Question about Mitsubishi WT-42315 42" TV
Color ghosting on left side
Mitsubishi WT-42311, purchased 11/2003. Just recently the set has started showing 3 colored ghost on the left 6" of the screen. It looks like the problem of an unshielded speaker, but no speakers have been moved or added. Is the internal speaker possibly loose and causing the ghost? It also won't turn back on when it is "hot", auto shut off when attempting to turn it back on. Thanks Braveheart
The IC's for your convergence sounds bad, they might need to be replaced
Posted on May 19, 2007
    Novelist:
    Champion:
  • 236 Answers
A magnetic field such as would come from a speaker might cause the ghosts but would not stop your set from coming on when it's hot. You may have a horizontal deflection problem such a bad flyback transformer or some other component that gets worse with temperature. You need to have it checked out by a technician. Stargazer
Posted on Mar 17, 2007
Red color shifting and ghosting on my wt-42315
Tv have a problems known as a convergence picture problems,it is dead.Tv have R,G,B colors lines mis alignments,have colors pictures shadows or 3D pictures look alike?Yes,than the tv convergence board have dead parts like 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board must have be replaced to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jul 07, 2011 | Mitsubishi WT-42315 42" TV
Color allignment on a Mitsubishi WT-42311 42in Rear Projection
You will need to replace the two stk-392-110 convergence chips this model uses. This can be a do it your self job if you have some skills.
This model has a light box which contains 98% of the set's inner parts. With it removed the chips will be easy to locate.
Total parts cost on EBAY should be under thirty dollars and repair should take about a hour or so.
YOU will need to be able to solder as the chips have 18 pins each.
If you think you can do it I can tell you how to get the light box out and proceed with the repair; this model has very few problems and a good picture.
You will also need to have the Mitsubishi remote to correctly adjust after the fix.
Let me know what you want to do--I am here to help.
SD TECH
May 07, 2010 | Mitsubishi WT-42311 42" Rear Projection...
Picture has colored ghost on the both sides of screen
Wt-46-809, if convergence is skewed and comes and goes, uses two of the STK-392-570 CONVERGENCE IC chips.
I have seen a lot of the Mitsubishi sets that use these two chips where the convergence jumps in and out. You need to replace both chips and adjust the set.
You can buy a pair of the chips on EBAY for less than 13 dollars plus shipping.
I HAVE START TO FINISH, STEP BY STEP INSTRUCTIONS FOR THIS REPAIR IN THE SETS THAT USE THESE TWO CHIPS.
If you or someone you know can do the repair you can save the set and a lot of money--most shops are going to get at least 300 for this kind of repair--I know as I have done hundreds of them here.
The instructions tell you everything you will need and how to do the repair. I have helped many people here do this based on my instructions.
If you want the instructions let me know and I will either post them here or send them to you.
If this information has helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 30, 2009 | Mitsubishi WT-46809 46" Rear Projection...
GHOST/MULTIPLE IMAGES AND COLORS ON MITSUBISHI WS55807 PROJECTION TV
In the menu ,,under settings usally ther a convergenge option,,what it does is realine the colors,, that should do the trick,,if your tv has that ,,good luck
Oct 05, 2008 | Mitsubishi WS-55807 TV
Mitsubishi WT-42313 42 in. rear projection tv
I guess I have to pay money for a solution, which is not what this website says. The only answer I got was pay money and we'll tell you. Is that true/
Sep 16, 2008 | Mitsubishi WT-42313 42" Rear Projection...
HP 2600 ghosting
It is a massive pain but a solution that worked for me is to run a 'clean' after every card stock sheet. I know it's wicked awful but it actually worked and I had to run 100 times (one for each good color card stock)
First put plain paper in tray 2
Next
Hit left arrow until you get to 'system service' and press green check
Next
then go to 'clean' and press check
Now it should print a clean image without ghosting
May 29, 2008 | HP Color LaserJet 2600n Printer
TV is Ghosting
if convergence problem color would be bowed and off. If it is the convergence replace ic stks there are 2 inside tv if you could solder and good at this stuff. parts cost is 30.00 . if you are going to get fixed cost is 300.00 . www.part store.com has parts just give them model number .They can tell you part number.I would pay someone to do this it is trickey.
I think ghosting is ground problem on cable connections check connections and replace cable wire.
thanks doctor video
May 18, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Colors properly aligned in HD but non-HD, or vice versa
you have to make the alignment for all 3 formats....standard....1080i...and 480i
Apr 29, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Big screen showing double and red ghost color
Go into your service menu and try to adjust the convergence, if it does not adjust, the IC's ( chips) are bad in that circuit. Call a local factory authorized dealer to service your tv. The cost should run around $450.00. Good luck.
Mar 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WT-42315 42" TV Logo
134 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
