Question about Apple 2.16GHz iMac Intel Core 2 Duo DVDRW/CD-RW Desktop PC Mac Desktop
Optical drive failure
My internal dirve immediatle ejects dvd's and cd's. Not recognising any type, either media or blank. I need to upgrade to Leopard and need the drive to do this. Is the drive finished? Any Cheap external alternatives? Or are there any do it yourself fixes to the problem?. The drive is a : PIONEER DVD-RW  DVR-K06
thank you in advance
  • 60 Answers
Try to clean the lens maybe you dont use it frome some time and there need a lens cleaning if no just change it with new one
Posted on Dec 14, 2008
DVD drive recognised but disc not recognised
not sure how its recognised on control panel
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Apr 05, 2012 | NEC MultiSpin ND-1300A (ND-1300A)...
My acer aspire cd/dvd rom wont recognise blank dvd
You might need to replace the optical sensor...
Hope that helps! Please rate my solution
Nov 14, 2011 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
I have never burned a CD. I have need of burning two tonight. What do I do?
are you burning a cd or dvd? burning a cd is pretty easy...windows will do most of the work for you. put a blank cd in your cd rom/ dvd burner drive. it will ask you what you want to do with the blank cd...vista usually asks you to format the disk...select ok.....a blank box will pop up....drag and drop your files to be burned into the blank box.....once you are done putting your media onto the disc....eject the disk...before the drive opens a box at the bottom of the screen says that the disc is being prepared for use on other computers. when it ejects, it should be done....you can try to put it back in to the cd drive and see if your data/media files are on the disc. ......now burning a dvd is alot more complicated....do you have software for burning dvd media? if you do, they have help me files and tutorials........some more good advice....youtube also shows good tutorial vids on burning. just type in "burn a cd or dvd".
Oct 12, 2010 | Computers & Internet
0F00:136C IDE device failed:blank media or no media is present in optical drive
read failure of the CD\DVD drive. If you were running diagnostics and have no readable media in the drive, that is a NORMAL result.
If you have readable media in the drive, try reseating the drive and try to read again. If the media is not a factory burned CD, try a factory burned one.
See if you can boot to an Windows CD.
If all the above fail, then likely a drive failure, replace the drive
http://cgi.ebay.com/Dell-Inspiron-E1505-6400-6000-E1705-DVD-RW-DVDRW-Drive-/170505381668?pt=PCC_Drives_Storage_Internal&hash=item27b2e9a724#ht_3121wt_1137
Sep 25, 2010 | Dell Inspiron 6000 Notebook
Using acer aspire 5315.. cd rom recognises cds but will not burn onto blank cds or recognise blank cds, laptop ued to burn cds, and not doesnt.
Are you able to read CD's and DVD's using the Optical Drive ?If yes, then it may be a problem with the lens in the drive.It can also be an issue with the software that you are using to burn Cd's ( like Nero ).If you are not able to Read and write Cd's or DVD's and the Optical drive isnot listed in " My Computer" then it can be either a driver issue or registry filters issue.Let me know abt this
Jun 29, 2010 | Acer Aspire 5315 Notebook
The DVD/CD drive on my Medion 8830 PC no longer burns
Have you changed or upgraded your OS recently?
Looks like the drivers are corrupt or out-dated.
Might go to your computer mfg support site or the Drive mfg support site and download the latest drivers.
Uninstall whatever drivers are loaded reboot and reinstall fresh copies.
Nov 21, 2009 | Computers & Internet
Dvd drive is not reading and also ejecting out !
Hi
I would simply recommend replacing the drive as it sounds like the optical lens is shot in it.
Taz
Oct 30, 2009 | Dell (0F146) Internal DVD Drive
LG GCA-4080N internal drive
It seems that what you have is a combo drive only :(
it only recognize DVD reading. no matter what driver you used. need to buy a dvd writer/ that said can write dvd.
Types of Optical Drives and CD/DVDs
Optical drive type Read from CD/DVD-ROM media Write to CDRW media Write to DVD ±RW/R media Write to DVD +R DL media Write label to LightScribe CD-RW Write to DVD-RAM media DVD-ROM Drive Yes No No No No No DVD and CD-RW Combo Drive Yes Yes No No No No DVD±RW/R and CD-RW Combo Drive with Double- Layer support Yes Yes Yes Yes No Yes LightScribe DVD±RW/R and CD-RW Combo Drive with Double- Layer support Yes Yes Yes Yes Yes Yes Blu-Ray Disc DVD±RW SuperMulti Drive with Double-Layer support Yes Yes* Yes Yes No Yes *Low speed (4X) and high speed (4-12X) are supported. UHS-RW (24X and 32X CD-RW) is not supported.
NOTE: Some of the optical drives listed may not be supported by your computer. The listed drives are not necessarily all of the supported optical drives.
Dec 26, 2008 | LG (GCC4521BBULK) CD-RW/DVD-ROM (Combo)...
My internal optical drive spits out dvd's and cd's.
When rebooting press and hold the Alt key until it displays all bootable drives. Now insert your disk. If it works install Leopard from here. If not then your drive is dead or faulty and needs checking or replacing.
All the best
Sean
PiDigital
Dec 14, 2008 | Apple 2.16GHz iMac Intel Core 2 Duo...
Apple 2.16GHz iMac Intel Core 2 Duo DVDRW/CD-RW Desktop PC Mac Desktop Logo
368 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
