Question about Borland Turbo C++ Suite 1.0 (TCB0000WWFS180) for PC
Displaying a jpg file using turbo c
I need to display a jpg file(16 million colors) using turbo c
can anyone tell me the exact code
is it possible to display jpg file having 16 million colors using turbo c???
  • avinash08 May 06, 2009
    maximum number of colors that can be opened using turbo c/c++ are 262144??? or the dac registers can be programmed in some way to produce 16 million colors...
    plz if anyone knows this.. plz do help me...
    tell me the solution
    is it possible to achieve 16 million color options using turbo c/c++ compiler...
    is there any other way beside using dac registers.......????
2 Suggested Answers
jibingrg
  • 96 Answers
SOURCE: color options in turbo c/c++
just try to wiki registration....last month i got 16 million color option...so try wiki registration
Posted on May 06, 2009
  • 11 Answers
How Not to Program in C++
How Not to Program in C++: 111 Broken Programs and 3 Working Ones, or Why Does 2+2=5986
Publisher: No Starch Press | ISBN: 1886411956 | edition 2003 | CHM | 280 pages | 1,2 mb
How Not to Program in C++ is a puzzle book with over 100 challenges. Readers must find errors in up to 40 lines of code. By learning to detect the errors, readers become more efficient programmers. Based on real-world programs, readers solve puzzles ranging from easy (one wrong character) to difficult (errors with multiple threads). Clues help along the way, and answers are at the back of the book.
Free Computer eBooks Link:
Download
Posted on Jun 16, 2009
I am missing fine details in computer graphics
Hi! I'm a computer-based graphic artist and also a photographer who does digital editing. THe difference between the display settings makes a big difference. Using 32 million colors rather than 16 million is significant for image quality. Also check your display's resolution settings.
How To:
Right-click on the desktop background.
Select "Properties".
Go to "Settings" to find Screen Resolution and Color Settings adjustments.
Clicking the "Advanced" button gives you more options.
One final idea:
Check to see if you are using the correct display adapter (driver), and that it is the most up to date one. A generic, incorrect, or obsolete driver can affect visial performance.
Hope that helps!
Steve
Jun 15, 2011 | Computers & Internet
Whenever I load photos onto my photo frame from the PC, they all seem to transfer just fine. But then when running the slideshow, not all the pictures are showing up. When I go into the photo menu on the...
The issue may be due to the file types of the pictures you are sending to the frame. You did not include the model number of the frame, so I can't be sure of the file types it can display but generally, JPG file types enjoy the most compatibility on such devices.
You should determine the file types of the images you are sending to the display. While displaying the slideshow, make a note of an image that displays properly. Look at the the image on your computer and check the file details to learn which file type it is. Play the slideshow on the frame and double check as many as you can against the list / thumbnails on the computer. After a short time, a trend show be visible. You may find that JPG and GIF files display properly, but TIF and others do not.
If you want those pictures to display, you'll have to convert them to one of the file types that does display. If you're finding that only some JPG (or other displayable file type) do not display properly, you'll have to see what is different. Sometimes, very large files may not display correctly, or it may have "too much color" information (they might be a 16 bit graphic or 16 million colors instead of an 8 bit graphic or 256 colors), or some other issue that isn't readily apparent. You can try resizing or converting to yet another format that is supported by the display (GIF for instance).
This is a starting point - hopefully you'll find the issue within one of these suggestions. Good luck! Please rate my reply - thank you.
Feb 24, 2011 | Philips 6.5-Inch Digital Photo Frame...
Went to a camera class a couple of months ago to learn how to use my Nikon D3000. We made a lot of setting changes. Now when I download photos, I get 2 copies -- a jpeg and an nef file. Do I really need...
In some ways the NEF file is the equivalent of a negative, while the JPG file is the equivalent of a print from a negative. However, since digital copies are exact, you don't need the NEF file if you're not going to do anything fancy with the photos. I know people are going to argue with that --- heck, I'm one of them, I shoot only NEFs.
Press the info button to display the information display, then press the i button to put the cursor in the information display. Use the multiselector to highlight the current image quality setting (the topmost item on the right side of the display) and press OK. Select JPG fine and press OK.
For full details, see the "Image Quality and Size" section in the manual (page 50 in my copy).
Jan 05, 2011 | Nikon D3000 Digital Camera
Some, but not all, .JPG files won't display
I have tried three different digital frames with the same problem. I contacted the Help Desk of one manufacturer. He claimed that tthere are several versions of the .jpg format and some would not work with their frame. I had never heard anyone claim that there are different .jpg types and really doubted his explaination but I can't argue with what I am seeing - some work and some don't. I asked the Help Desk how you could tell the difference. He said the only way is that you have to know what computer program originally created the file. Of course, with thousands of photos, that would be impossible. So... I don't have an answer - just a questionable explaination. Sorry I could not be of more help.
Nov 27, 2009 | Coby DP-758 Digital Picture Frame
Hi I want to Unlock my 2630 nokia cellphone by software just using pc & cellphone . If you know another way please tell me how? IMEL is: 357691015218766
Nokia N97 32GB unlocked ( Brand New )
Specifications
* Size: 117.2 x 55.3 x 15.9 mm* *18.25 mm at camera area
* Weight: Approx. 150 g
* Memory: Up to 48GB (32 GB on-board memory, plus 16GB expansion via
microSD memory card slot)
* Display: 3.5 inch TFT with up to 16 million colors nHD 16:9 widescreen
(640×360 pixels)
* Talk time: Up to 320 min (3G), 400 min (GSM)
* Standby time: Up to 400 hrs (3G), 430 hrs (GSM)
* Video playback: Up to 4.5 hours (offline mode)
* Music playback: Up to 37 hours (offline mode)
* Image capture: Up to 5 megapixels (2584 x 1938) JPEG/EXIF (16.7
million/24-bit color).
* WiFi and HSDPA
* DVD quality video capture and 16:9 display
The Nokia N97 32GB is made in Finland and it is the leading phone in the
Market, beating the Nokia N96 16GB and also the apple 3G 16GB..
Nokia N97 32GB is touch screen and is one of the Smartest technology.
Be one of the first to have this phone, We have sample units available for Sale..
Feel free to contact us, we are always online to give you a reply...
NOTE:
If you send us a mail today, we will reply you today.
dialaphonemobile@gmail.com
May 14, 2009 | Nokia 2630 Cell Phone (Unlocked) - Black
Color options in turbo c/c++
May 06, 2009 | Borland Turbo C++ 3.0 Full Version...
Download
May 06, 2009 | Borland Turbo C++ 4.5 Full Version for PC
My acer laptop with windows xp will not allow me to select the optimal resolution for my samsung moniter. How do I fix this?
The Samsung SyncMaster 730b is a 17-inch analog and digital TFT-LCD monitor delivering crisp, clean text and bright, vivid colors. This display offers a 600:1 contrast ratio, 300 cd/m2 brightness, 1280 x 1024 resolution, 160/160 degree viewing angle, scanning frequency of 30-81 kHz horizontal and 56-75 Hz vertical and 0.294mm pixel pitch
The SyncMaster 730b display offers the option of using either a digital or analog interface for viewing images and text. The Digital Video Interface (DVI) ensures a shaper, cleaner image and a more accurate representation of the original video source. Since video starts out digital in a PC graphics card, the digital output is directly interfaced to the digital input of the LCD panel and always provides the optimum quality image. In addition, no adjustments are required with a digital display, even when randomly changing resolutions. Input connectors for this display include 15-pin D-sub and DVI-D. Available in black, the SyncMaster 730b delivers a maximum of 16.2 million colors. The monitor is Windows Plug and Play DDC 2B compatible
The important stuff here would be the following:
(1) 30-81 kHz horizontal and 56-75 Hz vertical
(2) SyncMaster 730b delivers a maximum of 16.2 million colors
(3) 1280 x 1024 resolution
nVidia card settings should not exceed these monitor parameters. The monitor is not designed for more performance output without increasing liability toward failure. ?. Put your card settings, under the nVidia tab, at the following:
(a) Refresh rate set at 75 Hz
(b) Set colors at 16 million
(c) Set resolution slightly less than 1280 x 1024
It?s quite possible your monitor is at fault, but start with its optimal parameter settings for the display card first. The display card probably exceeds the monitor?s capabilities. Hopefully, this will stabilize your PC session and the blank outs cease if hardware is not faulty
May 23, 2008 | Computers & Internet
IQ Digital Picture Frame
I have an IQ Digital Photo Frame but the manual is in French I would like to be able to download the English version can anyone help please
Nov 19, 2007 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
Writing edited jpegs to CD1000
The problem is an incompatibility between Photoshop and Sony JPEG files. (I thought JPEG was supposed to be a standard!) A simple workaround is to use the PictureGear program supplied by Sony. Use its File – Process command to save the Photoshop frames to the CD-R. It is also useful to ensure that the frames are resized to 1600x1200, 1024, 640 etc to eliminate the black border that would otherwise be displayed by the camera. This “feature” can be useful however if you have frames that have important sections at the edge of the frame. This would often be lost when displaying on a TV. Save the frame as, say, 1520 x 1140 and you will always see the full picture! Another possible advantage is to use achieve greater JPEG compression. The CD1000 will accept PictureGear at the largest filesize (10) but one can use compression 8 or even less and get many more frames on a disk. There is a little loss of quality but much less than resizing down to a smaller image size. I would guess that the above will also apply to memory stick.
Sep 13, 2005 | Sony Mavica MVC-CD1000 Digital Camera
Open Questions:
how to write c/ c++ sourcecode for Merkle-Hellman Knapsack Public Key Cryptosystem ??? In this problem you will implement the Merkle-Hellman Knapsack cryptosystem. The encryption and decryption algorithms are based on solving a knapsack problem. The knapsack problem consists of finding a way to select some of the items to be packed such that their sum (the amount of space they take up) exactly equals the knapsack capacity (the target). Formally the knapsack problem is as follows: Given a set S = {a1, a2, ..., an} and a target sum T, where each ai >= 0, is there a selection vector V={v1,v2,...,vn} each of whose elements is 0 or 1, such that (ai*vi) = T. The idea behind Merkle-Hellman scheme is to encode a binary message as a solution to a knapsack problem reducing the cipher text to the target sum obtained by adding terms corresponding to 1s in the plaintext. That is, blocks of plain text are converted to knapsack sums by adding into the sum the terms that match with 1bits in the plaintext as shown below: Plaintext: 1 0 1 0 0 1 Knapsack: 1 2 5 9 20 43 Cipher text: 49 Plaintext: 0 1 1 0 1 0 Knapsack: 1 2 5 9 20 43 Cipher text: 27 The receiver will have to use the cipher text (the target sum) to recover the plaintext. A knapsack problem is said to be ``easy'' if {missing}. The solution for the easy knapsack problem is straightforward, and can be achieved in O(n).Furthermore, there exists a way for transforming an easy knapsack set S into a non-easy knapsack H simply by multiplying the elements of S by w mod n where w and n are well chosen integers. Formally the terms of H are: hi = (w*si) mod n. For example if S = {1, 2, 4, 9}, w = 15, and n = 17 then H = {15, 13, 9, 6}. Encryption algorithm (executed by the sender) H is called the public key and is made public by the receiver Choose w and 1. n such that n > max(S) and n is prime, and w < n. Construct H from S, w, and n. Sender uses H to encipher blocks of m bits P0 = [p1, p2...pm], P1 = [pm+1, pm+2...p2m] and so forth (m is the number of terms in H), as follows: Ti = Pi*H = (pj*hj). Thus T0 = P0*H, T1 = P1*H and so on. Ti are then transmitted to the receiver via a reliable channel. 1. Decryption algorithm (executed by the receiver) The tuple (S, n, w) is called the private key and is kept secret by the receiver Use w and n to compute w-1 where w-1*w = 1 mod n. if n is prime then w-1 = w (n-2) mod n 2. Compute Ai = w-1*Ti mod n 3. Find Pi by solving Ai = Pi*S Input file The input consists of N test cases. The number of them (N) is given on the first line of the input file. Each test case begins with a line containing a plaintext to be encrypted. The second line contains the number of elements (m) in the knapsack S that show in the third line. The knapsack elements are positive integers separated by space. The fourth line of each text case contains n and w in this order separated by space. Output file Print exactly 3 lines for each test case. The first line should contain the encrypted values of the plaintext of the set separated by space. The second line should contain the plaintext obtained by applying the decryption algorithm to the plaintext, preceded by `Recovered plain text: '. The third line should contain the value of w-1 Sample Input 2 Salaam! 4 1 2 4 9 17 15 hello there? 4 1 2 4 9 19 7 Sample Output 29 25 22 16 22 28 22 16 22 16 22 44 9 16 0 24 Recovered plain text: Salaam! 8 23 7 23 20 23 21 23 21 23 36 9 0 29 14 23 7 23 20 29 9 23 20 15 36 0 16 Recovered plain text: hello there? 11
Feb 24, 2009 | Borland Turbo C++ Suite 1.0...
Borland Turbo C++ Suite 1.0 (TCB0000WWFS180) for PC Logo
379 people viewed this question
Top Borland Computers & Internet Experts
Tony
Yoav Shilon
Yoav Shilon
k24674
Are you a Borland Computer and Internet Expert? Answer questions, earn points and help others
