Question about Apple 2.16GHz iMac Intel Core 2 Duo DVDRW/CD-RW Desktop PC Mac Desktop
My internal optical drive spits out dvd's and cd's.
My internal dirve immediatle ejects dvd's and cd's. Not recognising any type, either media or blank. I need to upgrade to Leopard and need the drive to do this. Is the drive finished? Any Cheap external alternatives? Or are there any do it yourself fixes to the problem?. The drive is a : PIONEER DVD-RW  DVR-K06
thank you in advance
  • jjwd1976 Mar 06, 2009
    I have a similar spec imac and have discovered that the cd player has stopped working but the dvd is fine. I've tried numerous discs to no avail. It's outside of warranty and will cost 200 uk pounds. Not happy. I wanted to install xp on boot camp and am now unable. I'm not sure an external cd player will be visible for the installation.
    Can anyone advise? If this is a common problem surely Apple should acknowledge this an offer a free repair.
    Sergeant:
  • Apple Expert
  • 250 Answers
When rebooting press and hold the Alt key until it displays all bootable drives. Now insert your disk. If it works install Leopard from here. If not then your drive is dead or faulty and needs checking or replacing.
All the best
Sean
PiDigital
Posted on Dec 16, 2008
Dvd drive is not reading and also ejecting out !
Hi
I would simply recommend replacing the drive as it sounds like the optical lens is shot in it.
Taz
Oct 30, 2009 | Dell (0F146) Internal DVD Drive
Not recognising cds and ejects them
If you have SP3 installed, try removing it. It makes problem with some optical drives.
Try new Free Nero 9
http://www.nero.com/eng/downloads-nero9-free.php
Sep 05, 2009 | Dell Computers & Internet
My MacBook spits out my music..
Your MacBook only likes odd numbers.
Could be initial sign of failing optical drive. Try other format discs and see if they are ejected too.
Aug 21, 2009 | FastMac (APP-5693) for PowerBook G4...
Dell xps m1330 dvd drive will not eject cd inside
Im a dell tech, and i hate those cdrom styles, but, that is what the consumer wants, so we make them. Try starting the machine, then press F2 to enter the BIOS. once in the bios, press the eject button. listen for any noises, (an attempt to eject). if you hear a sound, it means the drive should be capable of ejecting the disc, and perhaps the disc has not seated correctly. If the disc will not eject, you must contact Dell. This is from the DELL dcse site: " Optical Drive The XPS M1330 has a slot-loading optical drive instead of a conventional tray-loading module. There is no mechanical eject mechanism for the drive to eject stuck discs. This means you must replace the drive if a disc gets stuck in the drive. After replacing the drive, disassemble the old drive to remove the disc for the customer."
Jul 21, 2009 | Dell (0F146) Internal DVD Drive
LG GCA-4080N internal drive
It seems that what you have is a combo drive only :(
it only recognize DVD reading. no matter what driver you used. need to buy a dvd writer/ that said can write dvd.
Types of Optical Drives and CD/DVDs
Optical drive type Read from CD/DVD-ROM media Write to CDRW media Write to DVD ±RW/R media Write to DVD +R DL media Write label to LightScribe CD-RW Write to DVD-RAM media DVD-ROM Drive Yes No No No No No DVD and CD-RW Combo Drive Yes Yes No No No No DVD±RW/R and CD-RW Combo Drive with Double- Layer support Yes Yes Yes Yes No Yes LightScribe DVD±RW/R and CD-RW Combo Drive with Double- Layer support Yes Yes Yes Yes Yes Yes Blu-Ray Disc DVD±RW SuperMulti Drive with Double-Layer support Yes Yes* Yes Yes No Yes *Low speed (4X) and high speed (4-12X) are supported. UHS-RW (24X and 32X CD-RW) is not supported.
NOTE: Some of the optical drives listed may not be supported by your computer. The listed drives are not necessarily all of the supported optical drives.
Dec 26, 2008 | LG (GCC4521BBULK) CD-RW/DVD-ROM (Combo)...
Optical drive failure
try to clean the lens maybe you dont use it frome some time and there need a lens cleaning if no just change it with new one
Dec 14, 2008 | Apple 2.16GHz iMac Intel Core 2 Duo...
DRIVERS NEEDED
All optical drives use ATAPI drivers, these drivers are native to Windows. Physically install the DVD player and it will be recognised, depending on what type of CD and DVD burning software you have your drive may not be recognised by them.
OEM burning software will only work with the optical drive it was supplied with, retail burning software should work with any drive.
Aug 31, 2008 | Samsung SH-S182 DVD±RW Dual Layer Burner
I have an internal HP DVD Writer 740b that writes on CD but not on DVD. I tried Sony DVD RW and Memorex DVD-RW to copy files on but I failed. I use Nero Essentials to burn. The dialogue box keeps saying no...
DVD-RW drives have 2 different designs, 1 used dual optics, 1 for CD one for DVD, the other uses optics that can refocus between the media types.
If you haven't done so already, flash the firmware of the drive to the latest available from HP.
Assuming that the drive worked with NERO previously, If that doesn't resolve, you will likely need to replace the drive.
If you have not used Nero with that drive for DVD media, you might try a different SW and see if Roxio/Sonic will see DVD media in the drive.
Aug 13, 2008 | HP Computers & Internet
Samsung SD 616E Internal DVD not working
I have the same problem, wont read anything in the drive. It is a master and there is no slave dirve so its not that, jumpers etc checked, drivers, cables. Just wont work.
Dec 14, 2007 | Samsung SD 616E (729507925578) Internal...
Apple 2.16GHz iMac Intel Core 2 Duo DVDRW/CD-RW Desktop PC Mac Desktop Logo
2,155 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
