Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Kenmore Side by Side Too Cold
My Kenmore elite side by side Model 106.53606202. The Freezer maintains a constant -20 to -30 deg F. regardless of the temp setting. The fridge maintains as is set.
When the Freezer defrosts, it is so cold inside that it creates a sheet of ice in the bottom of the freezer. because it can't drain I have already replaced the Temp Control board... no change
  • mericks1 Feb 02, 2009
    I have the same issue. Kenmore Elite 106.53606202 freezer runs way too cold (-20 to -30) no matter what the freezer temp control is set at. Solution???
5 Suggested Answers
  • 363 Answers
SOURCE: whirlpool freezer not freezing
The fan speed can be deceptive. That is why this problem is so hard to diagnose, when the fan starts to wear out the motor spins but not with enough force to circulate air thru the freezer and rrefrigerator. If you have the ability to swap out the fan motor then it should only cost you the price of the motor and components. Approx. $125.00 if you have the make and model you can go to appliancefactoryparts.com or appliancefactorypro.com to obtain motor and components, But if you have to get serviceman to replace fan it will cost you an hours labor also.
Posted on Jul 28, 2009
heatman101
  • 43501 Answers
SOURCE: bottom of fridge and freezer cold ice maker not
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Nov 28, 2010
heatman101
  • 43501 Answers
SOURCE: Freezer side is cold and
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on May 11, 2011
heatman101
  • 43501 Answers
SOURCE: 5 year old whirlpool fridge/freezer
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
heatman101
Posted on Jun 12, 2011
Kenmore elite coldspot model 106.74219400 freezes in the fridge never gets above 5 or 10 degrees and it never shuts off.
there is a flap in the refrigerator side usually near or behind the light bulb the freezer side is thermostatically controlled with the compressor being controlled. On the refrigerator side the cold air comes from the freezer side. when this flap is open the refrigerator will cool continuously, Check the flap or the duct assembly
here is an illustration of the part
http://www.repairclinic.com/Kenmore-Refrigerator-Model-10674219400-ID-927868-Duct-Venting-Parts
Apr 14, 2013 | Kenmore Refrigerators
Kenmore/Elite Model 795.7756,7757 Trio: Bottom Freezer Door won't close. The latch or hook at the bottom corner of each side will not hook in.
We have a kenmore elite refrigerator modle number- 795 7756,7757 and it has been making a humming noise very constant now after two weeks, what could it be?
Sep 18, 2010 | Kenmore 77554 / 77543 Bottom Freezer...
My kenmore elite side by side is making a buzzing
The buzzing noise is likely coming from the main power board and will need to be replaced.
Nov 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer @ +28 deg/appears common problem B 1st 2 answer right....
Model numbers of Kenmore , starting with 253. are made by Frigidare . The compressor probably has a valve out , either the high-side , or low-side . Probably the low-side valve is bad , therefore , the high-side will pump but not get the freezer as cold as it should be . Both sides have to work . Low-side helps pull the refrigerant thru the system , while the high-side pumps pressure thru the system .
Aug 26, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
2001 GE side by side refrigerator model TGX26KRDA WW Beginning about a month ago the refrigerator temperature rose to 60 deg. F. Freezer remained well below 0 deg F. Checked baffle which was open and...
Is the fan that moves the air from the freezer to fridge running If there is a switch in cabinet somewhere the freezer door would contract it, with door open push in switch hear the fan both are good. Don't hear fan check evaporator or freezer fan and that switch it may be a duel switch open light closed fan run. Tricky there are light switches, when out light on or when switch is in its lights out
Mar 17, 2017 | GE Refrigerators
Kenmore side by side refrigerator model 106.56532400
Thanks for taking this question.
Kenmore 22 cft side by side does not have air circulation. Freezer is cold at the bottom (ranges 5-45 deg from bottom to top). Refrigerator section is 30- 60 deg from bottom to top. Thermostat is good; compressor is working; no ice deposit on the evaporator coils; condenser coils have been cleaned; defrost heater is working. I do not feel the air draft I used to notice whenever opened refrigerator door. Is it possible that the air recirculation fan not operating. Location of this fan in the refrigerator? Regards, Prem
Feb 19, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
Jun 20, 2007 | Kenmore 44109 / 44102 Side by Side...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
47 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
