Question about Pinnacle Studio Plus 10 Full Version for PC
Pinnacle 10 dvd burning
The movie appears to burn. no errors. But there is no image on disk. disk is burnt and ruined but no files, or movie.
Have you tried rendering as an AVI file ... then burning???
also, check the drop down tab to make sure in the "make a disc" section that
there are not 2 listings for the dvd choice ... if there are... then select the second
dvd.. and tell it to burn...
or make the AVI and use Nero 8 or 9 to make the DVD.
my version 10.8 is whacked...
upgraded to 12... it's working fine... finally.
bbell
Posted on Jan 29, 2009
I am trying to burn a dvd from a dvd player using the Dazzle, at the time of the generating the the menu, I am getting the pinnacle instant dvd record error, then the program close! How to fix it?
Program shut down during disk media burning is indication that a device structure encounted malfunction during the process. For example, the computer for an observation should least have any malfucntion. Second the burning compartment as a component part of computer when experince conditon would display notice either as incompartible or least capable attaining an experiece prior to action commencement. Ascertain that the disk medium on which materla it being burned is within standard to capture an impression from the computer. For example, the disk requires the same format as the material requesting burning. Usually DVD device disks are the only media that can create digital movies. Attempting to burn a digital movie on a CD disk or CDR W would least capture response. Also, ascertain that the DVD disk has least been recorded media since is impossible to burn onto a device with media. Also, ascertain that DVD disks are least disinytergral. For example, burining require least scratches or dirt on new disk. If any sccratech surfacese were encounted the computer aborts the process immediatelty to prevent further damage to an enture structure.
Feb 18, 2011 | Pinnacle Dazzle DVD Recorder
When attempting to burn project in MY DVD8 an error appears 800402007 while encoding. I am therefor unable to burn disc
Generally, defragmenting your hard disk will resolve this issue. To defragment your computer:
  1. Go to Start--> Programs --> Accessories --> System Tools --> Disk Defragmenter.
  2. When the Disk Defragmenter window opens, choose Defragment.
If defragmentation doesn't resolve the issue, burn your project as a data file, and then burn your project as a data disc using Disc Copier or Creator Classic. To create a disc image/data file:
  1. After clicking the Burn button, the Burn Project window opens.
  2. You have two data burning options:
    • Image file - this option will save your project as an .ISO file. To burn this file you will need to use the Burn Image option in Creator's Copy section.
    • Folder Set - burning a folder set will create a Video_TS folder that you can burn using Creator Classic. Burning a folder set to DVD will create a fully functional DVD. Do NOT rename the Video_TS folder other wise it will not play! Simply place it in a folder that is the name of your project if you need to keep track.
      Tip: Either of the above options are a great way to not only back up your projects, but make multiple copies to reduce encoding time!
Mar 03, 2008 | Televison & Video
I burned a dvd in Pinnacle Studio Plus 11. I know stuff burned to the DVD, but it won't play on the computer or in the DVD player. Does Pinnacle not finalize the DVD, could that be why it's not playing? ...
Be sure to check if there is a file written on the DVD disk. Try to install a player like VLC and see if the .VOB file is playing.If not the DVD is not burned properly then try to recheck your settings on the Studio 11 Make Movie
Sep 13, 2010 | Computers & Internet
In Roxio Creator 10, I attempt to burn a disk of a slide show. I receive an error message 8004520C When I check production it reports no problem. This is repeatable.
May 25, 2010 | Roxio Easy Media Creator 10 Suite
Pinnacle studio 12 .stx fil
Hi and welcome to Fix yah,
I would suggest to you to finished edit your project and after that click on make movie tab or the number 3 tab of your Studio then do this procedure.
Disc Type : DVD
Audio Compression : PCM
Video Quality : Automatic
Use Progressive Encoding : NOT checked
Always Re-encode Entire Movie: Checked
Burn Options: Create Disc Content and then burn.
Current Media : Should show what DVD Disc should be used.
Target Media: DVD 4.7 GB
Copies : 1
Write Speed: lowest possible
Let me know what happen.
Feb 14, 2010 | Pinnacle Studio Plus Version 11
Cannot burn AVCHD disk. Get this error
The problem with creator 2009 has been fixed by the roxio people.
Instead of burning directly to the DVD disk as roxio software states,
one needs to first save this to be AVCHD movie as a file and then burn directly from the file. This works OK, but as stated this is different
from what the software claims. I'm happy. Thanks
Aug 01, 2009 | Roxio Creator 2009 Ultimate for PC
Can not record dvd movie that is more than 103 minutes in length?
The solution is the quality settings on the DVD settings. On a 4.7Gb disk, 279 minutes at 24% quality, down to 70 minutes at best quality. Also, more will fit on the 8.5Gb DL disks. You can also use automatic quality, that will fit the video that you have compiled onto a disk, using the highest quality setting that will allow it to fit. An alternate method is to 'burn' to an image file on the HD, then use a program like 'DVDShrink' to fit on the disk.
Apr 13, 2009 | Pinnacle Dazzle DVD Recorder
Sony S-300
I had same problem, and fixed it just as per URL link from Wizz.
Apart from following the Sony methodology by the letter:- a couple of things to note:-
1) Make sure you appreciate the difference between a data disk and a burn image. To copy the ISO file you need an image copy of the file, the disk will also need to be "fixated", this is a normal function of most disk burning software but may be prompted as a tick list before you burn the image.
I downloaded burn epress from http://www.nch.com.au/burn/plus.html and it worked fine
2) I got a "No DWLD 09" error after I had put the disk into the player. I tried it several times but still got the error. I solved it by changing CDR disk manufacturer. I was using Maxwell CDR-80's and when I changed to a JVC it worked fine.
Dec 25, 2008 | Sony BDP-S300 Blu-Ray Disc Player
Sense error
Every time i try to burn my home from windows to a Philips DVD-RW a message keeps popping up from my laptop saying that i need to place a DVD-RW cd in which i have done . The funny thing is that i edit my movie from my Pinnacle Studio 12 which i got last week, this was my 1st movie i burned well Pinnacle Studio did it for me really, it was so easy when i took the cd out of my hp pavilion laptop it played on my LITEON DVD Recorder & watched my movie clip on my tv, it worked fine but do you think i do this again NO SUCH LUCK i am really new to all this its so frustrating windows wont burn my move pinnacles not burning, what am i doing wrong, i ve got all new dvd-rw cds is there any one out there who can help me please :-(
Oct 05, 2008 | Computers & Internet
I CANNOT BURN MOVIE TO A DVD
I have had similar messages with Pinnacle 9 (dives you mad :() The solution is to download the latest upgrade version from Pinnacle's website. Pinnacle 11 seems to be bug free.
Jun 30, 2008 | Pinnacle Studio AV/DV version 8...
Pinnacle Studio Plus 10 Full Version for PC Logo
275 people viewed this question
Top Pinnacle Computers & Internet Experts
AL Schehr
AL Schehr
Level 1 Expert
Alun Cox
 Ian Kayhan
Ian Kayhan
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
