Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Ice maker makes ice, but won't dispense.
Purchased used (about 1-1/2 ys old), hooked it up and everything works, except ice dispenser. Ice is making just fine, but when lever is depressed to dispense ice, nothing happens - not a sound. The auger is NOT frozen stuck and there is no clumping. It seems the drive mechanism is not coming on. Is there some switch inside or on back of refrigerator?
  • Anonymous Mar 28, 2014
    Ice ic melting in the bin and freezing in a clump preventing the auger from functioning.
  • 85 Answers
If you hear a click when the actuator is depressed the swt is ok remove ice bin and try rotating auger mtr by hand if you can't the auger motor is frozen, you can remove the whole auger asm and let it thaw out and dry out for a few days
Posted on Dec 14, 2008
Why is icemaker making a clicking sound?
Ice Maker Not Dispensing Ice ' ThriftyFun
Sometimes your refrigerator ice maker makes ice, but does not dispense it. ... If it gets pushed all the way back to the ice maker it prevents the metal arm from full ... Itry not to put anything on the shelf over the bin and also try to keep it pulled out just a little ... My ice maker is making a clicking noise and not making much ice.
Ice maker making ice, but won't come out thru door
If when you attempt to dispense ice (and it doesn't work) the whole refrigerator seems to .... Many have just bought a new refridgerator or don't use the ice dispenser. ... I'vetried to decrease the cold in it from the dial and that doesn't help. ... The motor was working and the auger would turn with no ice in bin but the added ...
Dec 25, 2015 | Samsung RH29H9000SR RH29H9000SR 29 cu. ft....
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
The ice maker makes ice and dispense water, but won't dispense ice. Cleaned out ice tray, not ice blocking any discharge area. When you try you can hear the ice dispenser door open, but the motor to...
i have the same fridge... same problem, except not only does it not dispense ice, it also dosent dispense the water too. i recently had a power outage, and when the fridge was turned back on the digital warmer and colder setting have been flashing 0 non stop making it unable to set temps... any suggestions?
Aug 22, 2011 | General Electric GSH25JSXSS Stainless...
1 week old Whirlpool Gold refrigerator. model FI7FVCXWYO ice make
Call for service as the "wet ice" indicates freezer is warm.
May 20, 2010 | Whirlpool Refrigerators
Ice Maker not making ice in new fridge
make sure the metal bar is in the down position
Apr 16, 2009 | Refrigerators
In door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Nov 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
GE profile performance tfx30ppz ice dispenser not working
Had the same problem. The water line from the valve to the ice maker was cracked due to heat from the compressor.
Jan 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Dec 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
GE Stainless Steel side by side fridge GS425JSRF - 2 ys old
Make sure there is no obstructions from the time the ice leaves the chute until it drops into the glass. make sure the motor that moves ice and out to the area for the cup is stuck or seized up let us know thanks
Aug 25, 2007 | GE Profile PSW26P Stainless Steel Side by...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
766 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
