Question about GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Eterna Spacemaker model number EMO3000HSS05
Recently I noticed that the microwave sounded like it was only operating on half power. In other words, the microwave sounded a little quieter than usual and it appeared to be operating slowly. Upon using the microwave a few more times, the power completely shut off. The power has since returned and I have normal use of the clock, lights and exhaust fan, however, I have the same "half power" problem. Any suggestions and can I fix this problem myself?
  • Anonymous Dec 29, 2008
    Our microwave GE Eterna Spacemaker model number EMO3000HSS05 has the same problem. First it made a strange humming sound (like it was operating at half power, grumbling almost) and then eventually today the power just stopped.
  • William Miller
    William Miller May 11, 2010
    Please reply back with your model number so we can help you.
MicrowaveSvc
  • 9098 Answers
SOURCE: My GE Profile Eterna Spacemaker also shuts off ramdomly
WARNING: The "technique" of using "anti-static paper" or anything else to try to shield the control circuit board is not a fix, but a band-aid at best...
This problem is almost always due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
The shielding may keep the interference out of the controls, but it's still being emitted, and the magnetron will eventually go bad.
Details covering some previous models are in GE's bulletin here. Even if your model is not on the list, the same problem can occur.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
NOISY MAGNETRON TEST (c) 2009 William E. Miller prototech@usa.net
One way to test it is to do the following:
1. Unplug the microwave or turn off its breaker.
2. Open the door, then detach the control panel as shown in the video at http://www.microwavedisplay.com and swing it down, but without disconnecting the wires. If you have any trouble getting the grille off once the screws are removed, slide the hood vent grille to the left about 1/4", then then pull it forward. On some models there are L-shaped clips that fit into a slot to hold bottom of the vent.
3. Plug the microwave back in.
4. Make sure neither you nor anyone else reaches in behind the control panel. There will exposed high-voltage connections.
5. Put a few cups worth of water in a microwave-safe container and place it inside the microwave.
6. Shut the door.
7. Run the microwave for about 1 minute or so on full power. (Time Cook > 1 > 0 > 0 > Start, e.g.)
8. If it does not fail, try it several more times.
9. When the water boils, change the water and try again.
NOTE:
If your model does not have a door handle, you will need to unplug the oven and reattach the control panel to be able to open the door.
If it still does not fail, I would recommend that you put it all back together and keep using it until it fails more consistently, then repeat this test.
While a microwave should never be left running unattended under any circumstances (as your owner's manual will tell you) it's even more important when one is exhibiting a failure or any odd behavior. So play it safe and stay with it while it's running!
If you or someone you know want to replace the magnetron yourself, you will need to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
Sometimes they will send you the magnetron to do it yourself. Call them at 888-239-6832.
Be persistent. You may have to speak with a supervisor.
If it is not within the magnetron warranty, you can find helpful exploded view diagrams and order parts by entering your full model number here.
If you prefer to arrange service by an authorized service center, GE Customer Service is here.
Posted on Jun 28, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: GE SPACEMAKER XL MICROWAVE OVEN JVM1440
Assuming that your internal cooling fan is working, I would suspect that your magnetron is failing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the
I would check the cooling fan, then suspect the magnetron.
Posted on Nov 16, 2008
jyackle5
  • 8197 Answers
SOURCE: how do I set the clock on a GE Spacemaker microwave oven?
You can get the manual here.
http://www.retrevo.com/s/GE-JVM1640SJ-Microwaves-review-manual/id/1080ci954/t/1-2/
But usually you just press the clock button to set
Good Luck and Please Rate Fixya!
Posted on Jan 10, 2009
  • 686 Answers
SOURCE: GE Microwave Spacemaker JVM1640BB sounds like it
SOUNDS LIKE THE MAGNETRON WENT BAD IT'S ABOUT A 100 AND SOME DOLLAR PART
Posted on Apr 13, 2009
scottowa
  • 87 Answers
SOURCE: Burning smell and won't heat.
If it buzzes real loud it's probably the high volyage diode. However some times if it smells it's the transformer. Usually the diode is a cheap fix ~$10.00 but this model the diode is $50. It's number 50 on the link below. Let me know how it works out or you need anything else.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=JVM1440BH01&productCategoryId=0123370&brandId=0432&modelName=MICROWAVE&diagramPageId=00001&documentId=G0312014&pop=flush
Posted on Apr 19, 2009
GE eterna spacemaker microwave won't heat
The problem is a magnetron, "heart of the system" or the inverter board, "if 7 years old or less" and possibly the keypad control board, all of these items are not cheap and lethal voltages are present.
May 05, 2012 | GE Microwave Ovens
The unit is beeping and has a code showing F3
Is it difficult to change a touch pad on my ge profile eterna spacemaker microwave. F3 Error, Bought it new in 2006. Touchpad Part No# WB07X10959 Twinsinger asked.
Feb 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave runs but no head
I have a model number MCD1311ST. The timer seems to be operating however there is no sound and it is not heating or operating.
Jun 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker quit working.....
sounds like a short in unit and if it is then must be taken apart to observe operation and failure spot. depending on the age GE has warranties that cover magnatron up to five years< most likely cause of problem> suggest calling company before procieding any further.
Apr 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave not operating correctly.
It sounds like your internal cooling fan (not to be confused with the exhaust fan) is not working.
This will cause the magnetron to overheat until the magnetron's thermostat trips, killing power to the whole oven until it cools back down.
To help further, I would need the full model number form the tag on the oven.
For more free DIY and other help & advice, feel free to contact me.
William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 11, 2017 | Microwave Ovens
I have a GE Eterna Spacemaker Model Number EMO3000HSS05
Reduced power was selected, perhaps inadvertently
May 07, 2017 | GE EMO3000 Microwave Oven
My GE spacemaker microwave won't heat and makes an unusual sound
I have the same problem on my oven- model JVM1640WB and called an appliance repairman who is honest and reliable (I've used him before). He said the problem is with the electrode, to fix it is roughly $300. He recommended buying a new microwave rather than fixing it.
Nov 17, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Constant rattling noise during operation
possibly the "stirrer" motor - this is in the top and turns a metal reflecting ring to disperse the microwaves around the oven more evenly. About $70 on GE site for my oven.
Jun 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
BREAKING MICROWAVE SAFE DISHES
I would recommend having it looked at. Sounds like the magnetron or the maser is malfunctioning and not operating within it limits which could be potentially dangerous.
Feb 04, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
217 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
