Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas
Rinnai RHFE 1001FA
I have an old Rinnai he I have been living with a 1001fa-1 for 4 years and every winter the unit stops working. When activated it clicks a few times and then nothing! I have had to call out repair men every time and it seems to work after what appears to be a filter cleaning. It stopped again today and I have had no luck getting help online or through a service. Where can one find a troubleshooting manual?
  • joebailey4 Jan 14, 2009
    I am not sure if this is the proper way to post clarification or not but here goes. The heater did run but only for a moment (less than one minute). The exhaust port on the outside of the building seems very small and is prone to ice buildup which chokes the heater. I found a manual for a simial model of heater which stated that the heater will cut out for ventilation blockages. I am assuming that is what was happening. I have been working around this by constantly clearing ice from the vent (probably installed with a poor angle on the exhaust pipe!) and taking the front coved off of the unit. This seemed to allow the unit some air and it began to work every time it was activated! This method defeats the filters though and should not be the long term fix. I did clean the filters throughly before resorting to the cover removal but the unit kept turning off. I am not sure how to keep this thing running without this constant supervision.
  • Thomas Hawkins May 11, 2010
    Joe,
    Does the heater run for a while before it quits? If so, how long will it run? Have you ever tried to clean the filters?
    Novelist:
  • 126 Answers
Joe,
If you are having trouble with the flue icing up on the air side, just remove the flex air hose from the back of the unit. It will now **** room air. When the weather conditions change you can hook the hose back up. As you can see the flue doesn't give much space for the air. As far as the front cover, I think you need to clean the circulating fan blowers as well as the screens.
Good luck,
Tom Hawkins
hawkins111@gci.net
Posted on Jan 14, 2009
  • 1,420 Answers
Sounds like a bad gas solenoid. They are not cheap to replace because there are three of them. I would check into replacing it.
Posted on Jan 05, 2009
My Rinnai 1001FA/VA will not come back on after shutting off unless the on/off switch is toggled. I have cleaned the switch and the slide potentiometer and then switched the whole panel with another...
I would first contact Rinnai, parts should be available also I would check the room temperature thermistor normally situated at the bottom rear left hand corner
Feb 17, 2015 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
We have a full tank of propane and the Rinnai RHGF 1001FA and is not lighting. does this unit have an electronic starter or do we need to light the pilot?
Caution This unit does not have a pilot do not try to light with any lighter or match. This unit uses "Electronic Ignition"
Sep 16, 2011 | Heating & Cooling
What is life span of rinnai 1001F propane heater? have had mine 10 years and it continues to shut itself off at night mostly even though just had entire unit cleaned. this happened a few years ago as well...
I often get customers calling about the same issue. I have found that the units have three gas solenoids that tend to heat up and close randomly. I usually chang out all three. Takes about an hour and parts run about $150. If that does not work, you are probably looking at replacing the PC board. The 1001FA/VA models you can still get parts for, the 1001FA-2 models not so.
Mar 30, 2011 | Heating & Cooling
RESALE VALUE
In Vermont I can get 200-400 for this unit. Make sure you include the vent kit that came with it. The new will not fit the old one anyway.
Jan 26, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Can you replace the slider thermostat in this unit with a digital stat? Or Can an wall stat be used? Model: RHFE 1001FA/VA-2
The model you have does not have a conventional thermostat but a temperature probe located at the right hand side bottem in the back. The slider acts like a dimmer switch and communicates with the computer board to cycle on or off.
Jan 01, 2010 | Rinnai Vent Free Gas Heater/
Turns on and then off and back on by itself
I have rebuilt many RHFE-551FA and RHFE-1001FA control circuit boards. If you would like more information about rates, turn around time, etc, please feel free to email me at fcg233@yahoo.com
Thanks!
Jan 13, 2009 | Honeywell Programmable Thermostat Heater
Rinnai 1001FA Energy Saver - Green Light Goes Out!
It is time to replace it. You cannot get some components like the main board.
Dec 15, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnani 1001f Heater not 1001FA Looking for manual
i just had the the same error message and it was the gas line was turned off. it may also be that there were too many gas fumes for it to light. Wait awhile and try again - at least that worked for me...
Oct 19, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai RHFE-1001FA
I can suggest a around-about solution. I also have the same model installed around the same time. I have the outlet that it is connected to controlled by an electric heat thermostat on a wall at the oposite side of the room. I keep the heater on high at all times and the thermostat controls the electricity to the outlet. It's worked great for the 13 years it's been installed.
Mar 11, 2007 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai RHFE 1001FA
i have a rinnai rhfe 1001fa heater and when its real cold sometimes it will shut down all the lights go out and i have to shut it off then turn it back on and sometimes it still wont start and i will leave it of for a day or two then try it and it will work it seems to act up more when its colder i am running it this fall so far no problems this unit is around a 1994 or so and has not given any trouble till this started last winter
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas Logo
585 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
