Question about Blaupunkt IDC-A09 5-Disc CD Changer
5 cd changer on a peugeot 307 has all 5 lights flash but will not play
  • 2 more comments
  • wtm123 Jan 24, 2009
    put cd in nothing happens but 1 to 5 numbers flash
  • Anonymous Feb 06, 2009
    same problem
  • Anonymous Mar 06, 2009
    flashing light asking to load cd 1 and nothing else ?????????/
  • kieran84 May 16, 2009
    i have been trying any thing but am not to sure to do the above cause un sure how to do it
Cd changer off set common fault had it happen three times due to buttons being pressed to quick take changer out remove leads for a minute replace them turn on ignition should reset if not cd drive wiil need to be relined see dealer repaired one but really tricki
Posted on Dec 19, 2008
Same problem. car center says it's the lens that doesn''t read the cd's good anymore ?
Posted on Jan 26, 2010
3 Suggested Answers
SOURCE: Cd changer will not work
I had the same problem with my 2002 307SW.
I read on another forum to switch ignition off, remove CD changer from dash and disconnect. It then told me to remove the lid from the case unscrewing the screws marke 1 to 5 then remove the Cd's. The only problem with this is you need a special size 'star' driver bit which i did not have at home and could not unscrew them. What i did was to use a terminal screwdriver in the 2 larger screws that fasten the front plastic cover on the unit. Once I had done that I could remove the CD's.
I then connected the changer back up and inserted it back into the dash. I then powered the radio back up anf loaded a CD and the problem had gone away so I loaded the 5 CD slots and everything works fine now.
Posted on Jan 23, 2008
Eagleeyes
  • 199 Answers
SOURCE: 307 5 disc cd changer wont play or eject cd,s 2003 307.
hi there is a repair kit for this unit.
please see: http://carradiospares.co.uk/repair-8619001490-p-256.html
mark
Posted on Jul 21, 2008
Peugeot 307 Audio
Anything is possible with a bit of fore thought ,take old one out then try to fit the new one the wiring plugs should be the same for two of them but the third one will work the changer so leave that disconnected
Nov 29, 2011 | Blaupunkt IDC-A09 5-Disc CD Changer
Fit radio control switch peugeot 307
i just changed the tape for my peaugot 307 becuase the last one had a beebing problem but all the dash board lights seem to come on, what is the problem and how do i fix it please ?
Oct 23, 2009 | Blaupunkt Car Audio & Video
Peugeot 307 BP905038637756 7607769050, code please?
PEUGEOT Blaupunkt
There may be 2 different codes depending on how old the car /radio  is.
Try 3963
and if your radio will not accept any digits higher than 6 ( ie 6666 is the highest  )
then try 2211
Sep 04, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
Peugeot 307 can t open trunk help
get the back seats down jump into the boot and lever the catch with a screwdriver
Jun 05, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
Peugeot 307
having same problem. faulty after disconection of battery
Jun 03, 2009 | Blaupunkt Car Audio & Video
Flashing lights on cd changer, Peugeot 307!
There are a few variations of this model eg; IDCA09,IDCA04,Fiat & aftermarket units.As already stated these models do suffer from mechanism faults quite a lot.This is due mostly to the complexity of the mechanics.The flashing lights are a classic symptom of a jammed or broken part of the mechanism.They can however be repaired by certain car audio repair centres here in the UK.I'm afraid unless you know what you're doing then just by stripping the mechanism down is unlikely to cure the faults than can occur.
Feb 03, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
Peugeot 307 Blaupankt CD Changer IDC-A09
Hi, I know this is an old post, but I'll reply, so that other readers may get the benefit of my answer.
2004 was the year that Peugeot/Citroen changed from VAN bus to CAN bus wiring on their stereo's. If your car is before or early 2004 you will need the IDC-A09 blaupunkt in dash changer, which should just plug in and work straight away.
However, If your car is later 2004 onwards you will need the IDC-A04 Blaupunkt changer which will plug in and power up, but will not work properly untill you go to a peugeot dealer and they hook up some diagnostic software to tell the car a changer has been added. Both the IDC-A04 and A09 changers look identical.
I would say that you got the wrong changer, as the IDC-A09 changers in pre/early 2004 should just plug in and work.
Remember: Pre 2004 cars need IDC-A09 (plug and play) and Post 2004 cars need IDC-A04 changer (get pug dealer to reprogram cars computer)...its a costly mistake if you bought the wrong one!
Oct 28, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Cd player
hi does it do anythig at all? does it flash?
Mark
Mar 21, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Blaupunkt IDC-A09 5-Disc CD Changer Logo
2,761 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
