In-One InkJet Printer Logo
65 people viewed this question
Ben Johnson
