Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
I have a 53 in rear pro, Panasonic T.V. that I can't seem to get the Conversence correct with the remote. Anyone know how I could fix this by my self, (Well with help from some of you guy's) Thanks CJ
  • bdavis613 Dec 22, 2008
    the picture has double images and when i try to adjust the convergence on the green line, it will only move so far, same with lining up the red and blue crosses. it will only let me line them up so far.
  • 585 Answers
If that has worked for you before, but does not work now it tells me that you at least know how it is supposed to work. If it seems the adjustments just don't respond, or not have enough range, it tells me the convergence amplifiers have failed. They are located on a circuit board and are screwed to a large finned heatsink also attached to the board. They should bear a number such as STK392-110. That numbered part is replaced by an improved type STK392-150 or STK392-180. When that part dies it will also usually burn out a resistor. Typically a 1.0 - 2.5 ohm 1-watt flameproof in the convergence yoke return path. The resistor must be the same value as the original or the convergence will not respond correctly.
Posted on Dec 16, 2008
Horizontal output transistor for panasonic pt-53tw53
I would say between $150 to max $200. When this guy fails its due to other components in the vicinity, have a pro do it.
Nov 15, 2011 | Panasonic PT-53TW53 53" Rear Projection...
Does anyone know what a "d" board is for a 53 Rear projection Panasonic Tv? If so, where can I get one and is it hard to repair on my own?
The D board is the deflection power board the power cord goes to ---not available from Panasonic.
For me to help I need to know what set does or does not do.
This model has a error code, if it tries to turn on and shuts off the power light blinks a sequence---like 3 blinks, pause or 5 blinks pause.
The more you tell me the better I can help.
Sep 29, 2010 | Panasonic PT-53TW53 53" Rear Projection...
Eaglestar pro 53-0305 / nFusion HD codes
i have eaglestar receiver. i watch hindi programs. since jan/09 its not working. people tell me to buy new receiver and new dish. what should i do?
Sep 12, 2009 | Universal Remote Control Remote Control
PT-53WX42 53 Blue curve problem
If you've already replaced the convergence IC's and confirmed the coolants in each tube are filled, you probably need a factory level convergence done.
The procedure is 18 pages long and requires a NTSC pattern generator to do correctly. You need a funtional remote. Personally I'd recommend finding a well-trained tech to do it for you. Takes
about 2 hours to do both 480 and 1080 modes. Anyone who tries to do it from home without equipment is asking for headaches. It's hard enough to do in our shop... (were factory service for Matsushita)
You might get away with a minor touch-up for any particular area, but going into the factory-level setup mode without knowing what you're doing is not recommended - you may find yourself replacing the EEPROM.
Good luck, Mark
Nov 20, 2008 | Panasonic PT-53WX42 53" Rear Projection...
D board for panasonic tv
You can purchase TNP2AH046S d board at Panasonic Parts and price is approx $280
Sep 16, 2008 | Panasonic PT-53TW53 53" Rear Projection...
It's called tearing and it's likely in the HV circuit, possibly the FBT or splitter. Won't go into any greater detail than that, other than to say it's time to call the technician. Voltages in that circuit can make you VERY dead...
Mar 18, 2008 | Panasonic PT-53WX42 53" Rear Projection...
53" Panasonic HDTV showing letters and shadow
maybe you have defective convergence correction circuit! replace a new one!
Oct 03, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
52 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
