Question about GE Profile Arctica Stainless Steel Top Freezer Refrigerator
Water spout to ice maker frozen
I have a 5 yr old ge profile artica, side by side. The water spout coming in to the ice maker from the back (left top) appears to be frozen which causes the plug at the back to pop out due water pressure build up. This has never happened before - why should it freeze and what possible solution? Thanks
  • baliran Dec 17, 2008
    what / where is the duel water valve and what does it do?
  • 85 Answers
Defrost ice maker fill tube and replace duel water valve valve for i/m is sepping water
Posted on Dec 15, 2008
  • Steve Hlavka Dec 19, 2008
    duel valve is located behind the refrigerator that supplies water to the door dispencer and ice maker independtly
The electricity went off yesterday while we were gone (not sure how long) and the freezer is no longer staying cold. The ice maker hasn't made any ice and it has melted on top of the other food. We have a...
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | GE Profile Arctica 25.4 Cubic Feet...
Hi there, We are having problems with our ice maker on our GE Profile Model # SRD2054W, purchased October 1995. I know it's old, but it has been a good appliance until now. The ice maker fills but the...
What you think is probably correct. Water valves can seep water and freeze the fill tube. Remove the ice maker and the fill tube remove ice from the fill tube and replace the water valve.
Apr 16, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Me GE Profile PSC23M Side by side ice maker quit making ice and water was on floor behind refrig. Is a water line frozen or clogged or do I have to replace ice maker?
It sounds like you just have a leak at the back. Try swapping the wires on the dual water inlet valve. Then try the water dispenser and watch on the back for where the water may be leaking before it gets up to the ice maker.
Oct 04, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker not making ice GE Profile
First check the temp inside the freezer. If it is not colder that 10 degrees the ice maker will not operate. If it's cold enough make sure the water has not been turned off and that you have water coming to the frige. If you do, inspect the tube where water comes into the freezer and pours into the ice try. See if it is frozen closed. If not, disconnect the water line opisite your water supply on the water valve. Using jumper wires, connect 110v to the valve. Water should come out when you attach the 110v. If not or the tube is frozen that you checked before, either one of these will require you to replace the water valve.
Aug 15, 2009 | GE Profile PSI23NCR Side by Side...
FRIDGE FREEZER SIDE STINKS
That is your problem.
The plastic supply lines over time deteriorate and wind up causing the water to smell.
Replace the plastic line with a stainless steel ice maker water supply line available at any home improvement center. They are 1/4 inch inside diameter lines and fittings.
They come in 5/10 and 20 foot lenghts.
After you do this run about 2 gallons of water through the water in the door dispenser. Discard the first 3 drops of ice from the ice maker.
Your ice quality will improve.
Mar 25, 2009 | GE Profile PFS22 33" Artica French Door...
I have a side by side GE profile Artica refridgerator. The Ice maker is producing, but I cannot get water to come out. When I push the water dispenser, I can hear something happening, but nothing comes...
One of two things. Water solonoid in back defective or water line insideof freezer door is froozen. I just posted a write up about this. Check other response. UJ63
Mar 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not making ice. Water disp inside frig disp water.
the line that gives water to the ice maker, every time the water comes down it lives a drip of water that turns to ice blocking the line, get some hot water and a towel and place the hot wet towel on top of the line intel it melts the ice in side the line. it happens to my frige at list once a year. if that is not the problem the valve that supplies water tho the ice maker needs replacing, it's behind the frige at the bottom, where the line coming from the house meets the frige.
Dec 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Profile Arctica Stainless Steel Top Freezer Refrigerator Logo
585 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
