Question about KitchenAid KHMS155LSS 1000 Watts Microwave Oven
My kitchenaid microwave is not heating up the food
What could be wrong
  • 2 more comments
  • cecurrie Dec 17, 2008
    I have the same, all the key pads and timers work it lights up, spins but does not heat up food it is only 2 years old.  I had a repair man look at it but he could not find problem without taking it off wall which he does'nt do and my wife had to let him go without resolution.
  • shestu Feb 19, 2009
    yes, my kichenaid microwave KCMS185JSS seems like it is working, but does heat the food.
  • cheloia Mar 20, 2009
    I have almost the same problem. but sometimes it heats, sometimes it does not...
  • William Miller
    William Miller May 11, 2010
    When you hit Start to
    cook, do the inside light and turntable come on?
    Any unusual noises? Is
    it louder or quieter than usual?
    Do you have the model number?
    These answers will help
    me judge whether it's in the high voltage
    section (magnetron, transformer, or diode) or the control section
    (door switch or control board relay or connection).
5 Suggested Answers
MicrowaveSvc
  • 9030 Answers
SOURCE: Whirlpool microwave MH1170xsy0 1000 watts
With the symptoms you mention, I would suspect:
- loose or corroded connection at the magnetron
- bad magnetron
- shorted high voltage diode
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
Posted on Aug 21, 2008
heatman101
  • 43501 Answers
SOURCE: my Kitchenaid Superba kaw38avm726 microwave does not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
dhjjd
Posted on Sep 30, 2010
MicrowaveSvc
  • 9030 Answers
SOURCE: Microwave won't heat food.
This would be under warranty, so Maytag should take care of it for you: http://maytag.com/support/index.jsp
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 31, 2007
  • 175 Answers
SOURCE: Microwave comes on but does not heat food.
hi..the reason to this problem is probably due to the
bad ignitor.
check this out..
thank you..
kindly rate my response..
Posted on Jul 20, 2009
dmftrucker
  • 1922 Answers
SOURCE: microwave works but is not heating up food
can you hear the magnetron operate i.e. light dims,transformer has a louder hum,if so more than likely either the H.v. diode or H.V. capacitor is bad or worst case scenario the mag tube has failed.....costly
Posted on Jul 27, 2009
Food in microwave is burning on edge and cold in the center
you may find the old unit was lower watts so took longer & cooked/heated better all the way through. a way to fix this is lower temp settings or pause and stir the food to help heat it up more even.
Dec 29, 2013 | KitchenAid KHMS2040BSS Stainless Steel...
Goldstar model MV-1515W over the range microwave. Runs everything works but won't heat and hums a bit louder than it use to. Anything I can do to fix???? Fuse, reset, throw away????
Please do not take offence to this answer. Please seek the advice of a qualified person because the capacitors in a microwave are dangerous. Handled wrong at best you will get a severe shock and minor burns at worse its lethal. I know what is wrong with it and a qualified engineer might charge about 80 pounds to fix but my conscience wont allow me to tell you in case it goes badly wrong for you.
Nov 16, 2013 | Microwave Ovens
My kitchenaid microwave is no longer spinning when i heat food
If the unit functions other than the turntable it is likely a bad motor or switch that is engaged when door is closed
Oct 29, 2012 | KitchenAid KCMS185J Microwave Oven
Sharp r-86stm will not heat liquid. What is wrong.
heatman101
Jul 02, 2011 | Sharp Microwave Ovens
I have kitchen aid microwave modelkcms185jss starts runs fine but does not heat food at all.
Does not heat food means a problem on magnetron tube and fuse blown in high voltage area. Have it replaced and it will heat again.
I hope I answer your problem.
Mar 30, 2011 | KitchenAid KCMS185J Microwave Oven
KitchenAid Architect II KHHC2090S Stainless Steel 1200 Watts Convection / Microwave Oven. Microwave quit heating. Inverter and magnetron replaced by the repairman. Still no heat but the magnetron gets...
Perhaps the "repairman" should take another look at it. A lot of microwave ovens have an aerial that directs the energy out to the load or food to be heated.
Maybe...maybe not but worth a look behind the waveguide cover I would say.
Mar 24, 2011 | KitchenAid Architect II KHHC2090S ...
It stopped heating food - what could be wrong?
heatman101 -=-][
Mar 14, 2011 | Whirlpool MH7140XF Microwave Oven
Im just trying to do it what am doing wrong? I cant find it can u help?
You did wrong by sending a question that does not make sense and with this information we cannot help!
Feb 28, 2011 | Microwave Ovens
KitchenAid KHMS155LSS 1000 Watts Microwave Oven Logo
1,220 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Darial Jr Lasaria
Darial Jr Lasaria
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
