Question about GE 24 in. GSD4030Z Built-in Dishwasher
GE dishwasher
Cycle knob doesn't automatically move from one cycle to the next...seems to be stuck
    Problem Solver:
  • 5 Answers
If you can move the timer manually, then check the power to the timer motor. If you have power to the motor, replace the motor
Posted on Dec 03, 2009
My washer will not switch from one cycle to the next
I understand that your washer is not advancing and stuck on one cycle. If you provide a Model and serial number, it will be helpful.
Jul 22, 2016 | Washing Machines
Hi my washing machine works perfectly fine but the water don't pump out srew out bottom filter is clean and I clean it on a regular basis. Defy 1300 laundromaid. Thanks please help
You probably have a rock or some object stuck in the pump blades. Take out the pump and turn the blades get out the obstruction
Nov 26, 2014 | Washing Machines
The knob just spins round and doesn't catch. It received a bash and it now won't accept a wash cycle. Any thoughts?
It seems that the timer has failed and needs a replacement. If this seems to turn around without clicking and if there is no action when the program cycle is initiated, this seems a failure of the timer controller unit. This happens in cases when it is turned around in reverse order or violently.
Jan 14, 2013 | Zanussi Washing Machines
Frigidaire washing machine gets stuck on cycles
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Apr 01, 2009 | Frigidaire Washing Machines
Washer only works by manually advancing the dial.
yes this sounds like a timer it sounds like it is getting stuck in the cycle. replace the timer and this will clear up the problem
Dec 29, 2008 | Maytag SAV3710AWW Washer
Timer stuck on cycle will work if manually moved
The timer has a small motor that advances it through the cycles. It either works or it's DOA. unfortunately you probably have to replace the timer complete.
Nov 01, 2007 | Roper RAS8445KQ Top Load Washer
Dishwashers Logo
146 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
