Question about MSI Wireless-G RG54G3 Router
Need to change server address???
Hi, Have a small problem with port forwarding, well sort of anyway... When try'n to make virtual server (for windows media encoder) i run into a problem... I have all LAN PC's w. addresses 192.168.11.** but the router only allows 192.168.1.** ??? Where i cannot change the last two, but only one no.? Am I missing something here or is it impossible to change this... I've gone through the whole manual, but nothing...? :( Any help is most appreciated! Thanks in advance! Sten
  • Sten Millend Mar 15, 2007
    Thnks man, exellent...!
    Cheers...
    Sten
    President:
  • 2,961 Answers
You have set an unusuall ip address of 192.168.11.**, normally 192.168.1.* or 192.168.2.* is used. You are better off letting your router assign ip addresses by enabling DHCP. Go to your network cards properties and enable obtain ip address automatically. Restart you pc so as to find the ip adresses from the router. When they are assigned you will then be allowed to open the required port on your pc's IP address, but obviously 192.168.11.** is not an allowed address.
Posted on Mar 15, 2007
    Problem Solver:
  • 10 Answers
Hey , ya have 2 solutions first ya assign static i to all comps with the range 192.168.1.2 n 3n 4 like on. OR second solution is : ya log oninto the router with hard wired connection thru ethrnet cable, open browser , type the ip of the router , go into it , then select "LAN OR IP SETTINGS" it will show ya the routers ip as 192.168.1.1 chnage it to 192.168.11.1 n start ip add will be 192.168.11.2 last/end ip will be 192.168.11.254 n save the settings. if both things dont work then you need to upgrade the firmware which ya can download from the respective site of product manufacturer. before ya go for firmwware ya need to confirmed of this issue , or talk to me with the results.--- take care - samrat
How can i configure aip w505 for att elevate internet, in order to view my qc dvr
You need to enable the virtual server settings on the AIPW505
You also need to allocate a static address to the DVR within the range of the DHCP address range.
Virtual Server Settings - Selects between enabling or disabling port
forwarding the virtual server. (Default: Disable)
? IP Address - Specifies the IP address on the local network to allow external access.
? Port Range - Specifies the port range through which traffic is
forwarded.
? Protocol - Specifies a protocol to use for port forwarding, either TCP,UDP or TCP&UDP.
? Comment - Enter a useful comment to help identify the forwarded
port service on the network..
The manual can be obtained from here
ALFA NETWORK Inc
Oct 21, 2012 | ADVANCE Alfa AIP-W505 802.11n/b/g Wireless...
Tip
Virtual Server / Port Forwarding does not work from within the Local Network
When you use port forwarding in Virtual Servers and try to test it from within the local network, it may fail. When for example, port 80 is forwarded to a web server in the local network, you may get the router's home page instead of the web server's one or you may get nothing at all. When you try to use the server from outside the local network it will work fine though.
This can happen when you try to access the router's WAN IP address from within the local network. In order for port forwarding to work from within the local network, the router needs to support a feature called NAT loopback. This is not a part of the specification of Belkin routers and modem-routers, so most of them will not have the feature, and if a router does have it, it is not supported.
In order to use the server from within the LAN, you can address it by its internal LAN IP address (e.g. 192.168.2.101).
If the WAN IP address has a DNS host name associated with it, such as www.example.com, and you need to use that name to connect to the server, you can do so by associating the name to the local IP address in the hosts file (a file called hosts with no extension). This file lists IP addresses and host names and is used before actual DNS lookups are done. You can add lines to the hosts file using a text editor like Notepad on Windows. The lines look like:
192.168.2.101 www.example.com www.otherdomain.com # comment
The lines contain an IP address and one or more host names separated by white space. Anything that follows a hash sign is a comment and will be ignored. You will need to change the hosts file on all machines in the LAN that need access to the server.
On Windows, the hosts file can be found in C:\Windows\System32\Drivers\Etc on Windows XP, Vista and Windows 7, in C:\WinNT\System32\Drivers\Etc on Windows 2000, and in C:\Windows on Windows 98 and ME. You need to have administrator rights to edit the file; on Windows Vista and Windows 7 you need to run Notepad as administrator.
on May 05, 2010 | Computers & Internet
My router ( di 524 ) is blocking servers in Bettlefield Heroes, how can I fix it? I know the ip and port of that server.
1. Open a web browser like internet explorer or Netscape. Enter the ip address of your router in the address bar of your browser. In the picture above the address bar has http://www.google.com in it. Just replace all of that with the ip address of your router. By default the ip address should be set to 192.168.0.1.
2. You should see a box prompting you for your username and password. Enter your username and password now. By default the username is admin, and the password is blank. Click the Ok button to log in to your router.
3.Click the Advanced button near the top of the page. The menu on the left should change. In this new menu, click Virtual Server.
4. We will list a series of lines here that will show you exactly how to forward the ports you need to forward. Battlefield heroes requires you to forward the ports you entered above. Go ahead and enter the settings shown above into the Virtual Server menu and then click Apply.
fill up the blank boxes
Private IP : ip address of pc where you play the battlefield
Protocol: both
Private port: ( provided by battlefield tech support)
Public port: ( provided by battlefield tech support)
schedule: always
then click appy
Jul 11, 2009 | D-Link AirPlus DI-524 Wireless Router
Unable to ftp from outside of the network. Went through all of the port forwarding setup. Still can't connect.
You need to setup a Port Forwarding / Virtual Server (FTP) in the router to forward port 21 (FTP default) to your FTP server's FTP port. You may need to setup a reserved IP address for the FTP server first in the router before the option comes up.
May 27, 2009 | D-Link DIR-625 (790069292637) Wireless...
Can't open port to uTorrent
virtual server also known as port forward, try to look for this phrase, if not u may also find some word with NAT or Nat table.
Anyway routers must have this function in general.
By the way, how did you make your ip static, manual from your mac or the routers'?
Nov 23, 2008 | Computers & Internet
Ftp server
What is the name of the software? Is that an FTP software?
Anyway if you are using DX-E401 Router you can enable DMZ (demilitarized zone) to your PC.
1.access your router configuration page (default ip: 192.168.0.1)
2.go to advanced tab
3.select DMZ
4.select enable then type the ip address of your server pc
5.apply settings
after that have someone try to access the files in your pc.
if the software you installed is ftp software then have them access it by this
ftp://internet_ip
the "internet ip" is the ip address found in the STATUS TAB of your router under the WAN catergory.
If this software you mentioned is using any particular application ports, you will have to open those ports for your server PC.
In that case you will to configure VIRTUAL SERVER. It's the actual term used by dynex. for you to have a general idea how to configure your pc behind your router please go to this link
http://www.dynexproducts.com/skins/skin_1/Topics/Documents/DX-E401_Manual.pdf
Virtual server configuration is in pages 22-23. It has detailed explanation of the terms used.
Hope this helps!
May 07, 2008 | Dynex DX-E401 Router
Belkin router F5D7230-4
Not sure wanting help to download illegal music is available here.
Jan 07, 2008 | Belkin (F5D72304F5D7000) Router
How do I open ports in the Virtual Server?
You need to forward the ports used by the application to the server running the application in the Virtual Server, which is present in the router's management screen, as follows. 1. Open your web browser, type in the router's IP address (standard: 'http://192.168.2.1') and press enter. 2. Click on Login, Advanced Setup, NAT, Virtual Server. 3. Enter the port details and enable it as follows: Private IP Private Port Type Public Port 192.168.2.x xxx TCP xxx 192.168.2.x xxx UDP xxx
Feb 19, 2006 | SMC Barricade 7004
Feb 19, 2006 | SMC Barricade 7004 Router
Configure the firewall
You can use the Virtual Server to forward an individual port to one of your computers. You cannot forward the same port to multiple computers. In order to configure the Virtual Server you need to know the IP address of the computer that needs the port opened and the service port number. The links below will help you find the IP address of your machine. If you don?t know which port needs to be opened, try checking the software manufacture?s support website for information on use behind firewall. Configuring the Virtual Server: Step 1 Access the device configuration by entering 192.168.0.1 in your web browser. Login with your username and password. The default username is admin and the password is blank. Step 2a If the port you need to forward is a common port, it will be under the predefined virtual server list at the bottom of the page. Click the pad and paper icon next to the virtual server entry you want to use. The Protocol Type and Service Port fields are preconfigured. Click the Enable radio button to use the virtual server. Enter the private IP address of the computer that will use the service port. Configure the Schedule as needed, then Apply your settings. Step 2b If the port you need to forward is not listed under the predefined virtual server list at the bottom of the page, you can create a new entry for your application. Click the Enable radio button to use the virtual server. Give your virtual server a name. Next, enter the private IP address of the computer that will use the service port. Then, select the Protocol Type and enter the Service Port. If you don?t know how to use Private and Public port assignment, then just enter the same port number in both fields. Configure the Schedule as needed and Apply your settings.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
MSI Wireless-G RG54G3 Router Logo
75 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
