Question about Panasonic PanaFax UF-490 All-In-One Laser Printer
How do I reset my Fax
I need to reset the access code that my X-wife setup on my Fax nachine
    Sergeant:
  • 284 Answers
You need to do a shipment set on the machine.
press function-7-monitor button "press it 4 time" the the * star key... should say service mode. then press 6 then press up arrow twice "should say shipment set" then pres start then 1 .. it should say initialize now. if it does wait a few minutes and your done
Posted on Dec 15, 2008
I need a access code to recieve a fax
you have a fax machine or you have a fax program on your computer?if you have a fax machine you dont need access code.
Nov 27, 2013 | Brother IntelliFAX 1570MC Plain Paper Fax
Cannot use the fax portion of the copier due to password issues.
There is on department code to control the access of the MFP. For fax function, need to make sure the fax board is installed where ( with RJ11 phone port ) the fax board is an optional accessories.
Mar 30, 2010 | Toshiba e-Studio 350 Copier
Hello my fax machine keeps giving me error codes how do I fix this, I need my fax machine. thank you
Hit the setup button, select fax setup or setup fax, and make sure the option to "Junk" fax blocker is off. The default when you setup the machine itself is on yes. This helped me with my "error 410" message I received when printing fax log.
Mar 15, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Accidentally set the pulse/tone dialing feature to pulse for a Ricoh 4430L. How do I change it ?
Option setting within "Setup" menu (need access code of 2222) allows you to see advanced features not normally viewed after installation of fax machine is completed. Within these advanced features is a parameter to choose analog line setting of either tone or pulse.
Jan 09, 2010 | Ricoh 4430L Laser Fax
When i press hook to receice a fax the message continues to read
Check that the tel line cable is connected to the correct hole in the nachine. It may have been moved. It should be in the one marked 'L' or 'LINE'. Use another fax lead to see if the lead is faulty. Otherwise you may have a faulty LJU board which requires replacement and will cost more if not on warranty, than the machine is worth.
Jul 06, 2009 | Canon FAXPHONE B740 Plain Paper Bubblejet
Mac will not add printer
Hi, try to reset the print system as the apple article below:
SummaryWith Mac OS X 10.4, 10.5 or later, Printer Setup Utility includes a Reset Printing System feature, a troubleshooting function that you might want to use after you try all other printing troubleshooting stepsImportant: This feature should only be used as a "last resort" for troubleshooting a printing issue.
Products AffectedMac OS Printing/Fax (any version)
What does Reset Printing System do?
  • Deletes all printer queues and jobs.
  • Resets all printer settings to their default by deleting configuration files.
  • Performs a permissions check on the /tmp directory.
Any devices that previously appeared in your Printer List and Fax List will need to be added again after resetting the printing system.
Resetting the printing system in Mac OS X 10.5.x
  1. To use the Reset Printing System feature in Mac OS X 10.5.x, follow these steps:
  2. Choose System Preferences from the Apple menu.
  3. Choose Print & Fax from the View menu.
  4. Control-click on list of printers on the left side of the window, then choose "Reset printing system" from the contextual menu. If you don't see a list of printers, Control-click on the text "Click + to add a printer or fax" and select "Reset printing system..."
    As an alternative, if you currently have one or more printers listed, you can Option-click the "-" (Remove printer) button.
Resetting the printing system in Mac OS X 10.4.xTo use the Reset Printing System feature in Mac OS X 10.4.x, follow these steps:
  1. In the Finder, choose Utilities from the Go menu.
  2. Open Printer Setup Utility.
  3. From the Printer Setup Utility menu, choose Reset Printing System.
  4. Click Reset.
Additional InformationTip: If Printer Setup Utility won't open at all (possibly due to your printing issue), you can try to access the Reset Printing System feature directly by holding down the Option key while opening Printer Setup Utility.
Mar 14, 2009 | Apple Computers & Internet
I need to put in access number to fax
Key in fax number press PAUSE twice then access code then start.
Sep 05, 2008 | Brother FAX-575 Plain Paper Thermal
Need to reset savin 3740 fax to factory defaults
Found documentation of Ricoh's website. They are the manufacturor of Savin products. The default access code is 2222. Entering this allowed me to get into the network settings and change the IP scheme.
Jul 25, 2008 | Office Equipment & Supplies
Needs Access Code
on all these machines it is universally ***1
Nov 20, 2007 | Pitney Bowes 9920 Plain Paper Fax
Panasonic PanaFax UF-490 All-In-One Laser Printer Logo
156 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
