Question about Miele S251i Plus Bagged Canister Vacuum
Cable not rewinding on Miele vacuum cleaner model s256i
I have a Miele Black Diamond vacuum cleaner model no. s256i. The cable rewind does not retract. How can I open the machine and rectify this problem?
VacuumRepair
  • 438 Answers
SOURCE: How to fix the retractable cord, the coil came
Greetings from GoVacuum,
I'll attempt to try and walk you through this repair with a detailed explanation of it, and along with some pictures to help you. You'll first want to buy the new Miele S500 series cord reel (hopefully from GoVacuum), You may purchase the S500 Series Cord Reel Here; Miele Cord Reel - s500 Series #5240304 .
So once you have the cord reel, you'll need either a Phillips head screw driver for the older S514 models, or a T20 Torx Screwdriver for the newer S514 model vacuums. The picture below is actually of the Miele S518 Cat & Dog series, but for this repair the procedure and parts are identical to the S514. You'll need to remove the hose, wand, and power nozzle from the vacuum cleaner2_bing.gif before you begin.
The first thing you'll wand to do is open up the bag housing, and remove the vacuum2_bing.gif bag, as well as the exhaust filter which may be either the Cloth Super Air Clean Filter, or the HEPA Filter catridge which is blue in color. If you're using the Super Air Clean filter, remove the filter, and then remove the bracket that secures the filter in place as well. Simply pull straight up on the bracket and it will come out.
Once the bag and the filter have been removed, you'll need to take off the entire tool lid. While the vacuum cleaner is open so that you can see into the compartment where the bag just was, you need to pry two arms from the tool lid off of the main body housing. Simply put a screwdriver behind one of the blue arms, and pry inwards. Here's a picture of what this looks like;
Once you have removed both of these clasps, the tool lid will pull straight upwards and off, leaving you with only the bottom part of the canister. This is how the vacuum cleaner should look now;
Now you'll need to remove the black speed control box from the canister. There is one screw in the front of the black speed control box that needs to be removed. After the screw has been removed, turn the vacuum cleaner around so that the back of the machine where the cord reel goes into the vacuum is now facing you. If you look where the black speed control box meets the bottom part of the canister, you can see two clips that you'll need to release before the variable speed control box can be removed. Simply put a screw driver and push in on the clip while lifting the black speed control box at the same time. Here's where the clips are located on the vacuum;
Ok, now that the speed control box has been removed, it's time to separate the colored plastic from the base of the vacuum cleaner. There are 7 screws that need to be removed in order to get these housings separated. I have circled the location of each screw in the picture below;
After removing all 7 screws, you can then simply pull upwards on the colored plastic housing, and remove the housing from the base of the vacuum cleaner so that the motor and cord reel are exposed. Once you have exposed the cord reel, you'll need to remove the internal wires (white wire is in the higher posistion, and to the left of the lower right side black wire), as well as the rubber hose part. The rubber hose part simply pulls off, just like the wire terminals do. After removing these parts, you'll need to remove one more screw with your screw driver. Here's the picture of which screw needs to be removed;
After the final screw has been removed, you'll have to remove the rectangular shaped wire harness that sits at the top of the cord reel. Pay close attention to how this wire harness is correctly seated which will save some aggravation when putting the vacuum back together. Here's a picture of the wire harness that needs to be removed from the old cord reel;
Once the wire harness has been completely removed from the old cord reel, you may simply pull up on the cord reel and remove it. The new cord reel will come completely assembled, with all the parts and compontents that your faulty cord reel had. You simply need to line up the screw hole on the new cord reel with the hole in the bottom of the base of the vacuum. When installing the new cord reel be very careful that you don't pinch any of the wires down by putting the cord reel on top of them.
If this repair guide was helpful to you, please click the four thumbs up icons in the top right part of this solution to rate it has helpful.
Thank you so much,
Chris Jones
GoVacuum.com
Posted on Mar 19, 2010
SOURCE: Access to the Plug in Cable of Miele White Star Vacuum Cleaner
Problem solved. A guy posted on the internet a step by step explanation including photos of how to open a Miele White Star vacuum to get to the take up reel.
Posted on May 14, 2009
ukvacfan
  • 328 Answers
SOURCE: The automatic cable rewind on my Morphy Richards
Hi Not really. It means that the cord has been pulled roughly when its been plugged in and the retracter is getting weaker to hold the cord that has been pulled out. Generally though wipe the entire cord from the end of the machine with a dry cloth and some furniture polish. This will clean the cord and add some resistance to the retractor that could minimise the cord flowing back into the vacuum.
Posted on Jun 19, 2009
  • 294 Answers
SOURCE: My deluxe elite rewind vacuum spits out dirt
The elite rewind does not have any fancy features. This sound like you have a blockage in the foot or base of the vac. remove the bottom cover to look under. Also check the hose, it can be in there as well.
Posted on Apr 21, 2010
  • 4 Answers
SOURCE: Vax V-091 Rewind Mechanism Broken
If you need help or advice, please call the Vax Customer Careline on 0844 412 8455 with your machine available, and an Advisor will be able to help you. The Vax Careline is open every day, from 8.30am until 6.30pm, Monday to Friday, and 9am until 5pm on Saturday and Sunday. Outside of these times please check the website support section which includes videos to demonstrate how to deal with everyday problems such as changing filters and belts and checking for blockages. With best wishes, The Vax Team.
Posted on Apr 22, 2010
How do I dismantle a Miele S8310 vacuum cleaner?
if the service agent states that it is not cost effective to repair then trust that advice
They will know of the difficulty to get it apart , the lack of spares when you do break it apart and the safety risk that is posed by repairs by untrained people
many wholesale cleaner shops have regular sales where the price of a new unit will be half the repair cost of an old unit
Apr 15, 2016 | Miele Vacuums
How can I fix my Miele cat and dog vacuum cleaner. The electric lead will not stay out it keeps wanting to rewind. What can I do?
I think this model is a canister. If it is you might have broken the retractor reel from its bracket. Unfortunately it has to be taken apart and the part checked. Unless you are familiar with taking these apart you will need to bring it to a Miele dealer to have it looked at.
Mar 03, 2015 | Miele Vacuums
How to rewind the power cord assemble?
The only way to rewind the cord assembly is to take the cord real out of the vacuum and rewind it and put it back in. There is no easy way to do it
Apr 29, 2014 | Miele S514 Solaris Electro Plus Vacuum
Think cleaning lady pulled too hard on cord...now no power, doesn't turn on
it is possible that the cord rewinder has become broken inside the unit. It is a common problem with this and other models by Miele.
There IS a fix to the cord rewind, unless your model falls within the 5 year warranty. In which case contact your nearest Miele dealer for a replacement to the cord rewinder.
Good luck.
Nov 19, 2010 | Miele S514 Solaris Electro Plus Vacuum
My Miele Carina Vacuum stopped working. Does it have a fuse that can be replaced that could be at fault here?
although it might have an internal fuse on this model, I dont think that will be the problem.
The miele cord rewinder has been known to have a small fault in it where the cord winder that actually retracts the cord onto will come apart from the electrical connection in the cord winder itself.
As most of these units have a 5 year warranty anyway, I suggest that you take it to your nearest miele dealer for a repair/replacement on the cord rewinder.
Good luck.
Nov 06, 2010 | Miele Carina Vacuum Vacuum
May 13, 2009 | Miele S251i Plus Bagged Canister Vacuum
Miele S251i Plus Bagged Canister Vacuum Logo
984 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
