Question about Sharp Aquos LC-32D40U Television
NO SYNC Do you know if it is an expensive repair?
    Genius:
  • 2,920 Answers
Probably about 300.00
Posted on Dec 14, 2008
How old is this stove?? Dual ,large element gets toooo hot...is this repairable..??? expensive ??? worth the repair ??
Carol , read your question to yourself . what do you think about age and other questions.. I am feeling nice tonite or I would delete it as irrelevant . we know nothing about your stove MAKe<MODEL <YEAR
Jul 15, 2016 | Kitchen Ranges
Htc sync wont sync phone comes up with error 1001
Hi @fmarcoux260496. I have some troubleshooting steps for you that may get HTC Sync working again!
On your PC, go to Control Panel and click "Add and Remove programs" in Windows 7 and Windows Vista or "Programs and Features" in Windows XP. Double click HTC Sync and choose "Repair."
If Repair does not work and you still get the error, reinstall HTC Sync. To do this, click on "HTC Sync" and then click "Change" or "Change/Remove" and follow the on-screen instructions. Do this for "HTC BMP USB Driver," "HTC Driver Installer" and "Adobe Air" as well. Once that's done, go to http://www.htc.com/ca/support/amaze4g-videotron/downloads/ and download and install HTC Sync. It is under the heading, "HTC SYNC 3.0.5579 FOR HTC AMAZETM 4G ' 15.12.2011". Complete instructions can be found by clicking "More." This will also install the newest HTC drivers and the newest compatible version of Adobe Air.
After you've finished installing HTC Sync, connect your phone to your PC via USB. Select "HTC Sync" from the "Connect to PC" pop up on your phone, and the phone will search for and open HTC Sync!
If you're still seeing the error message, disconnect your phone and perform a soft reset, and then re-connect the phone to your computer. To do a soft reset, just turn the phone off and remove the battery for one minute, then re-insert it and turn the phone back on.
If you still experience problems, I recommend you contact my teammates in Customer Support. You can find their contact information at http://htc.com/support
Please check in and let us know how that helped!
Jun 01, 2012 | HTC Sensation 4G
Will the new Droid Phone allow for wireless sync with outlook calender, contacts and e-mail without the use of a server?
companionlink has a couple of sync products. The cheap one only syncs when requested, the more expensive can be scheduled to run as frequently as every few minutes. You could also try google sync for appointments and soocial.com for contacts, both free. Soocial.com doesn't like contact pictures.
Nov 02, 2009 | Google Android
My phone was reformated and I need to sync to palm desktop
no once your phone is messed up and all of your stuff gets deleted there is no way in getting it back. i know by past experince.
Jul 28, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
Palm Tungsten E2
The top digitizer is defective and needs to be replaced.
You can find digitizer parts in ebay or other on-line companies, at reasonable prices.
Regarding the labor cost, depending of the repair shop you choose, it may be cheap or expensive.
Also, if you have minimum experience and skills in fixing electronics, you can try it. really is not so difficult, and minimum set of tools are needed for it
Best regards,
Sep 26, 2008 | Palm Tungsten E2 Handheld
Need to replace timing belt on 1999 Toyota Camry.
having them changed by a certified mechanic is your best bet,Timing belts are a wear item. Most are to be changed every 60,000 miles for preventive maintenance. They may break causing expensive damage to interference engines due to the collision of valves and pistons as they go out of sync.Having them replaced at intervals is the best way to save yourself from a very costly repair.The task of the timing belt
Jul 29, 2008 | Toyota Camry Cars & Trucks
Component Video losing sync with too much White signal
I had this exact same issue. I tried two different component AV switches, and shorter cables to prevent signal loss, but any time there was too much white on the screen, the video still lost sync. Plugging the sources directly into the TV solves this problem, but since I have a DVD player, a game console, etc, this was not acceptable. The way I resolved it was to (sadly?) buy an expensive component AV switch that can support the bandwidth without losing the signal.
I wound up spending the extra money on a Key Digital 4x1 component switch. It is much more expensive, but it works.
May 02, 2008 | Onkyo TX-SR604 Receiver
Display is not coming when i switch on the player
seetha - Call Sansa to get THEIR price. View eBay to find a reasonable price. It is definitely NOT cost-effective to repair it. Ask your local Geek Squad if they are willing - probably no - minimum $250. If you live in Philadelphia or another major metro, see if they have Mp3 repair servicemen - most places do not because the actual builders/info is in Korean, Japanese, etc, and b/c it is less expensive to replace than to repair.
other guests -
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Nov 22, 2007 | SanDisk Sansa e260 MP3 Player
Mitsibishi 50" vs50607 convergence?
Rolling picture could be a pip module problem as both horizontal and vertical sync goes through the PIP module. These sets have been known to have bad caps in the pip board causeing loss of vertical sync.If you need any more info let me know.
Oct 15, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Televison & Video Logo
22 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
