Question about Bosch 23 in. SHU33A Built-In Dishwasher
Bosch SMS 6032
Hi, I think this is an older model, so I was not able to find it on the site. I am unable to start the programme. When I select the programme all is well, and the door closes OK. However, when I push the start/stop button, it does not "click" in, and so the dishwasher does not start. Is is a problem with the switch - or am I missing something here? Millions of thanks, Rugger
  • 944 Answers
If you can make it run by holding the switch in, then the problem is with the switch, else it is almost certainly a control board issue, although it is probably worth checking all the connections to the control board/switch just in case. Sorry had no luck with a manual, although for older models if you get in touch they claim to supply: You can order most original instruction manuals through Bosch UK Spares Department. We are open Monday to Friday from 8:45am to 5pm: phone: 08705 543210 fax: 01908 328650 e-mail: mks-spares@bshg.com Hope this helps, if not please post again :)
Posted on Mar 16, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Mar 17, 2007
    sorry should have said "they are open etc..." -no connection with me or fixya.com
How do we put it through a test mode?
Here you go, both answers :>)
Bosch Dishwasher Troubleshooting Your Bosch dishwasher can run a test cycle which will quickly go through each stage of a wash programme in order to find out at what point a fault is occurring. It will only give you a general idea of where the problem lies but is a useful first step in diagnosing the issue.
The steps to start the test cycle vary depending on what model you have but the basic method is similar across the range. It might be that your dishwasher doesn't have the same button labelling as described in the steps below. In that case try holding down the buttons which have similar names. After a little trial and error you'll find the right combination.
  • Make sure the dishwasher is switched off.
  • Press and hold the Power Scrub Plus and Regular Wash buttons.
  • Turn on the dishwasher, then release the two buttons.
  • The light above each of these buttons should flash.
  • Start the test cycle by pressing the Power Scrub Plus and Regular Wash buttons again.
  • The test programme will begin and an error code will be displayed at the end of the cycle if a fault has been detected.
You can find a list of Bosch dishwasher error codes and their definitions here.
Error Codes are also here;
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/dishwasher-fault-codes/3058-bosch-sms-series-dishwasher-fault-codes.html
Sep 30, 2015 | Bosch Dishwashers
Unable to get ac compressor to start
HI,
you may get a pdf download of the manual form this site Programmable thermostats at discount prices at hunter-thermostats.com.
they may have the model you require .
Goodluck,
Please don't forget to rate the solution
Apr 23, 2008 | Hunter Fan Company 5/1/1 Programmable...
It is a Bosch WFF2000. The programme stopped mid
circle at bottom right take it off there is a filter there remove it and look of obstructions.WATER WILL POURE OUT!
Jun 23, 2010 | Washing Machines
Samsung J700 I am trying to move my sms messages to my Memory
I am trying to move my sms messages to my Memory card but am unable to do so. Can any1 help.
Hand set Model is Samsung SGH J700i
Apr 15, 2010 | Samsung J700 Cellular Phone
Have a xksstel x12 phone. I am unable to receive some MMS depending on the file size. How can i get more free space or change something to receive MMS's? I also am unable to send any ''predefined...
you cannot do anything just use the mms format like that it is inbuilt programms,sms cannot use multimedia tools ok animation is always for mms ok
Jul 11, 2009 | Cell Phones
Text messages cannot be sent
I have been having the same problem with my P3300. I finally found a solution that worked for me. Here are the steps.
Go to:
Start menu
Settings
Connections Tab
SMS Service Icon
Then set SMS over: to gsm preferred
I was then able to send and receive sms with no problem.
I hope this helps out. Post back and let me know if this worked for you.
Sep 28, 2008 | HTC P3300 Smartphone
Bosch WFL 2872 washing machine has just started beeping (3 beeps) at approx 1 minute intervals at end of program until I turn machine off. washer is 3 years old & has never done this before - does it...
A similar thing happened to mine. I think it starts when there is a power cut or something similar mid cycle. The solution (which you would never guess!) is the following:
Select any programme - say 30 Cottons
Press and hold any function button - NOT Start Signal will sound at varying levels - release button when it gets to the level that you want, off in your case. De-select programme Good luck!
Jul 24, 2008 | Washing Machines
Facing problem in reading SMS
wot version of OS??
suggest: soft reboot- press home and power button for 10 secs.
lemme know.
if not working then probably restore.(b careful wid reboot, 'coz its gonna lock ur phone )
Jul 24, 2008 | Apple iPhone Smartphone
Forwarding sms on iphone
connect it thru wifi and download SMSD APPLICATION or iSMS AND DEN U cn forward msgs
enjoy
May 23, 2008 | Apple iPhone Smartphone
Bosch 23 in. SHU33A Built-In Dishwasher Logo
819 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
