Question about Garmin StreetPilot C330 GPS Receiver
Garmin 330 won't turn on. Screen flashes then turns off. Won't even do that if in the cradle.
  • Anonymous Dec 25, 2008
    wont turn on
  • bobnail Dec 27, 2008
    I have the same problem, I pressed the on button (out of the craddle ) it came on, then off. I put it in the craddle, plugged it in, nothing happened. can you help?
I had the same problem. check the three brass connectors on the craddle. mine was missing the middle one some how and did the same thing.
Posted on Jan 08, 2009
This means that the fuse in your car charger is faulty.
To make 100% sure, try charging the unit using the USB to computer connector.
If this works to charge it, you know it's the car charger fuse.
Posted on Dec 15, 2008
My garmin won't come on flashes then goes off
Turn on, Garmin screen comes on, then a screen showing press dot comes up and won't go any farther
does it still happen when plugged into a computer ?
might be a problem with the battery
or it might be a lead connection problem if you are tech minded there are youtube video's that show you how to replace garmin batteries and to dismantle garmins
not sure if this garmin is the right one
http://www.youtube.com/watch?v=zVwMHpNIVjQ
hope this helps
Oct 03, 2012 | Garmin Nuvi 50 LM
Panasonic tc-p60gt30 won't turn on. Something hit screen. Screen did not crack but now won't turn on
May have damaged the PDP (plasma display panel) inside---if the panel which is fragile shorted inside it will trigger shutdown.
Aug 28, 2012 | Panasonic 60 TCP60GT30 3D Plasma TV
My garmin was automaticly flashing differnt modes continously. Now it won,t turn on at all.
whoa, mine just starting doing that too. Today on a run it just started flashing through the 3 screens and I couldn't turn it off. It kept logging the run so I kept going. Then it would stop flashing sometimes during the run and I'd press the up or down arrow and it'd start flashing again. Now it's in the cradle and I can't sync it up but the battery is charging. Any ideas how to fix this?
Aug 10, 2011 | Garmin Forerunner 305 GPS Receiver
It won't turn on and even if i plug it into the computer or a ciagrette lighter nothing happens. it was working perfectly fine when i was using it and now i have absolutely nothing. it kept saying low...
Have you tried pressing and holding the power button for about 8 to 10 seconds? It should go on then off. Then wait a few seconds the turn it on normally. This usually resets the unit.
If this does not work try a hard reset.
Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite data.
Once it gets going update your gps at the Garmin site.
Thanks for using FixYa
Here is a link to the owners manual if needed.
http://www8.garmin.com/manuals/3130_OwnersManual.pdf
Jun 30, 2011 | Garmin nuvi 1450 GPS Receiver
Yesterday i download the forerunner 205 software from the garmin website. after i connect my unit using usb to the computer, my garmin won,t power on immediately. i tried to reset it (soft and hard reset)...
Did you install the software correctly? Because such errors appear usually when the update/upgrade is not finisher or was not done in a proper manner.
If possible try to verify the device on another computer (a friend's) to see if the same problem appear.
If the problem persists I'd say you've burned out your battery (hope not the hole Forerunner...!).
Mar 05, 2011 | Garmin Forerunner 205 GPS Receiver
My BB pearl won`t turn on, first the screen went white
You can re-charge your battery fully by the provide electrical charger for 6 hr , then you can try and send me status.
Jul 22, 2010 | RIM BlackBerry Pearl 8100
Just get white screen won,t turn off
Hold the power button down for as long as you can until you hear drums play.
let go of the power button once you hear the drums.
and see if your device boots up properly
cheers,
Pabz
Sep 23, 2009 | Tomtom XL 330 Car GPS Receiver
My streetpilot c330 won"t shut off.
IT'S CALLED A FROZEN SCREEN...
2 OPTIONS
ONE, RESET IT !!! (See resetting instructions below)
TWO, let the battery die out!
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 12, 2009 | Garmin StreetPilot C330 GPS Receiver
Fritzed Unit when antenna up
I have a similar problem but I can't turn the GPS off at all, even when the antenna is down. As far as the power on/off cycle, I found another link on this site that said to turn off WAAS while the GPS is off then when you turn it on the unit will not power cycle continuously. You loose the WAAS feature but the GPS and unit still works.
Jan 24, 2008 | Garmin iQue 3600 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
81 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
