Question about Sony Ericsson K310i Cellular Phone
My k310i shows Error message every now and then.Wat to do?
My k310i shows error message and keeps showing it every minute or so.It stops doing that after i restart it but after some time,may be after a day or two again starts to show the same...what to do?Whats its problem?
  • onlysid2008 Dec 17, 2008
    I have tried it but it didnt work.The error still appears after some time...
    ummm....whats flush !??
Any one to help me i cant do mms from this mobile
Posted on Dec 29, 2008
  • 112 Answers
TRY TO RESTOE YOUR CELL
Posted on Dec 14, 2008
  • MOHSIN AMIN
    MOHSIN AMIN Dec 17, 2008
    ok dear try flush
    thats proved you repairing center
Why my canon ir1133 printer is showing e733/0000 error message?
ERROR E733-0000 Stops printing and shows sign "Turn ...
www.fixya.com/support/t21602993-error_e733_0000
Nov 20, 2013 - ERROR E733-0000 Stops printing and shows sign "Turn main power ON". Error ... error message when printing d1350 imageclass. Jan 03 ...
Oct 29, 2015 | Canon imageRUNNER 1133 Laser Multifunction...
Not making copying and show error code no c-0098
Try reset the error code.
Turn OFF the copier,press and keep pressed the Utility key turn ON the copier wait to display appaire the Trouble reset message.Release the Utility key,touch the message and turn OFF the copier.Wait 1 minutes and turn ON.
Mar 26, 2013 | Minolta C350 Printer
Problem with the Samsung Washing Machines The machine keeps coming up with the message HEI 10x
Here is a list of errors for your machine.
I hope they help you.
SAMSUNG WASHING MACHINES, ERROR FUNCTIONS
When an error occurs, the alarm noise will sound and the error code displayed in the program window. Listed below is a series of error codes you may or may not see for your model of Samsng Washing Machine. The errors are shown as blinking in O.5 second intervals until the error status has cleared. In this case, all the driving devices are turned off until the error is cleared.
1. WATER SUPPLY ERROR - Display shows 4E.
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
2. WATER DRAIN ERROR - Display shows 5E.
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
3. OVER-FLOW ERROR - Display shows oE.
Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER switch OFF. Water is drained prior to POWER switch OFF. The tub is drained for 2 minutes if a frequency of more than 25 KHz is detected.
4. UNBALANCE ERROR - Display shows UE.
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
5. WATER HEATER ERROR - Display shows HE, HE1.
HE, HE1 is displayed if the water temperature rises by 7 C or more in 1 Min or by 2 C or less 20 Min after heating process has started. The error can be cleared by turning POWER switch OFF.
6. WATER PRESSURE SWITCH ERROR - Display shows 1 E.
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
7. ABNORMAL WATER TEMPERATURE ERROR- Display shows cE.
e.g. If the water temperature is 50 C or more, during a Delicate or Wool cycle.
At the time of initial water supply, if the water temperature is not appropriate, the display will show cE. This error can be cleared by POWER SWITCH OFF.
8. WATER LEAKAGE ERROR - Display shows 11 E.
Water Leakage error occurs when the water drains naturally, (by leakage) after the washing program starts.
9. THERMISTOR ERROR - Display shows tE
Nov 21, 2010 | Washing Machines
Error message keeps showing to "reset black toner".
Try to reset the toner by taking it out and putting it in again.
Jul 16, 2009 | Ricoh Aficio AP3800C Laser Printer
Configuration error
take the phone back to the service center and explan what is wrong and tell the person to fix it correctly, just like it should have been the first time.
Dec 02, 2017 | Sony Ericsson K310i Cellular Phone
System Error (-1) in my 6670
well, i have , all i do just erasing all the logs, and its back to normal again
Mar 25, 2008 | Nokia 6670 Handheld
HDD error
I get the exact same message.
My camcorder keeps showing this message. Sometimes it works flawlessly but most of the time, this error shows up. What gives?
Jan 02, 2008 | Hitachi DZ-HS300A DVD Camcorder
Error 2
my vhs/dvd combo sylvania shows error 2 how do i fix this
Nov 15, 2007 | Sylvania SRD3900 DVD Player/VCR
Sony Ericsson K310i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
