Question about Echo 30.1CC Chainsaw With a 14 In.bar and Chain
Need high and low ajustment procedure - Echo 30.1CC Chainsaw With a 14 In.bar and Chain
  • 211 Answers
Hi carlayoung
Start the engine and turn the high speed screw "H" in(clockwise)until the engine starts to slow down(the fuel mixture is to lean,not enough gas).
Slowly turn the screw out(counterclockwise)until the engine begins to run smoothly,keep going very slowly until the engines just begins to run rough again(rich condition,watch for black smoke from exhaust).
Then turn the screw in again(clockwise) to a point about half way between lean and rich condition.This is the properly setting.
The low speed screw"L" adjust in the same manner.
The idle speed "T"adjust accordingly.
best regards savumihai71
Posted on Dec 17, 2008
Bike misfires after it warms up. act like its running on 2 cylinders.
carbs are dirty or need ajust--when choke is on it supplies fuel until runnin temp then low speed jets take over but are clogged with varnish--buy a clymer manual for bike procedures
Aug 10, 2011 | 1985 kawasaki ZL 900 A1 Eliminator
Homelite st100 string trimmer carb ajustment with one ajustment highe and lowl
Hi lloydlavalla...
Before you remove or try to adjust your low and high speed jets you should always count the number of turns it takes to lightly seat the idle mixture screw and high speed needle adjusting screws.
Be sure to write the number of turns down on a piece of paper so you will know how many turns from the seated position to open the jets when you go to reinstall them, or if you remove them for cleaning or replacement.
Normally you will adjust your idle jet to 1/2-3/4 turn open from the bottom seated position.
Then you will re-adjust the low speed of the engine when the engine is warm by turning the idle screw in or out till the engine runs smoothly at idle speed, around 1200 RPM.
The high speed jet is adjusted to 1 1/2- 1 3/4 open from the bottom seated position, after the engine is warm.
Then re-adjusted by turning the High Speed jet adjustment screw in or out till the motor runs smoothly at high speed.
Free Answer...Please take time to rate me
Jun 07, 2011 | Homelite Garden
When engin is running i can rev bike and revs will go up but when riding the revs wont go above 3000rpm and speed is low is this a carb problem
yes carb jets probly need ajust or it needs total cleaning-passages are blocking causing delay in fuel--buy a clymer manual for procedures
Sep 23, 2010 | 1998 Yamaha XJR 1200 SP
What are the high and low carb settings on a stihl fs76?
high 2 turns out and low 1 and 1/2 turns out
after you get runing up operrating temp ajust
again throttle wide open ajust high neadle and
win idle ajust low neadle
Jul 18, 2009 | Oregon Scientific Complete Carburetor for...
Want stay running
try ajusting carb did get better.if no rebuild carb and ajust carb again should fix your problem low needle 1 turn out and high needle 1 1/2 turns out this will get it runing and you might ajust again run full throttle to ajust high needle.let me know if this help you.ok
Jul 14, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Need carb h/l ajustemts and idle controle ajustment
This does take a little time to get it just right. Start at one full turn for the h and l. Work on the high first and after you get the H running work on the Low. They have to work together. So if you get it to idle and run at full throttle but it hesitates when you pull the trigger just adjust the low a little higher.
May 02, 2009 | Poulan Pro Chain Saw 46cc 20"
My eager ****** chain saw will not stay running ?
The 3 adjustment screws are Idle, high and low.
First figure out which screws are which adjustment. Tighten the screws then turn them 1 full turn.
Then start the saw and get it warmed up. Work on the high adjustment. This does take a little while. after you get the saw running at high speed work on the low speed.
Apr 25, 2009 | McCulloch MC1275 Steam Vacuum
Headlights needs ajusting
on each headlamp assembly, there will be either one or two plastic nuts that you can turn.
If you only have one nut on each, that will adjust the vertical aim of the headlights.
If you have two nuts on each, one will adjust the vertical and the other will adjust the horizontal.
Park your car on a level ground 30 feet from a wall and measure the height from the ground to the bulb and mark on a wall (do this for highs beams and low beams if the bulbs are separate, if highs and lows are the same bulb, only do it for the lows)
If the headlights read VOR, then aim the brightest part or cutoff part just below the mark on the wall. If it says VOL or nothing, aim them 2 inches below the mark on the wall.
Mar 14, 2009 | 2004 Nissan XTerra
Echo 30.1CC Chainsaw With a 14 In.bar and Chain Logo
361 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
