Question about Kenmore Washing Machines
Smells like rubber burning
Replaced motor coupling now i smell rubber burning and a high pitch squeel that comes and goes i disasembled again and its coming from the water pump side of the motor i also have back and forth play in the shaft
  • flyingtarzan May 11, 2010
    have your ran it with the water pump off the motor
  • 145 Answers
Hi and welcome to FixYa!
First thing to check is to make sure that you have pressed the couplings on the motor and transmission shafts all the way on to the point where the metal ring on the new coupler is totally flush with the shaft. If you do not do this, you will get a binding condition.
Another is that some people really pound on those couplers to get them on, and this can damage the bearings in the motor. First do as I outlined and make sure the new couplers are on all the way, and is the noise does not go away remove the coupler altogether and re-install the motor and listen for the noise. if you ruined your motor, you will know. FYI that motor is not servicable; it will have to be replaced. The way I install those couplers is to use a deep socket that closeley matches up with the metal ring on the new coupler (you may have noticed the old one had no ring) and tap it LIGHTLY to get it to seat on the motor shaft and tranny shaft.
Hope this helps you..!
Posted on Dec 14, 2008
Fridge has a burning smell
Are the coils clean by the compressor?
Nov 26, 2012 | Frigidaire FRS23R4A Side by Side...
Washer wont spin, smells like burning rubber
The burning rubber smell is coming from the belt which goes around the drum and is driven by the motor. The belt has probably stretched and is now slipping. It will need to be replaced.
Jul 13, 2011 | Washing Machines
I own a FP dryer model DE08-US1, and it is making a high-pitched squeking noise and smells like burning rubber--please help.
I suspect your drive belt is slipping or a worn bearing, you need to have this checked by a Qualified serviceman. Get a firm "Quote" before proceeding.
Jan 31, 2010 | Dryers
Vacuum smells like rubber burning. Replaced belt. same result
My vacuum's belt fell off, So I fixed it. Two days later my vacuum wouldn't turn on, so I opened it up again and took out a dust ball in between the electrical wires. I turned it on and sparks and snapping sounds came form the motor. Also burning rubber smell, What wrong? Is my vacuum fixable?, or should I buy a new vacuum?
Jan 15, 2010 | Oreck XL2000 Bagged Upright Vacuum
Motor Pulley Squeeling - Maytag MDG5500AWW
try spraying wd 40 on the motor ends to see if it will stop if not try the rollers normally they go bad and make the belt squeel.
Jun 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Burning rubber
hi! we have read your problem at Fixya! since you have specified that it smells like burning rubber, the belt connecting the motor and the tub accelerator might have been wearing out.this is a problem which occurs when you overload the motor frequently.if you get the smell continuosly, open the cabinet and get the replaced.hope your problem is tackled.have a nice day
May 25, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing machine spins slowly and smells of burning rubber
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
Apr 21, 2009 | GE WBSR3140DW Top Load Washer
Washer makes a squeel and burning smell
belt which operates pump/motor/transmission pulleys
Apr 10, 2009 | Washing Machines
Washing Machines Logo
67 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
