Question about HP DesignJet 750c plus InkJet Printer
I haven't used the printer in a while (about 6 months) then last week I turned it on and tried to use it. Went to print a test page and it went through the process but nothing came out on the paper. I checked the carts for ink and there is plenty in each one.. can yo fix this. it is a 750c plus by HP
  • 53 Answers
Take out the cartriges and hold one at a time between your forefinger and thumb tightly. Hit your wrists together and see if ink comes out the bottom of the cartrige. Be careful not to mess ink on your clothes or carpet etc. This sharp "shock" will bleed the cartrige and hopefully the cartrige will work. Clean all messed ink from any contacts and the jet area of the cartrige before inserting back into the plotter.
Posted on Feb 06, 2009
Printer prints test page and direct prints fine but anything sent from the PC only prints (at most) a thin line (about 2cm/1in) on the left side of the page.
Well, if it ran okay with Windows 8.1 until the last month and if it prints a test page ok, the problem is unlikely to be drum wear or wear of internal parts. You sometimes encounter weird streaking effects if the windows are not clean. Normally, if only one side of a page is being printed, parts are worn or the drum need replacing. But your test page prints out. The only thing I can see that would have changed is --Ta da! -- some automatic update by Windows 8.1. Re-installing drivers doesn't really undo any changes in Windows 8.1 itself or whatever you have installed in the last month or so. (Windows 8.1 experts can stop laughing--I am simply making an educated guess.)
If this were a home setup rather than a work computer, I might see what would happen if I returned the computer to a state prior to "the last month or so." If the printer then worked, you would know it was not a hardware problem but rather what had been installed on the computer after that. Is the printer actually using the Brother driver or is it deferring to a Microsoft driver? Just something for you to check in your device manager. If returning the computer to a former state fixes the problem, you may have to test subsequent installations to determine which one troubles the printer, a tedious process unless a candidate springs to mind.
Aug 11, 2015 | Brother HL-4040CN Laser Printer
Printing very light
Try performing a stop test. Send a test page and turn it off mid print. Retrieve the page from the printer to see if the image is readable before it went through the fuser. If so the the fuser may need to be replaced.
Jan 16, 2014 | Oki Electric Industry B410D Laser 30PPM...
I just bought a whole set of inkjet cartridges. My printer went through the cleaning process. Then it started printing a document. But there was nothing printed on the paper. The paper was clean without...
Please try to to print a test page and see the results. If the test page prints correctly then there is nothing wrong with your printer. Since you have changed the operating system you are required to update the printer driver. For that go to your printer site. Under the support find out which driver is compatible with windows 7. Download the same. You should not have any difficulty printing when you have the latest driver.
Feb 18, 2011 | Brother MFC 240C All-In-One InkJet Printer
I have a Brother 5240 printer. The toner light
Try this... it reads the level of the toner and can become faulty. This clears it.
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
Jun 24, 2010 | Brother HL 5250DN Laser Printer
Power went out last week. Can't print. The jobs
OK try this Remove Power Cord from Printer, remove USB cable from PC. Reboot PC. Wait 10 mins, then connect, the Power again to printer. Turn OFF PC. While OFF plug in the USB cable TO any other USB other than the one used before. Turn PC ON. After a bit you should hopefully have a working printer. If that doesn't work, Unplug USB, reboot & then using your DVD re-install it all again.
Feb 15, 2010 | HP Photosmart C7280 Printer
G600 printer dock used about 6 months ago. Only
Yes, maybe the ink dry out. Try a deep cleaning several times, from the printer options.
If you don't use the printer, you should weekly print a test page to avoid this problem.
Aug 27, 2009 | Kodak Easyshare Printer G600 Thermo...
I have bought a lexmark fax,printer,copier X4270 two months ago and it is not working.I do not want you to call or offer me a dicount on it being repaired this is the second lexmark one that I have bought...
IF your printer is 2 months old then if not working you can contact Lexmark and get your printer replaced as its under warranty for free by the company ...
Good luck..
Aug 18, 2008 | Lexmark Office Equipment & Supplies
Power on, but nobody home
If this an inkjet then you might find that the cartridges have dried up.
Oct 07, 2007 | Office Equipment & Supplies
Test page
try with replacing the catridge or clean with tissue paper and do the test page scan again
Sep 06, 2007 | HP PSC 1510 All-In-One InkJet Printer
HP DesignJet 750c plus InkJet Printer Logo
166 people viewed this question
Ben Johnson
