Question about HP PSC 2175 All-In-One InkJet Printer
Hp psc 2175 all in one making knocking noise when i turn it on then gives me a error message on the machine display "scanner error, turn machine off then on" . i called hp and they told me it was a hardware problem. is there anyway i could fix this problem myself?
  • 8 more comments
  • magikhouse Dec 23, 2007
    I have the same problem. Disconnected printer and using and old one for now because at start-up it starts knowcking and then displays scanner error3
  • larryboyer Jan 06, 2008
    SAme problem, recently went to VISTA on HP power up
    I get the clicking then message Scanner Failure turn power off an on again. Which I have done about 10 times. Not working at all.
  • knittingchic Jan 07, 2008
    I have the same problem. I am so disappointed with this printer. Never seems to fail when I really need a copy, it does not work!
  • kathy0428 Feb 21, 2008
    my printer makes noise when it starts up it is telling me to press enter to align the cartridges but it will not let me. My problem seems to be the scanner which will not move when you first start. How can I fix this, someone told me it might be stuck or a belt came off. How do you get to the light when you can not find a way to it.
  • Anonymous Mar 09, 2008
    I have a similar nocking noise when I put the is printer on. It does not stop..it feels like thecycle doesn't stop and keeps on kicking like the energizer bunny..
    What a rip off this was...if there is a solution please advise..appreciate the help
  • Anonymous Mar 19, 2008
    I am having the exact same problem. Was fine when I made first copy. Went to make second copy and lights were flashing, etc. Turned off then back on; noises started - scanner failure on screen. Have had this happen before, but was always able to figure out a way to fix it. Not this time I'm afraid.
  • Anonymous Sep 08, 2008
    I replaced the ink cartridges, closed the cover and the machine tried to align. The machine keeps making a click/knocking noise then flashes a "scanner error" message and directs to turn off then on again, which does not solve the problem.
  • hlaya Jan 26, 2009
    I have installed cartidges in my HP PSC 2175 but can't figgure how to close the print cartridge access door,it is locked open.How do I release the door to close it.
    thanks Harry
  • Anonymous Feb 08, 2009
    Exactly the problem listed about with the same message
  • garydds Feb 19, 2009
    I'm so frustrated with th printer. Out of te blue, wh turn it on it makes clicking noise and gives me error message to shut off and back on. Doesn't help at all. anyone have any ideas? Thx Rhonda
    Novelist:
    Champion:
  • 202 Answers
Http://h10025.www1.hp.com/ewfrf/wc/solveCategory?lc=en&cc=us&dlc=en&product=90809&lang=en Here is the HP site for any extra info you may need. ISSUE: Sometimes when printing out, the carriage makes an abnormal noise or its movement is erratic. SOLUTION: To solve this issue, follow the steps listed below: NOTE: The images and descriptions showed along the document might be slightly different depending on your HP All-in-One model. 1. Clean the unit front and back rollers. To do so, follow the steps listed below: 1. Disconnect the power cord or power supply from the rear of the unit. 2. Open the print carriage access door. 3. Remove the rear door and check it for damage. 4. Make sure that the paper rollers inside the rear access door rotate freely. Please clean them using a lightly moistened cloth. 5. Wipe the paper rollers with a lint-free cloth lightly moistened with distilled or bottled water. Rotate the rollers with your fingers to clean all the way around. 6. Allow the rollers to dry completely, and then close the rear access door. NOTE: Make sure the rear access door is correctly closed and placed. 7. Through the previously open cartridge access door, clean the front rollers with a lint-free cloth lightly moistened with distilled or bottled water. Please rotate the rollers with your fingers to clean all the way around. 2. Use a clean, dry cotton cloth to wipe the carriage rod. Move the carriage as needed to clean the full length of the rod. WARNING: Do not lubricate the rod. 3. If noise is located at the paper path, it may be caused by ink, dust or other residues stored over the pinch rollers. Please, clean the pinch rollers by using a cloth lightly moistened with alcohol. 4. The edge of the pitch rollers must be cleaned too. To do so, use a small drop of alcohol. This will remove the ink and will solve the issue. (see detail in the image below). 5. Clean the carriage contacts and the capping station. To do so: 1. Connect the power cord to your HP All-in-One product, and turn the unit on. 2. Lift the front of the HP All-in-One product just above the paper output tray as shown below. The print cartridge capping station will lower to allow access to the print cartridges. 1 - Print cartridge latch 2 - Capping station 3. Gently pull up the print cartridge latch front to release it. The latch is spring loaded and will spring upwards. Slowly raise the latch instead of letting it spring open. 4. 5. Remove each print cartridge by sliding it out of its socket, moving it toward the front of the HP All-in-One product. Do not try to pull it in an upwards direction. NOTE: If the print cartridge cannot be slid out, verify that the latch is raised, and the HP All-in-One product is on. If it is not possible to remove the cartridge, too much time may have passed since it was opened and the capping station may have raised again. Close the print carriage access door, wait five seconds, and then open it again to lower the capping station. 6. Extract the cartridges and clean the copper contacts with a watered lint-free cloth 1 - Copper-colored contacts 2 - Ink nozzles (do not clean) 7. Disconnect the power cord from the HP All-in-One product. 8. Clean the electric pins placed in the front of the print carriage using a lightly moistened cloth. 9. Using a dry cloth, clean the ink stored inside the capping station sponges (see the image below). 10. Mop up the electric pins completely, and connect the power cord again. 11. Turn on the unit, reinstall the cartridges, and close the print carriage access door. 12. If the noise issue remains unsolved, please perform a Power Cycle on the unit following the steps below: 1. Turn the unit off. 2. Unplug the power cord from the unit. 3. Wait 30 seconds, and then re-connect the power cord to the unit. 4. Turn the unit on. 13. If the issue persists, the unit may need to be reset. Please, consult the HP All-in-One Products - Performing a Partial Reset of the All-in-One document to learn how to do it. Additional steps (only for PSC 1100 & 1200 Series All-in-One products HP PSC 1100 & 1200 Series All-in-One products may be affected by this issue, due to the friction between the printing carriage and the paper. Please, print a couple of pages full of black text in Normal mode, and follow the steps listed below if the printed text looks like the image below: 1. Print a Self-Test Report and then, check the quality of either the text or the color bars. Follow these steps to print a self-test report: 1. Press and hold the Cancel and the Color buttons at the same time. 2. Release both buttons. 3. The Self Test Report will be printed. 2. If the media does not fit the weight specifications (see table below) or if paper is curled, then this may prompt the bottom of the ink cartridge to come in contact with the media. If this happens, the print will smear and the cartridge may become damaged. HP PSC 1100 & 1200 Series Type Paper Weight Plain paper 70 to 90 gr/m2 (20 to 24 lb.) Cards Up 200 gr. (110 lb.) Envelopes 75 to 90 gr. (20 to 24 lb. max.) Transparency Film N/A Labels N/A 4 x 6 Photo 236 gr/m2 (145 lb.) Custom Media 34 gr/m2 (9 lb.) 3. Make sure that the Paper Type is correctly set to either Plain or Photo. 4. Run an alignment of the print cartridges. To do so, follow the steps below: * HP PSC 1100 Series: 1. Turn on the HP PSC 1100 Series product. 2. Disconnect the USB cord from the unit rear. 3. Press the following sequence of front panel buttons to initiate the ink cartridge alignment: NOTE: The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds. 1. Press and hold the Cancel button. 2. While holding the Cancel button, press the On button. 3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons. 4. Press the Cancel button again. 5. Press the Resume button. 6. Press the Paper Type button. 7. Press Color Start Copy. The alignment page printing will begin. NOTE: If the alignment page printing does not start, please repeat the button-press sequence. 4. Once the alignment page is printed, place the page face down on the scanner glass and press the Scan button. The print cartridge alignment process is complete when the On light stops blinking. 5. Re-connect the USB cord to unit rear. * HP PSC 1200 Series 1. Turn on the unit. 2. Disconnect the USB cord from the unit. 3. Press the following sequence of front panel buttons to initiate the ink cartridge alignment: 1. Press and hold the Cancel button, and then press the On/Resume button. Then, release both buttons. 2. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons. 3. Press and release the Cancel button again. 4. Press and release the Copies button. 5. Press and release the Paper Type button. 6. Press and release the Start Color Copy button. The alignment page printing will begin. NOTE: If the alignment page printing does not start, please repeat the button-press sequence. 4. Once the alignment page is printed, place the page face down on the scanner glass and press the Scan button. The print cartridge alignment process is complete when the On/Resume light stops blinking. 5. Re-connect the USB cord to the unit. 5. Close the cover and press the Scan button. Wait until the alignment is finished. The On light stops blinking when the alignment is finished. Let me know what happens. Good Luck, Tim,
Posted on Mar 15, 2007
Hi, my printer keeps giving me a cartridge error.
remove cartage and clean contacts with a soft cloth. also clean contact inside cartage holder and incert nice and firmly, hope this helps in some way
Dec 01, 2009 | HP PSC 2175 All-In-One InkJet Printer
My HP 2175 PRINTER keeps giving me an error
Check the default paper settings in the printer sofware, if they are correct then problem may be internal.
You dont mention whether it prints OK though.
My HP 2175 printer keeps giving me the message to align the print cartridges. will not copy or anything
Hello sir; Your machine need to reset; turn power on, open the cover when cartridge carrier move to the center ,the UNPLUG the power cord wait about a minute put power switch in off position, then plug in power, turn switch on.
Nov 22, 2009 | HP PSC 2175 All-In-One InkJet Printer
My HP 2175 started knocking, won't copy
Try pulling the cartridge out and re-install a couple of times, also check to see if everything is clean inside printer, paper scraps can get into things and cause trouble
Aug 22, 2009 | HP PSC 2175 All-In-One InkJet Printer
My hp psc 2175 all-in-one keeps giving me the message "press enter to align cartridges." When I do that it says" printing align cartrigdes page" then it says "alignment cancelled" and then goes back t
Hello Dear; When you install new cartridge the machine going to alignment it is neccessary you just follow the direction step by step to finished the procedure.
Apr 28, 2009 | HP PSC 2175 All-In-One InkJet Printer
Constant whirring noise and won't print
I do have the same problem with my psc-2175. I opened it and recognized that the problem is with the scanner unit. There is a sonsor in this unit which locates the scanner lamp at the beginning point when you turn it on. When this sensor fail to function, the electric motor, which moves the scanner lamp will not recognize where to stop and it works without any stop. So it pulls lamp unit into its borders and make the noise you hear.
I wanted to let it repaired, but I found out that it will be very expensive and it is better to buy a new set. I have bought it in Iran 1600000Rls (170$), and the repair cost is almost 750000Rls (78$).
If you find another solution please let me know, my email is: decoder84@yahoo.com and my name is Soroush Asarzadeh.
May 08, 2008 | HP PSC 2175 All-In-One InkJet Printer
Hp psc 2175 all in one SCANNER PROBLEM
This is only a software issue. Reinstall the software or try installing on other system
Mar 19, 2008 | HP PSC 2175 All-In-One InkJet Printer
Hp psc 2175: change cartridge
The cartridge was somehow jammed, I helped it a bit manually.
After changing the cartridges, color and black, some error messages where shown in the display like, check the cartrige or similar.
Feb 16, 2008 | HP PSC 2175 All-In-One InkJet Printer
HP PSC 2175 All-In-One InkJet Printer Logo
2,575 people viewed this question
Clive
Clive
