Question about Mongoose Butterfly Summer 12" Girl's Bike
Why does my new bike's back wheel not spin easily?
I bought a new bike off the internet and the back wheel is not spinning easily. it appears that the coaster brake or connections to the back frame are too tight. it is difficult to pedal and the wheel does not spin as easily as it should. there are no obvious chain , sprocket, or frame defects.
  • 2,039 Answers
If brake and aligmen t of wheel is good the bearing ajustment is too tight remove the wheel loosen the nut on each side not too loose just so it turn freely with no play in the wheel let me now pierre
Posted on Dec 15, 2008
Front wheel doesn't spin freely and squeaks on 2n'd day i got it.
Hi James:
If New, I'd take it back to the dealer.
If used.....
Set bike on jack so front wheel is raised. Make sure it is secure so can't fall.
1) Remove front brake pads........... spin wheel If it still squeaks, remove wheel and service bearings.
If no squeak when brakes removed, service brakes.
Jan 18, 2016 | Motorcycles
Yamaha starter clutch
Starter clutch is behind the alternator rotor. It should turn only one way. If it is bad (you'll have to take it out to see) it will turn either way.
Apr 03, 2014 | 2007 Yamaha V Star Custom
Hello, I bought my little girl the huffy 12in disney princess bike (blue) already assembled from walmart. she tried to ride it today, but when she pedals the back wheel spins, but the training wheels and...
ONE AT A TIME, loosen the nuts securing the training wheels to the rear axle and slide each one upward a little bit so it float a little bit off the ground when the bike is vertical, then retighten the nut.
As she develops her handling and balance skills she'll need less help from the training wheel. So you can gradually raise them a bit higher as she masters balance and then she'll develop the 'lean' for turning. Ultimately, you remove them entirely.
I hope she's wearing a properly-fitted helmet.
http://www.nhtsa.gov/people/injury/pedbimot/bike/easystepsweb/index.htm
Jan 27, 2011 | Huffy 12 in. Girls Disney Princess Single...
I have a new trike that may have ome shipping damage (bought at flea market) The rear axel appears to be bent. severe wheel wooble. is there some adjustment in those set screw type bolts in the center of...
The set screws in the center of the axle are there to keep the axle centered in the frame. Only the right wheel is powered which also means only the right wheel brakes when operating the rear brake. This is because the rear wheels must be able to spin independently when turning because the outside wheel will move faster. Unfortunately no one builds differentials at this price.
If you have wheel wobble you need to determine if the axle is bent or the wheel is not true. Prop up the rear of the bike on a stand and remove the problematic wheel. Manually pedal the bike and check the axle as it spins. If the axle is wobbling then it is bent and will need to be replaced. If it spins true then the wheel is the culprit.
The axle is relatively inexpensive and can be ordered through a Schwinn dealer. Any bike shop should be able to true a wheel for around $15-$20.
Sep 23, 2010 | Schwinn Meridian Adult 26-Inch 3-Wheel...
Avid Juicy 7 disc brakes:The front wheel was removed and the brake lever squeezed while the wheel was off. The front wheel goes on, but does not spin freely. It turns easily, but not freely like it...
It sounds like you have a piston that is not fully returned and is sticking.
Get a big flat bladed screw driver, take the wheel out and very carefully insert the screw driver into where the disc would sit and use the screw driver to try and push each brake pad back in without damaging your brake pads.
If this works go to a local bike shop and ask them for a avid brake insert for transporting your bike so this does not happen in future! :)
Jan 13, 2010 | Avid Juicy Ultimate Hydraulic Disc Brake ,...
Brand New mens Diamondback mountain bike, with
You may have a locked up wheel bearing or you may have an object stuck in the chain. Can you spin rear wheel by hand? If not, most like bearings, if so, then you may have bent gear tooth or something stuck in chain. Check derailer to make sure it is not bent
Aug 17, 2009 | Cycling
16" Girls Mongoose Pizazz Problem!!!
some bikes are like that. The rear wheel only spins with the pedals. Try pedaling backwards and see if the wheel goes back. If it does then that is normal.
Jul 13, 2009 | Mongoose Butterfly Summer 12" Girl's Bike
Childs 12 inch mongoose is new, but back wheel does not spin prop
The bikes are pre-assembled by a machine that overtightens the rear axle.  I had the same problem with my daugher's 12 inch huffy princess bike and my other duaghter's 16 inch Schwinn bike.  If you loosen the nuts on the back axle it fixes the problem.  I have read that the idea thing for these bike is to have them re-assembled and re-lubricated by a bike shop, but I thought this might cost as much as I paid for the bike.
Dec 14, 2008 | Mongoose Butterfly Summer 12" Girl's Bike
Mongoose Butterfly Summer 12" Girl's Bike Logo
1,412 people viewed this question
Top Mongoose Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
Rommel Balcita
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
