Question about GE DSXH43EAWW Electric Dryer
My dryer plug is 4 and the electrical plug in the wall is 3
I move and took my dryer and come to find out the house I move into the electrical plugs in the wall is 3 and my dryer is a 4 plugs can I purchaces and adapter
  • 145 Answers
There is no "adapter" per se, you MAY be able to swap to a 3-wire cord, however that may be against local code. The only other option in that case would be to have a qualified electrician install the newer 4-wire outlet. You need to find out what you local codes are with regard to this issue. If you do change to a 3-wire cord to macth that outlet, it is critical that it be installed correctly.
Posted on Dec 14, 2008
Just moved, the dryer has a 4 prong plug and house has 3. Should it replace plug to dryer to 3 prong or house plug?
Buy a 3 wire cord and install it on the dryer. Hang onto the 4 wire one in case you move again.
Aug 28, 2011 | Whirlpool LER4634J Electric Dryer
I took the plug off the dryer from the back to the wall , the 120/240 plug and dont know how to rewire it
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Aug 04, 2011 | Maytag Neptune MDE5500AY Electric Dryer
We just moved and this house has a 4 prong dryer plug and our last house had a 3 prong dryer plug. We bought a new plug and hooked it up as it says and still nothing. Any help would be much appreciated!
You may have inadvertently incorrectly wired the dryer power cord. The following link epxlains the differences between the 3-wire and 4-wire configurations:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
Make sure you have the wires connected properly at the terminal block. Pay particular attention to the difference in how the ground and neutral wires are connected. If you have any questions, please post back and let me know. I hope this helps you.
Dec 01, 2010 | Roper REX4634KQ Electric Dryer
How do you change a 4 prong dryer plug down to a 3 prong power plug
Today's newer electric dryers now use a 4 prong plug. If you try to relegate your new dryer to the old 3 prong hook-up that you currently have in your house, you will have issues with your dryer. Instead, I recommend you update your house's wall receptacle to the newer 4 prong terminal and keep that new dryer warranty intact. Douglas
Sep 05, 2010 | Whirlpool LER5636P Electric Dryer
Change a 3 prong plug to 4 prong
Is it an electric dryer or gas dryer? If it's a 120 volt gas dryer, then no, you need to keep it on a 3 prong cord. If it's an electric dryer, then yes it is possible to install a four prong plug onto it. Although it isn't recommended.
The main thing you need to know is which wire is ground. From the machine, it should be the green wire. On the plug, there should be on prong that is slightly longer than the other 3. The ground has to be the first one in the wall receptacle and the last one out. So the slightly longer one is where the green ground wire needs to be wired in. The other two wires are both power so it doesn't really matter which prong you wire those wires at.
Once again I'll remind you that it isn't recommended to convert 3 to 4 prongs like that. Just be careful and make sure you aren't touching any live wires.
Mar 26, 2010 | Dryers
Changing a 3 prong plug into a regular outlet plug.
Your plug is for 220v and a regular wall outlet is 110volts. It simply will not work. You will burn out your dryer, and place yourself at risk of electrocution.
Nov 03, 2009 | Maytag Neptune MDE6800A Electric Dryer
Wall plug is 3 prong, dryer is 4 prong...is there an adaptor available?
The following link explains the wiring scheme for 3 and 4 prong power cords. I know the instructions are for converting from a 3 to a 4 prong, but if you look under the "Additional Notes" section it explains how to convert back to a 3-prong if you are currently using a 4-prong.
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
I hope this helps you. If you have any questions, please let me know.
Aug 13, 2008 | Estate TEDX640JQ Electric Dryer
I've since moved and in the new house the dryer cord had a 3 pronge plug. The one that I need in the new house is a a 4 pronge plug. I purchased one, took off the 3 pronge plug without looking at the...
Yes, it does matter which color wires are connected. If connected wrong, you may injure yourself and/or destroy the dryer. The following link explains how to convert your dryer plug:
Let me know if you have any further questions. I hope this helps you.
Aug 07, 2008 | Dryers
GE DSXH43EAWW Electric Dryer Logo
250 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
