Question about Sony KP-43HT20 43" Rear Projection HDTV-Ready Television
Generic TV question, please help!
As I was disconnecting my component cables, it pulled the thin metal cover off of the back of the TV with it! It only happened on one of the 3, but now its just black plastic with a hole in it on the back of the TV. Does this thin metal cover have to be resoldered, or replaced? Where could I find a replacement? Will the TV work without it? Its the Red Component In. Please help!
    Sergeant:
    Champion:
  • 326 Answers
Hello theadidasman, best solution is to replace the destroyed part(s). Contact your nearest Authorized Sony Dealer. Regards, Arpi
Posted on Mar 15, 2007
SOURCE:
My 1999 tyahoe hood latch and cable doesnt work how can iopen the hood
have someone push down on hood and try to open ---- reach behind the lever and disconnect cable use a vise grip to pull cable if cable is broken---- than behind grille is latch look through grill and will need a metal hook to grab cable and pull cable towards grille and pull through cut cable cover back and pull cable back
Hood latch won release ChevyTalk FREE Restoration and Repair Help for your... how to open hood from outside when cable breaks
Jul 28, 2016 | 1999 Chevrolet Tahoe
Tip
How to replace your ipod battery
1. buy a new battery
2. open ipod (where it joins up) with thin pice of plastic or metal
3. there will be clips holding then together. push them in and they will open.
4. open ipod carefully because there a ribon cable holding each side together
5. carefully remove the hardrive, (should have a rubber protection around it) by lifting the cable socket.
6. removie battery carefully with thin plastic or metal. try not to touch the circuit board underneath.
7. disconnect wire from ipod case. (pull them from socket)
8. attatch the new battery
9. put back in hardrive
10. put case back on and your all set.
on Feb 17, 2010 | Audio Players & Recorders
Where is the starter
Radiator side of engine block lower
Oct 26, 2010 | 1998 Pontiac Grand Prix
How can I change the fan inside my computer? It's making too much noises
  1. Shut down the computer through the Start menu.
  2. Ensure that your computer and attached devices are turned off. If your computer and attached devices did not automatically turn off when you shut down your computer, turn them off now.
notice.gif NOTICE: To disconnect a network cable, first unplug the cable from your computer and then unplug it from the network wall jack.
  1. Disconnect any telephone or telecommunication lines from the computer.
  2. Disconnect your computer and all attached devices from their electrical outlets, and then press the power button to ground the system board.
caution.gif CAUTION: To guard against electrical shock, always unplug your computer from the electrical outlet before opening the cover. notice.gif NOTICE: Ensure that sufficient space exists to support the open cover—at least 30 cm (1 ft) of desk top space.
  1. Lay the computer on its side so that the arrow on the bottom of the computer points up.
  2. Open the cover:
    1. Facing the back of the computer, press the release button on the right side of the computer with one hand while pulling up on the top of the cover with the other hand.
    1. Press the release button on the left side of the computer with one hand while pulling up on the top of the cover with the other hand.
    2. Hold the bottom of the computer with one hand, and then pull open the cover with the other hand.
caution.gif CAUTION: To guard against electrical shock, always unplug your computer from the electrical outlet before you open the cover.
  1. Open the computer cover.
notice.gif NOTICE: Before touching anything inside your computer, ground yourself by touching an unpainted metal surface, such as the metal at the back of the computer. While you work, periodically touch an unpainted metal surface to dissipate any static electricity that could harm internal components.
  1. Disconnect the cooling fan power cable from the FAN2 connector on the system board.
  2. Disconnect the power cable from the PWR connector on the system board.
  3. Lift up the airflow shroud.
caution.gif CAUTION: The heat sink can get very hot during normal operation. Be sure that the heat sink has had sufficient time to cool before you touch it.
  1. Remove the heat sink:
    1. Release the retention module clip by pressing in on the tab and lifting the retention module clip up.
    1. Pull the release lever out until the heat sink is released.
    2. Lift the heat sink away from the microprocessor.
notice.gif NOTICE: Lay the heat sink down with the thermal grease facing upward.
May 12, 2010 | Dell Dimension 8300 PC Desktop
1/8 inch wide vertical streak on dell lcd monitor grey-green
There are loosed contacts between scaler board and flex-cables, at least those where you have color lines. These cables are glued with anisotropic compound and not such easy to fix, to make it right you shall heat junctions to certain temperature and press the cable down to surface with certain pressure, which is specified for compound used in there - consider as unknown.
The easiest way to get rid of these lines is to press flex-cables with something like piece of foam rubber.
Disconnect all cables coming from the display to boards, take the chassis off, unscrew metal cover from back side of display to get access to the scaler. Now, if you can, connect display back to boards (you may need to take boards off the chassis) and turn on the monitor. This will help you to find exactly loosed spot. Gently pressing to junctions of flex-cable to scaler PCB with finger observe the behavior of color lines on the display. Then put there thin piece of foam and fix with metal cover. That will work for awhile.
Sep 12, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
I have a thin vertical green line that appears on my 9 month old 23'' Apple Display, the line goes away, but has reappeared a couple times. Is there anything I can do, without sending it out? or is this...
There are loosed contacts between scaler board and flexi-cables, at least those where you have color lines. These cables are glued with anisotropic compound and not such easy to fix, to make it right you shall heat junctions to certain temperature and press the cable down to surface with certain pressure, which is specified for compound used in there - consider as unknown.
The easiest way to get rid of these lines is to press flexi-cables with something like piece of foam rubber.
Disconnect all cables coming from the display to boards, take the chassis off, uscrew metal cover from back side of display to get access to the scaler. Now, if you can, connect display back to boards (you may need to take boards off the chassis) and turn on the monitor. This will help you to find exactly loosed spot. Gently pressing to junctions of flexi-cable to scaler PCB with finger observe the behavior of color lines on the display. Then put there thin piece of foam and fix with metal cover. That will work for awhile.
Sep 10, 2009 | Apple Computers & Internet
Toshiba tv 32ax60 3 thin wires disconnected
belive your referring to rf converter assembly. entire unit can be replaced  or if threaded end pulled out can be repaired. dont understand 3 wires unless worked on previously. avg shop prob min bench to repair. .
Dec 02, 2008 | Toshiba CX36H60 TV
I pulled the tv by the cable cord and broke the metal part.
this metal can rectangular component? this is the tuner module for the tv the device that seprates the signals that come into you tv into the channels you watch. Union electronics, partsstore.com are some places you can get tunner
Nov 19, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Where is the Fuse??
once you take off the back of the tv you can see where the power cord plugs in and there is a thin metal cover you pull that off and unplug the power cord from the board and right in front of that under the other metal cover you will see a small fuse with a white middle. pull it uot and get a new one. i think that is what you are looking for
Aug 19, 2008 | Protron PLTV-32 Television
Slot where cable fits in - Broke
I am assuming that what you are referring to as "metal block" is the tuner assy. and that the "slot/cable receptor" is the chassis mounted 75ohm TV "F" Coax Connector (female). This is easily replaced and the component should be readily available from most electronics part stores.
To perform a DIY and replace this, the TV has to be opened, the metal cover of the tuner pried open, and the F connector replaced and eventually soldered in place.
Incidentally, a nice tutorial on how to go about this is posted here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 07, 2008 | Samsung TXG2547 25" TV
Sony KP-43HT20 43" Rear Projection HDTV-Ready Television Logo
22 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
