Question about Gemmy Rocky Balboa Big Head Animated Talking Doll Featuring Sylvester Stalone
Gemmy dueling banjos hamsters repair
This silly gift from a dear friend means a lot to me. These hamsters are connected at the tails, each hold banjos. The "dueling banjos" song still plays fine, but they no longer "strum" their banjos. I emailed Gemmy, no help. Does anyone know how to fix these?
  • Dennis St. Pierre Jul 04, 2013
    I have the same set but can't get mine to turn on. Where is the switch? My email: dspservice@hotmail.com
Replacing fret board on banjo
Can you place a straightedge from the nut to the bridge and measure down to where the fretboard will be ?
Then you could see what is out there to buy or make.
Sep 28, 2017 | The Music
Can i feed my hamster rat and mouse food?
If this was the other way around, I would say it'd be okay for a couple of days. Hamsters have a pretty advanced digestion system and can get bloaty and sick when fed the wrong things. But never fear if you google hamster food you can find some more ''organic?" supplements until you can make it back to your local store. Rats/Mice on the other hand are made to hoard their food. They don't stuff it in their cheeks, although mine likes to sometimes it seems, they like to hide their food. Doing this they burn more energy and need a higher energy/protein diet.
I don't buy rat food, I make my own. I did the same with my hamster too with the store bought mix. Here's a list from my memory you can give hamsters that you may have around the house.
Carrots
Apples
Granola (Good for teeth!)
Cooked red meat (like hamburger meat)
Water Chestnuts
Nuts
Shelled almonds (more fun!)
Bread/Toast (My friend made peanut buttered toast for her hammy)
Fish (fully cooked!)
Eggs (Scrambled/Boiled no fried)
Cheese (in moderation)
Mealworms and crickets (you probably don't have these but for future reference :) )
Dog Biscuits (Try to stay away from some high in protein, and it's good for their teeth!)
Hope that helps!
Jan 04, 2017 | Rodents
Brake fluid leak at front wheel fitting connector
If you mean at the "banjo" fitting where the line connects to the caliper, replace the "Banjo Bolt Sealing Washer" (2 per Banjo Fitting needed).
http://www.jpcycles.com/product/5000250
Mar 31, 2013 | 2005 Harley Davidson FXDWG - FXDWGI Dyna...
May have air in the gas line. where to bleed?
There is no good way to do it. It can be done at the banjo connection on the top of the fuel filter. It is found on the drivers side of the engine compartment just below the air filter. Make sure you get a wrench on the top nut just below the banjo connect to hold the fuel filter from turning while removing the banjo bolt. Place a rag over the fitting to keep gas from spraying all over and something to catch the drips. Once loose you can jumper the B+ terminal with the Fp terminal in the diagnostic connector. Then turn the ignition to the on position and the fuel pump will start running with out starting the car. You may need new copper washers to reseal the banjo connection.
Aug 16, 2012 | 1986 Toyota Camry
Need a new moter model SJD-B2 so we can fix our penquin snow globe. do you carry this so we can order one? 120 volt 60hz 0.442a 3130rpm
My Gemmy blower worked great for a Christmas inflatable. At season end, I packed it into it's bag and into the box. Next season, lights light, but blower won't spin. The motor sounds like it wants to go, but no spin.
I removed the blower base, opened the blower housing (the part where the air comes out. I dropped about a dozen drops of 3M household oil on the shaft , spun it a few times and let it set.
Three hours later, blower works just fine.
I suppose the trick is to oil the shaft before it gets packed away.
Dec 06, 2010 | Gemmy Industries Corp. Airblown 9 ft....
Tail lights out, but breaks lights work
Some tail lights/brake lights have duel filaments. Meaning they use the same bulb for both functions try changing the bulbs.
Aug 27, 2010 | 1998 Lincoln Town Car
I am trying to get a mystery gift on pokemon platnum
Getting to the Mystery Gift option is simple. First you turn on your DS and select Pokemon Platinum. Once it gets to the opening screen, hit start to get to the next menu screen. Scroll down till you see Mystery Gift and hit A. You should see 3 options for Mystery Gift. Depending on the circumstances of the gift, you'll usually need to either acquire it through WiFi Connection or through a Local Area Connection, usually at a Gamestop or Toys R Us or toy/game store that is holding a Mystery Gift event.
Getting a Gift is all about timing. Pokemon Mystery Gifts are time restricted and once it has passed, you cannot get the gift item/pokemon without getting it from a friend who did the event.
Jun 21, 2010 | Nintendo Pokemon Platinum for DS
This is going to sound so silly....., but I am borrowing a friends Lexmark Z2320. How o i find out the ink levels????? Cheers
Once you install the software connected to the printer, it will show the ink levels. And no, its not really silly. Lots of people have this question :)
Thanks
Ranjit www.supportminds.com
Aug 18, 2009 | Lexmark Z2300 InkJet Printer
Gemmy "dueling banjos" hamsters
places to ask or toy repair shops/ toy hospitals and watch makers
Sep 24, 2017 | Gemmy Toys
Gemmy Rocky Balboa Big Head Animated Talking Doll Featuring Sylvester Stalone Logo
349 people viewed this question
Top Gemmy Toys Experts
NOEL
NOEL
Andrew Taylor
Andrew Taylor
Are you a Gemmy Toy Expert? Answer questions, earn points and help others
