Question about HP Compaq Presario V2000 Notebook
Computer wont start-up
About 3 weeks ago i tried to plug in my external hard in to a usb port to transfer some files to that computer. When I plugged it in the mouse and keyboard would freeze up and i could not do anything but restart it. Every usb device I tried to hook up had the same problem. If I plugged it in before i cut on the computer it would freeze on the windows screen. I tried to reinstall all the drivers, removerd the critical updates that were obtain within the past month, start up with last known good configuration, restored to a couple weeks before the problem and had no success. Now I cant even get the computer to start up correctly. Everytime i try to start it up everything freezes like it did when i put in a usb device. It will start up sometimes but the mouse and the keyboard wont work. Can someone help me sovle this problem?
    New Friend:
  • 21 Answers
If I get you right, after you plug the xternal drive to transfer some file, the system didn't come up. Right?
Well, let me assume yes. If that is the case, I will advise you to boot the system from an external disk and use it to scan the local hard disk for virus. After that, remove the x-hard disk and try to boot the system. If it doesn't work, then transfer all the files to the xternal hard disk and format the local hard disk for new use. Best of luck.
Posted on Dec 14, 2008
Windows will not start with a Toshiba external hard drive plugged into USB
Computer starts normally in windows with a windows that is installed on a hard disk on that copmuter. In other words - windows is installed on an internal hard disk of a computer A. If you get it out and put in a computer B it wont work.
To have the things work:
1. First should set in BIOS boot up options first boot device CD/DVD, second OTHER/USB/EXTERNAL, third HDD
2. Should boot up from a CD and install windows on an external hard disk (in your case your 3TB Toshiba external HD)
3. Set in BIOS boot up options first boot device OTHER/USB/EXTERNAL, second internal hard disk e.g. HDD0, HDD1
Apr 04, 2014 | Toshiba Canvio Computers & Internet
Transfer stuff from a working and put it on another hard drive
The easiest way is to connect your hard drive to an USB hard drive adapter or USB hard drive dock, then plug this USB adapter ot dock into the USB port of your computer. The computer will see this as an external storage device, you can then open the various folders and copy the folders or files to the computer,
If you want to copy these folders or files to another hard disk then connect the other hard drive to the USB hard drive adapter or USB hard drive dock and plug it into your computer and copy the folders or files from your computer to the external hard drive.
Mar 28, 2013 | Maxtor Hard Drive
I plug in my hard drive to the USB port, but the computer/USB port wont detect it. This happens on multiple computers
henryhan20, OK, good. Plug both of them in when using the external hard drive. The USB plugs supply power to the device as well as serve as a means to transfer the data. USB ports can carry 5 volts of power (max). If the hard drive is over 4200 RPMs then it will most likely need more than 5 volts to work properly. Try plugging both USB jacks in concurrently.
Hope this helps,
Mark
Oct 05, 2010 | Iomega Computers & Internet
Computer is not recognizing my external hard drive
If the light won't blink, there could be problem with the power source. Do scanning hardisk for errors manually ( take off the hardisk from the case, assemble it on other PC Desktop)
May 06, 2010 | IO Magic Corporation GigaBank (I250HD35)...
Transfered contents to a terabyte drive weeks ago. Not recognized
thats a file system related problem, try to download this file systems repair tool, let see if work. download data recovery wizard tool from this link. http://www.easeus.com/disk-copy/download.htm
Apr 13, 2010 | Hitachi SimpleDrive Mini 250GB USB 20...
After a time, Computer not recognizing portable harddrive
Reformatting will be our last option and there are a number of steps that you can try to fix this.
  • Try plugging it in on a different USB port
  • Check the USB cable, try replacing it and see if it works
  • USB ports on your computer makes use of power, so if you have multiple USB devices plugged in, the portable hard drive might not be receiving enough power. Try plugging it in without your other USB devices, except the mouse of course
Please leave me a comment for this.
Jun 03, 2009 | SimpleTech Signature Mini 320GB External...
New WD external drive not showing up in my computer
I just had this problem, go to Computer Management/Disk Management, and assign a drive letter to it, for some reason it doesn't automatically.
Jul 16, 2008 | Western Digital My Book Premium ES...
I am trying to install a WD 250GB Passort V2 External USB 2.0 - 2-50" Portable Hard Drive but unfortunately my Windows XP doesn't want to know it. I have had it just over a week now and when I first...
Did you try a different usb port? is the cable plugged in correctly? check device manager and monitor it once the ext. hdd is plugged and report back with the result plz.
Jun 16, 2008 | Computers & Internet
Transfering data
If you are having issues accessing the drive i've encountered that situation before
I tried a different cord and it started working again. Additionally i've had this work for me (see below)
Try This:
  1. Unplug all USB devices
  2. Turn off Ext Hard drive
  3. Shut down computer
  4. Power on ext hard drive (then wait like 1 min)
  5. Turn on computer
  6. Wait for windows to finish loading
  7. Plug in the USB cord from the ext hard drive to your computer (may take up to a minute for computer to recognize it)
  8. If it doesn't recognize it then keep trying it in different USB ports
If it still won't recognize get all the latest windows update and reboot. If that doesn't solve your issue try your external hard drive on some other computers, check to see if drive needs special drivers installed (which most don't).
From SimpleTech's website: "1) I have the drive plugged in but I cannot find the drive in "My Computer", why?
The most likely cause would be not enough power provided by a single USB port on your computer. Unplug the portable drive from the cable and unplug the cable from the computer. Now, plug the cable into 2 USB ports directly on your computer. (If you have a desktop, you should plug the USB cable directly into the USB ports on the back of the computer. If this is a laptop, you should plug directly into a USB ports on the computer. Do not plug into a USB hub or docking station). Then plug the drive into the cable. In a few seconds you should see the drive listed in the "My Computer" window as a SimpleDrivePS."
If all that fails you need to RMA (Return to Manufacturer) your external hard drive. Most hard drives have a pretty decent warranty on them. Your simpletech 250GB has a 3 year warranty on it. Info on the warranty can be found at http://www.simpletech.com/support/warranty/. If you want to RMA it, click the "Technical Support / RMA Request" on the left hand side of that page.
Mar 12, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Wd 120gb External no longer recognised by my PC
hi there
have you tried looking at the device manager?
you can also try transfering it to different usb ports.
hope this helps
Feb 04, 2008 | Western Digital Passport WDXML800UE...
HP Compaq Presario V2000 Notebook Logo
126 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
