Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Aio Home center will not open up to scan.
I haven't been able to scan on my Kodak 5300 since I purchased it . Everything else works fine ,I can't get the home center to open so that I can csan. Thanks
    Sergeant:
    Champion:
  • 201 Answers
  1. Is your drivers properly installed?
  2. Use Paint in windows and try to aquire a imige from there,
  3. Else reload your driver
  4. Still not working reload your O/S windows
Posted on Dec 14, 2008
Printer will not scan
Kindly install the Kodak all in one home center on your computer,connect your computer and printer via usb cable and then try 2 scan. Ur issue will be fully resolved. Click on scan pictures and documents On kodak aio home center and then click on scan now,follow the instructions.
Nov 28, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak 5300 all in one printer will not scan. Cannot get on line with 5300 a10 home center program, tells me printer is not connected
try to unplug replug the usb cable of the printer.
You may also go to control panel printer and faxes and look for the printer of your 5300 now if you see 2 icons delete them both then exit to printer and faxes. and unplug/replug your USB cable then restart computer.
If this issue not solve try to uninstall the software and download the clearutility kodak.com/go/clear. then after doing this restart computer.
Nov 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak aio home center experienced an exception and cannot continue Error 1- 2010 What is this?
Try to install the latest version of Printer software from www.kodak.com/go/downloads on your computer. then open the kodak home center software and click on scan pictures. Adjust the settings and you are ready to go. download the user manual from www.kodak.com/go/manuals.
Oct 10, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
How important is downloading kodak home centre software for the kodak printer to work?
Kodak AiO home center, serve as a driver as well for your printer to print from the computer. It will let you scan, copy or print pictures. AIO home center will let you select the settings you want for your printer
Sep 28, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
I have a kodak esp9 on win xp wireless connection. Constantly get the 1-2010 error code and kodak aio home center will not open and the printer will not connect any solutions?
  1. From your computer, access Device Manager.
    • For WINDOWS XP OS:
    • Right-click My Computer, then select Properties.
      • Select the Hardware tab, then Device Manager.
  2. Select View > Show hidden devices.
  3. Select Printers.
  4. Select Action > Uninstall.
  5. Select Action > Scan for hardware changes.
  6. Double-click the KODAK AiO Home Center icon. If the error occurs again, go to the next step.
  7. Set administrator rights for the Home Center application:
        • Right-click on the Home Center icon.
        • Click Properties.
        • Click the Compatibility tab.
        • Clear all the check boxes.
        • Click Apply and OK.
    1. Double-click the KODAK AiO Home Center icon. If the error occurs again, go to the next step.
      IMPORTANT: In the next step, before you install the Home Center Software, make sure you disconnect the USB cable. Then, connect the USB cable when the software installation instructions tell you to do so.
    2. Upgrade the software and firmware for your printer:
Jul 17, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
The kodak aio home center won't open getting error 1--2010 esp3 printer
if using vista try this:
Select Properties.
Select the Compatibility tab.
Click Run this program as administrator.
Click OK.
reply if does not work.........
Jun 08, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
i dont have an answer to your first problem, but i do to your second
Please call 1.800.421.6699 and select option 01 for prints missing black or color ink. Kodak will send you a replacement printhead kit for free.
by the way, the cleaning heads issue is normal since the cartriges don't have printheads
Jan 28, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Unhandled Exception message with new 5300 AiO
go to c:\windows\system32\kodak and check for kds_aio5000 and inside that you should have 1 folder and 1 file. the folder name is lib and the file name is ekaiowia.dll. inside lib folder there are cct.ekpgct and hippo.dll. If not then uninstall the home center and then go to www.kodak.com/go/clear and run it then install the home center from www.kodak.com/go/downloads and choose the appropiate product.
Jun 06, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Home Center will not open...Can't scan
I needed to reload my AiO Home Center software and no one seemed to have the correct procedure. Maybe if you remove & reinstall yours it will resolve your problem. This procedure worked for me on my XP-machine:
1. got to Control Panel/Printers&Faxes and delete the printer
2. go to your Hardware/Device Manager/Universal Serial Bus Controllers, right-click on USB Composite Device and select Uninstall
3. go to Control Panel/Add/Remove Software and remove the EasyShare software
4. disconnect the cables from the Printer
5. download from Kodak.com the program "install_aio.exe"; run the program
(I selected only AiO+EasyShare+Software Updater to load)
6. followed the prompts after the sw installed to reconnect the Printer cables
7. rebooted
WORKED for ME !
Jan 13, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
75 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
